Question about Linksys Wireless-G WRTP54G Router
Linksys router the router resets itself after powering up. any solutions
Hello any one help me for router i can't entry to sitings on the ip
Posted on Sep 24, 2008
I have a Zyxel Q1000z dsl router power light and DSL light on solid green however internet light is completely out not red or green or anything Qwest my service provider tested the line as good. I have...
If you have called your service provider and they have confirmed that the connection is good then there may be a problem with:
A- The router itself
B-The physical connection from the ISP's last access point to your router.
Your best bet would be to (if you haven't already) reset the router and wait AT LEAST 10-15 seconds before plugging it back in.
Another solution would be to go to the router configuration page and check the router logs to see when the problem first occurred, and what could be causing it.
Jul 09, 2011 | Zyxel P660HW-D1 Router
How to set the factory default on the router
To bring the router back to its factory default what you can do here is to reset it using the reset button on the router itself.
To do that using a pen or paper clip press and hold the small reset button on the router for 10 seconds while power is ON and then after that let it go and power off and power on the router and its back now to its factory settings.
May 11, 2011 | Linksys WRT120N Router
We have a 3CR858-91 3com router and nobody knows it's administration password. I have tried to reset it to the factory defaults using a RJ45 cable (DSL port to LAN port connected) but it does't work (even...
I have same problem. So the solutions is (in my particular case), when you done everything as it written in the reseting instruction. You face blinking LAN/WAN ports and no any activity with Alert LED. After 30 second or even 1 min (i don't relly know do you need to wait or not), i disconnected LAN/WAN ports and connected it again without repowering. Then Alert LED starts to blink slowly every 2 second. After re-applying power it was reseted.
Mar 29, 2010 | 3Com 3CR858-91 Office Connect Cable/DSL...
2wire 1800HG router keeps resetting
1) Check power cord. 2wire has known issues with power cords being defective. If you have a Multimeter, I would check to ensure the correct voltage and amperage and being delivered to the router first.
2) Need to resolve the "resetting problem" first. Then attack the port forwarding issue.
Aug 15, 2009 | 2wire 2700HG-B Router (2700HGB)
All of the computers are losing their connection to my network
are there any lights on the router?
if yes then may be your router survived and restarting the router may fix your issue
if there are no lights then it means either your router has died or the power supply adapter is faulty.
Thnx and please rate this solution
Hope you find it helpfull
Jul 16, 2009 | D-Link DIR-625 (790069292637) Wireless...
Need default password for wa540g router
Usually the default password for a router is ADMIN.That should be also written on the router itself on a sticker.Before you try it you should do a hard reset by pushing in the reset button for 10-12 minutes.
Jul 10, 2009 | ConnectGear (WA540G) Router
I cant reset my password. i want to reset this
If you have forgotten your password the only option is to reset it to the factory default using the reset button on the back on the router (little pin hole between power socket and WAN socket).
  1. Leave the power on, do not disconnect the power
  2. Press the reset button and hold (use a paperclip)
  3. Keep the button pressed for 10 seconds
  4. Release the button
The router will now reboot itself and will be reset to factory defaults which are username: admin / Password: Blank (ie. no password)
Jul 05, 2009 | D-Link AirPlus DI-614+ Wireless Router
Wireless router not connecting to internet
Unhook all wires except for the power cable. Press and hold the little reset button on the back of the router for 30 seconds ( I know, most sites say 5 seconds is enough...)
After releasing the button the router should reboot itself. Sometimes after the reboot you have to press the reset button again for just a second and release it. The wireless should reset itself at this point, but this will also reset all of the router settings. You will have to log into the interface and reset your security and other settings. The user id & password should reset to admin & motorola, unless you have loaded aftermarket firmware.
Apr 09, 2008 | Arris Wireless G Broadband Router (wr850g)
Linksys WRT54GX2 constantly disconnects
I just upgraded from firmware version 1.01.14 to 1.01.22 and I have the same problem, the router just keeps resetting itself. I think the solution is to go back to the old firmware, but I haven't been able to find a copy yet, Once I find firmware version 1.01.14 for the WRT54GX2 router. I will let you know if this is the solution... :)
Mar 08, 2008 | Linksys Wireless-G WRT54GX Router...
Help with DI 524
Start your router, and keep and hold pressing on the "reset" until it resets by itself. This will reset the router to defaults. If the lights got back to work normally again, then you are ready to go. you can access your router by directing your browser to Admin as user and blank as password Download this manual to get you going on configuring your router Goodluck
May 25, 2007 | D-Link AirPlus DI-524 Wireless Router
Linksys Wireless-G WRTP54G Router Logo
59 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
