Question about Panasonic Lumix DMC-FZ8 Digital Camera
Lense stuck out, cap error message
I have the same problem - what is the next step? Can I romove the lense or do I need to send it somewhere to be worked on? Lense is semi extended and the camera continually gives the message to remove the lense cap. Camera wasn't dropped and there is nothing preventing the lense from retracting (sand, grit etc).
  • 1,031 Answers
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move. The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism,
Posted on Sep 24, 2008
  • Starnley Johnwells
    Starnley Johnwells Sep 24, 2008
    take the following steps
    The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
    Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on.
    Fix #2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
    Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
    Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
    Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
    Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
    Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
    Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
    hope this works.goodluck appreciate by rating it
    President:
  • 1,952 Answers
I wonder if the lens isn't a standard size and you could find a poppable cap for it? If not, yes I definitely see how a screw-on lens could be a major cause of frustration.
This is really up to you. It is not really a good idea to leave a lens exposed; there are lens caps for a reason, and that is to keep your lens safe. The plastic cap is attached to the camera, so maybe you could get into the habit of snapping it on and off? Think of it this way: the time the camera takes to open an auto lens cover is about the same amount of time it would take you to pull off the plastic cap, so you probably won't miss any more pictures because of it.
The main reason this happens is when there is dirt on the lens, or a smudge. This can confuse the focus meter causing an error because it is trying to focus on the error on the lens. This is easily solved by gently cleaning the lens with a non abrasive cloth.
It could also be a true zoom parts malfunction for which I have no solution for but hopefully it is only a bit of dirt.
  • mohammed marika thambi
    mohammed marika thambi Sep 24, 2008
    use this link more use ful ur product
    Panasonic Lumix DMC-FZ8 Digital Camera Review - Panasonic Point ...','digitalcamerainfo.com');"http://www.digitalcamerainfo.com/content/Panasonic-Lumix-DMC-FZ8-Digital-Ca...
    This lens is complemented by Panasonic’s Mega Optical Image
    Stabilization system, which has two modes. The mode can be chosen with
    the button atop the camera with the shaking hand icon next to it. The
    image stabilization can be turned off or to the ambiguously titled
    “Mode 1” or “Mode 2.” Mode 1 only activates when the shutter release
    button is pushed halfway; it is more energy efficient. Mode 2
    continuously functions for the live preview and the final captured
    image. Both modes work as they should and the system as a whole works
    well. It keeps video steady and reduces the occurrence of blur in
    images.
    Be The First To Comment
    Add Comment Enter your comment...
    dropped it and it
    must've knocked the lens barrel sensor out of whack.
    With the lens barrel out, I gently pushed the barrel up, down, left,
    right and put a little pressure in. Somehow, the barrel worked itself
    into the right position! The camera works perfectly know. Its worth a
    shot to save $$$. Be gentle!! Good luck.
    Guru:
  • 558 Answers
Hi there, Thanks for your posting in FixYa. Please do the following:For Cleaning the lens, turn the camera off, retract the lens barrel and gently wipe the lens surface with a soft dry cloth. Hope this would help you a lot. Dont forget to rank me up. Have a nice day. Best of Luck & RegardsELLIN
  • Puneet Jain
    Puneet Jain Sep 24, 2008
    Hi there,If you're under warranty, that's the avenue I would pursue, since doing
    anything to try to fix it yourself will void that, and why do that when
    you could get it fixed possibly for free?
    If that isn't an option,
    there are a few things you can try:
    -Blow gently (breath works best,
    if you use something like compressed air be very very careful!) around
    the lens mechanism. Sometimes a trapped piece of dust or dirt where the
    lens retracts can cause this.
    -Turn the camera on; when the lens
    starts trying to move, give it a gentle tug (hold it out for a minute)
    or alternatively, give it a gentle push (as it tries to come out, push
    it back in). You can also try holding it right up to a table top and
    turning it on so that the lens touches the table as it comes out and
    gets pushed back in again. This may fix it.
    Regards
    Ellin
    Master:
  • 726 Answers
Try to take out the battries for like 5 minites and so on if there is no obstuction with the lens there will be a fault in the camera and will be difficult too relace your self its better off sending it back as it seems the sensor inside for the lens is buggered thanks from chris plz rate
In the middle of taking pictures, all of a sudden my Nikon P100 will become blurry and then the Lense Error message will come up saying, "Lense Error: if the lense cap is on the camera, turn the...
Could be sand particles getting into the seams around the lens barrel, binding it up. Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 08, 2011 | Nikon COOLPIX P100 Digital Camera
Finepix j27 When the camera is turned on "Zoom error" message appears and lense is stuck in an extended position. When the power is turned off, the lense remains extended. Do you know how...
hi, Zoom Error occurs when there the lenses are not able to move and something is obstructing the movement like some dust or sand grains etc., to dislodge the obstructing particles try tapping the lense side corner of the camera on a table top lightly (not too hard please, as the lense and autofocus combination is quite fragile) a couple of times in switch off mode and trying to power on after every 2-3 taps.
or you might send it out to a service centre, the charges are generally just the serviceing charges as no new parts needed.
hope this helps
cheers
May 05, 2011 | Cameras
I have a Toshiba Satelliet P105-S6114 my dvd rom does not work is it very hard to replace
open cd rom door just clean lense with soft cloth ...if same
remove cd rom romove top cover then romove buttom u can see on back of lense two veriable for lense adjustment try one by one one adjustment is for normal cd and one is for dvd cd dont try together.. move little bit...and clsoe and then check... Thanks
Sep 05, 2010 | Toshiba Satellite p105-S6114 Notebook
Camera powered on, lenses extended, then got an E18 error message. Won't take pics, lenses won't retract. Tried charging battery, no difference. Powers up, powers off, that's it.
Canon E18 error happens when the lens gets stuck while trying to extend.
There is a step-by-step tutorial (with pictures) for fixing this yourself on this website, which is too long to re-post here.
You can also try tapping the USB port lightly against a hard surface, and using compressed air to blow out the area between the camera body and the lens turret.
If you can't fix it yourself and decide to send the camera back for repair, be warned that Canon has horrible customer support and response time. You might want to consider replacing the camera instead.
Oct 25, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
Repair stuck lense
try to take out the memory card, the battery again.
is there a error message ? was it in water/sun for to long?
try to see if there is something stuck in the lend, like send or dust.
Jul 21, 2008 | Nikon Coolpix 5700 Digital Camera
Dsc w7
While turning in off softely press the lense in and out a couple of times. The lense would retract. If not fully, but most of the way, push the lense a little harder in until completely retract. If you turn it on, I should work fine. The reason the lense does not retract is most likely some dust in there somewhere. If it did not help, you would have to open the lense and clean it and close the lense.
I hope it helps,
Jul 13, 2008 | Sony Cyber-Shot DSC-W7 Digital Camera
Lense Cap Error
This problem is caused by a stuck aperture assembly. The problem has occured on multiple models made by JVC (GR-DF430u, GR-DF450U and GR-DF470U). You have to have some degree of technical aptitude in order to disassemble the unit and access the part causing the problem. The tiny motor that opens the aperture flaps is not able to overcome the sticky oil/grease that JVC unwisely used on this part. Therefore the flaps stay closed, and the camera sees no light when you remove the lens cap. This makes the camera think you haven't removed the lens cap, causing the "lens cap" error.
If you feel like you have the skill and you are careful, you can disassemble the unit and clean the part yourself. It takes longer to take the unit apart and put back together than it does to clean the sticky oil off the part.
If you contact me, I can send you a diagram of where the part is located that you need to access. This is not recommended for amateurs, as you can damage the unit and cause other problems if you aren't somewhat skilled in disassembly of electronics.
Mar 03, 2008 | JVC GR-DF450 Mini DV Digital Camcorder
"Cover opened" error message
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Sep 14, 2007 | Kyocera Finecam L4V Digital Camera
Error 2 message
I have the same camera, but not the error message. My lens occasionally will get "stuck" out. I have found that removing the battery for a few minutes then re-installing it will "reset" the camera and the lens will retract when the power button is pressed. This "fix" does not always work.
A call to Vivitar only results in the suggestion that you send it in for repair.
Apr 04, 2007 | Vivitar ViviCam 8300s Digital Camera
Panasonic Lumix DMC-FZ8 Digital Camera Logo
274 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
