Question about Sceptre X23gv-Komodo 23 in. LCD TV
1/2 screen is black
Sceptre X23gv-Komodo 23" LCD-TV
When the TV turns on, it only displays the right half of the screen and the left side is black. This separation "line" is vertical to the red/blue ON light.
It will display half the input (cable) and I can change input.
Looking through the vents in the back, the right (good) side has a green light, while the left side does not.
Also looking closely at the blank image with a flashlight I see no signs of ghosting or faint image at all.
Please help if you have any knowledge on this issue.
  • xiaona Apr 26, 2009
    I have the same problem. how do you solve it
  • 406 Answers
SOURCE: Sceptre X32GV-Komodo
Please set it to auto mode. And see that you have put the signal in right position and place
Posted on Mar 20, 2008
SOURCE: Sceptre X9G Komodo IV
I have a 19" Sceptre Comodo display. After 3 years it got the problem everybody complains about. Took it apart yesterday.
There are 4 capacitors in a row on the power supply board (it has a socket for the power cord and is covered by a metal shield. The caps are barrel-like things standing upright on the side opposite to the power cord socket.) Two of them are 470 uFx 25 V, they are next to each other. In my case, one of them popped up and another one was bloated. I pulled out the power supply board (make sure you unplug the power cord and press the power button do discharge the high voltage caps before messing with your monitor) after disconnecting all sockets (mark'em!). I assume that you have new caps handy (I paid $2.10 for a pair at a local electronics store), they must have the same capacity and voltage rating. Now grab a soldering iron, remove old caps, and put new ones in. You must observe polarity! (Usually "minus" pin is labeled on the cap's side. Mark down "minus" and "plus" pins location of old caps and put the new caps in exactly the same way! Otherwise, you can blow the caps.) If you are not used to work with a soldering iron, hire somebody or buy a new monitor. Check the quality of the work (no shorts, solid contacts, etc), assemble the monitor back and may be it will work (did for me). If it does, you put one monitor less into the city dumpster, be proud to get a working monitor for less than $5, and force you mother-in-law to take this shiny new replacement display she just bought back to the store.
Of course I do not guarantee that my procedure will work for and you can use it at your own risk only (i.e. I am not liable for any damages).
Posted on Sep 09, 2008
SOURCE: Sceptre X32GV-Komodo keeps turning on and off
I replaced my own part and it works as new again .Go to ( Power-On.com )Look up part #LCD225-6M Power supply it only cost $65.00 and ups shipping was $10.46 2 day later I got it and 15 mim. later we were watching TV again
Posted on Dec 19, 2009
budmrtn
  • 11361 Answers
SOURCE: I have a X42 Komodo
That is the TFT (Thin Film Transistor) drive stuck on due to bad transistor or the IC driving it or bad tab connection.
Learn more here;
PDF download: http://www.mediafire.com/?zzjygannjty
See example here; http://s807.photobucket.com/albums/yy352/budm/VIEWSONIC/Viewsonic%20VX710_910/
New panel needed. You can try reseating the ribbon cables, but not liekly.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Aug 11, 2011
yutianyunren
  • 848 Answers
SOURCE: sceptre LCD - no display
Sceptre LCD - no display? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
Sceptre LM004 Power Supply Backlight Inverter for X9G KOMODO
Posted on Mar 22, 2015
Sceptre X42GV-Komodo 42 in. LCD TV no picture no sound but splash screen displays good
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 22, 2014 | Sceptre Televison & Video
Why are there multi-colored lines in the middle of the TV?
The usual suspects include main and other boards it is connected to up to and including a defect inside the display panel itself which is of course fatal.
Jun 15, 2012 | Sceptre X32GV-Komodo 32 in. LCD Television
Half of the screen turns black after 10 mins 46" Sceptre LCD TV
YOU PROBABLY HAVE DEFECTIVE LCD PANEL THERE IS A SLIGHT CHANCE IT IS THE MAIN BOARD OR THE LVDS CABLE
Apr 10, 2009 | Sceptre X42GV-Naga 42 in. LCD Television
Mar 15, 2009 | Sceptre X32GV-Komodo 32 in. LCD Television
I have same problem... just went off warranty and they won't cover it.. they want $100 for repair plus $35 shipping plus I have to pay to ship it to them... For $179 I can buy a new 19" with 3 year warranty...I wouldn't buy another Sceptre at half the price
Jul 13, 2008 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Monitor Problem
Use ctrl+alt+ up Arrow key on your keyboard (you can also use use ctrl+alt+ left/right Arrow key)
Good Luck
Jan 17, 2008 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Sylvania 42
Check the fuses on YSUS & ZSUS boards, if found the fuse blown on that board, just try to replace the board.
Dec 30, 2007 | Sceptre X23gv-Komodo 23 in. LCD TV
Sceptre X9G Komodo IV 19" Monitor
Hi dgp1952, Check with www.lcdrepair.net if you want a repair. Something is wrong with your backlight or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. Dust can cause the circuitry to heat up faster and put the power supply into Clamp mode. Clamp mode will turn the supply off to certain circuits which may be the reason your display is going black after 5 minutes.
Oct 09, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Sceptre X23gv-Komodo 23 in. LCD TV Logo
63 people viewed this question
Top Sceptre Televison & Video Experts
Henry  Thomas
Henry Thomas
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
