Toshiba Rear Projection TV.
I have a 48 inch Toshiba rear projection TV, you know the kind with the 3 color guns.
I don't have the model number handy now.
Basically the problem is that the picture convergs in the corners, it doesn't fill the whole screen. and the lines especially at the corners are not straight but bent.
Sometimes it snaps in and fills the whole frame and it looks really nice. Sometimes I leave it on overnight so as to keep this nice "Full frame" picture. But after a while the picture sometimes disappears completely into Black, or it converges into a tiny opening surrounded by black.
When that happens I turn the TV off then on again, and usually I end up with the picture converged at the corners again (not a full frame picture).
I've checked all the solder connections for a cold solder joints and resoldered few of them that I thought didn't look good but I still have the same problem.
I am aware that this a common issue with these tv's.
Is there a way to fix this without spending too much money??
I am fairly handy and can fix many things.
Thank you for your time.
SOURCE: Picture warped..Can't fix convergence because crosshairs are also warped!!
hello fathertime, it seems we have the exact same problem with 60pp9202 convergence!
Please let me know how you solve it! And if you are in nyc area- I will pay someone to repair it! Kurt email- ANTIQUEBABIES@AOL.COM
Posted on Dec 15, 2007
CAYPIANAN
  • 227 Answers
SOURCE: Rear Projection TV convergence
dear friend if you have that type of skills you cerlainly can either resolder or replace the convergence stks. you we'll need to replace both if that's the case. they look like the audio outputs in the audio amplifiers. good luck
caypianan@yahoo.com
Posted on Oct 12, 2008
  • 8 Answers
SOURCE: convergence board swap questions....
You can try to change it out and go to convergence adjustment mode on service mode to setup the template.
But I rather replace couple trans and leaky diode on your old convergence amp board to save my time
Posted on Jan 06, 2009
  • 184 Answers
SOURCE: Convergence problem philips rear projection tv.
All convergence circuits require two voltages which are equal, one being positive the other negative. Check the power supply for these two voltages and then see if you're getting them at the output ICs. I suspect one of them is missing or low. If there are no cooked resistors near the ICs, inspect the fuses that protect those two voltage sources or the regulating devices themselves.
michtech
Posted on Feb 17, 2009
  • 21 Answers
SOURCE: Have a rear projection tv 55pp9352. Has green
yes, you need remplace the liquid in the picture tube green and blue, and need remplace 2 parties stk-392-120 and resistences 6.8 ohms at 1/2 watts
Posted on Jan 06, 2010
I have what I think is a Hitachi 55 inch ultravision rear projection TV that is 12 years old. I think the model is 55UX58B. The color goes out and it becomes black and white. It comes back after a few...
When the tv is it totally black and white and the tv picture are good and clear wright?when the tv colors are fade in and out are clear up and when the tv picture it is in colors it is look good normal picture wright?Tv have no shadows of any kinds of colors when picture are good in colors wright?Yes,take ur hand make fist or take a wooden hamer bangs all around the tv bazel frame if the tv colors come back or tv stay in colors it is have good picture in colors.Tv it is still good just have components parts are cold soldering or CRT colors guns R,G,B just require resoldering works only.
Aug 22, 2011 | Hitachi 50UX57B 50" Rear Projection...
48 inch Hitachi rear projection tv picture goes out.
Backlight main video board is going,video board must change,about $500 with labors.
Oct 10, 2009 | Hitachi 50UX57B 50" Rear Projection...
48 inch toshiba with color alingment problem
Hello:
Thanks for this forum.
I have a Toshiba 48" rear projection TV which started to show red and green lines on the left side of the screen and have also started affecting the left-hand focus of the image shown on the screen. I have had this TV for 14 years and had a projection adjustment done once before.
Thank you in advance for your assistance.
Ed Alexander
Dec 06, 2008 | Toshiba Televison & Video
Guns on their last leg- color fading
If you are asking about Guns in rear projection tv then answer is No.
Rear projection TV has 3 Guns (CRTs), red-green and blue and each gun has its unique color phosphorus coating to produce its mono color (red /green /blue) and these are not interchangeable.
Need further info, let me know.
Oct 23, 2008 | Televison & Video
Old toshiba
Hi Veronica,
I need to know exact model number of your Toshiba TV to help you out.
You can find it at back of TV on some kind of sticker.
Oct 11, 2008 | Zenith R49W36 49" Rear Projection HDTV
JVC 48 in rear
Probably the projection guns (my JVC had them fail on me). It started that way and eventually I had a triple image of what was on TV, one in red, one blue, one yellow, and all slightly offset from each other. The fix was new projection guns (thankfully it was under warranty as they were about $300 each).
Aug 08, 2008 | JVC AV-48WP30 48" Rear Projection...
Colors are offset
You will need to install new convergence ICs if you need more info on this please let me know. Its a fairly easy repair.
Apr 10, 2008 | Mitsubishi WS-48613 48" Rear Projection...
Toshiba theaterview 50in rear projection tv
Look at it on the QVC channel where you have boxes with straight lines. If any of the 3 colors are bowed and 1 inch off, then it needs parts inside. If the colors are straight and only 1/4 inch off, you can adjust it. Using the remote, in the menus find convergence to adjust. Your user manual will explain it. At WWW.Toshiba.com you can download the manual if you do not have it.
Mar 24, 2008 | Toshiba 57H81 57" Rear Projection...
43 inch phillips projection t.v
There is no bulb or color wheel in a standard projection set. The standard projection set has convergence output IC's that correct the 3 colors around the edges of the picture. If one of these IC's burns out then one color may sag toward the center at the top. The defective convergence IC will have to be replaced and the convergence circuits realigned and that should be done by a qualified tech.
Aug 07, 2007 | Philips 43PP9202 43" Rear Projection...
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Electro Med Services...
