It's my moms car and she says the heater core has been replaced 3 times since 2000 so is there another thing that could be causing the antifreeze on the drivers side floor. I know alot of people say usually the leaking is on the passenger floor board, could you please help
There is only so many things that can cause this and are you sure its anti-freeze and not washer fluid.just something else.a damaged heater core is usually what causes a leak inside the car.when the heater cores were replaced did the shop say there were signs of them leaking or couldn`t see anything.the other is coolant from a previous leak could have spray aroung the air ducting in the dash and has finally found a way out.but this should have been gone shortly afterwards and usually there is only a mist that is sprayed into the air ducts which usually shows up on the inside of the windows,so i don`t think this is the problem.if the hose clamps are loose were the hoses are fastened to the heater core spigots/tubes it could be leaking inside the cars air duct.and yes its unusall for anti-freeze to leak onto the drivers floor but stranger things have happened.
