Question about Nokia 6270 Cellular Phone
Can't switch on my Nokia 6270
Well , I was on a sleep, after that my phone alarmed I woke up, then i go and stop it . It ask me to snooze or stop , i press stop. Then it mention that switch on my phone or not ? I press On . Then the screen goes blank.
Maybe between my sleep ,there is phonecall ringing and till it used all the batteries power? But I charged it for hour , and try press the switch on button , it don't switch on. Whats the problem? How do i solve it ?
    Problem Solver:
  • 10 Answers
First check u'r battery....... if it's not k then clean u'r board with thinner r petrol........ then also it's not k u wannsa to flash u'r mobile contact any service center near u
Posted on Oct 04, 2008
How do I switch off the alarm on my CR1003 (model Number) Blaupunct bedside radio?
Setting the Alarm
1. Press and hold the 'Alarm/Sleep/Snooze' button to enter alarm mode.
2. 'Alarm Status' will be displayed and 'ON' or 'OFF' will flash on the second line of the display. Use the right hand rotary control to change the display to 'ON' or 'OFF' as required and press the right hand rotary control to confirm.
Stop the Alarm
When the alarm sounds press the 'Standby' button on the top of the radio. Alternatively, you can press 'Alarm/Sleep/Snooze' on the top of the radio.
Turn off the Alarm
Follow steps 1 and 2 in 'Setting the Alarm' and select 'OFF' in step 2.
Snooze function
When the alarm sounds, you can press the 'Alarm/Sleep/Snooze' button on the top of the radio. 'z' will be displayed in the bottom right of the display and the alarm will sound again in approximately 5 minutes.
Apr 16, 2017 | The Audio Players & Recorders
Nokia 1110 alarm click default snooze to off
when an alarm appears you have two options one is snooze other is off if you select off it wont snooze......... by default snooze will come after 10 mins even if you missed it first time you can off it next time ok.
Oct 21, 2011 | Nokia 1110 Cellular Phone
Problem with launcher Pro and alarm clock. No way to turn it off or to put on snooze. I can't switch off my alarm clock or snooze. I have to turn off the phone completely to make it stop. I use...
I had the same problem the other morning. All I wanted to dowas go back to sleep, but the alarm would not shut off.
Here is how to fix it:
Go into the clock, then alarm clock and click the menu button, then settings. Go to Slide Button Behavior, which will give you threeoptions, choose none.
Now, when your alarm goes off there will be a pop up and you can either choosedismiss or snooze. Please don't forget to give thumbs up!!
Jul 13, 2011 | McNeil-PPC Android Apps
My alarm of 2310 is not currently ringing. It is just showing the stop and snooze buttons. Please reply as early as possible.
The alarms on nokia phones don't ring when the phone is set to silent. Check the ringer mode. Are you sure the phone speaker is working fine?
Mar 05, 2011 | Nokia 2310 Cellular Phone
How do you set aliam on my nokie e51
Got ot the link below page 67-68 will tell you how to set the alarm.
http://nds1.nokia.com/phones/files/guides/Nokia_E51_UG_en.pdf
Or
Alarm clock
Open the alarm clock tab.
To set an alarm, select Options > Set alarm. When an
alarm is active, is displayed.
To switch off the alarm, select Stop, or to stop the alarm
for 5 minutes, select Snooze. If the alarm time is reached
while the device is switched off, the device switches itself
on and starts sounding the alarm tone. If you select
Stop, the device asks whether you want to activate the
device for calls. Select No to switch off the device or Yes
to make and receive calls. Do not select Yes when wireless
phone use may cause interference or danger.
To change the alarm time, select Options > Reset
alarm.
To remove the alarm, select Options > Remove alarm.
Good luck please rate 4 thumbs up and please leave a testimonial.
Oct 28, 2010 | Cell Phones
Please my Nokia 6270 ask for restriction code whenever I switch it on or put a sim that it does not use to.
For the best unlock code for your Nokia model mobile,
you can try this site http://www.mobileunlocksolutions.com/nokia-6270/rs1wp9/
It has the step by step instructions and easy methods for unlocking mobile phone...........
Jun 23, 2010 | Nokia 6270 Cellular Phone
I wish to cancel the snooze mode on my mobile sagem 401c
Go to where you alarm is in your phone ,switch of all the active alarms.the snooze notice will stop.
Jan 20, 2010 | Sagem my401x Cellular Phone
Missed calls and message notification
try to reset your phone by dialing *#7370#.
this will reset your mobile and hopr this works.remove your memory card first before trying this and also store your numbers save to yuor phone..it will ask for the code then then type security code as 12345 which is a default one from nokia..hope this works
Jan 07, 2009 | Nokia 5310 Cellular Phone
How do I set the sleep timer?
To adjust snooze time - The system is set for a standard 10-minute snooze time (the number
of minutes you can delay the alarm). While the selected alarm is flashing, hold down Sleep⁄Snooze
and press the Time or to adjust the snooze time (from 1 to 30 minutes) for that alarm. The
number of minutes and Sn appear on the display to confirm your selected snooze time. You can
set a different snooze time for each alarm.
Oct 01, 2008 | Homedics SS-4000 Clock Radio
I can't switch on my NOKIA 6270 .
A problem might have occurred in your phone, like for example,overheated maybe and melted the leads (silvery thing) joining the circuits or the connection between components or between the battery and other related parts. But I think there's just a minor damage at all. You might find part like it was burnt a very small fire.
Sep 24, 2008 | Nokia 6270 Cellular Phone
Nokia 6270 Cellular Phone Logo
51 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
