Pro 42CC 2 Cycle Chainsaw, 18": New gas, clean plugs..Ran fine last year, won't st...
Check for a plugged fuel filter and defective fuel lines. Make sure the carburetor fasteners are tight. Check for spark at the plug--it should be blue and snappy with a new plug. If ok, squirt in some fuel mix in the plug hole, replace the plug, and see if it will pop a couple of times. If ok, make sure the primer bulb draws fuel into it after several pumps. If still won't run, remove the lower chamber of the carburetor and check the diaphragm for flexibility and no holes. Hope this helps!
