Question about D-Link DP 301U (DP-301U) Print Server
Print server problem
I have a D-Link 301U print server. i install hp1505 printer. i can go to print server. but i can't get print out.
Firmware is not support
Posted on Nov 10, 2008
Printing Problem
i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
1. install printer locally via usb and test.
2. create a second printer as per the dlink manual creating a port. don't worry about the name as we will delete it.
3. once created go into the properties of the 2nd printer and change the port to something local - anything will do to free up the port.
4. go into the properties of the printer that was created in step 1. and change the port to that of the print server.
5. test print. should work fine.
cheers!!
Aug 11, 2009 | D-Link DP 301U (DP-301U) Print Server
No documents are sent to the print queue when attempting to print to a printer through a DP-301U. Printing in Vista works fine, but not so much with XP.
Check and see if the drivers are installed correctly and configured on both pc's.Then see if the printer is installed and that sharing is enabled on the network. Mike tekman2300@yahoo.com let me know when you complete these steps and if it worked.
Aug 08, 2009 | D-Link DP 301U (DP-301U) Print Server
Print server DL-301U setting
I have one of theses D-Link PD-301U. It does NOT support a printer like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1006 is NOT in the list):
Apr 14, 2009 | D-Link DP 301U (DP-301U) Print Server
Hp 1020 dp-300u
dont' worry about what the d-link site says. its because they haven't tested it. i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
cheers!!
Apr 13, 2009 | D-Link DP 301U (DP-301U) Print Server
HP LJ P1008 can be used as network printer ?
I have one of theses D-Link PD-301U. It does NOT support a printer like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1008 is NOT in the list):
LaserJet
  • 1200
  • 1500 (USB 2.0)
  • 2200
  • 2200D
  • http://support.dlink.com/faq/view.asp?prod_id=2135&question=DP-300U%20/%20DP-301P+%20/%20DP-301U%20/%20DP-311U%20/%20DP-G310%20/%20DP-G321
    Feb 10, 2009 | D-Link DP 301U (DP-301U) Print Server
    Problem with scan from print server
    This unit does NOT officially support Samsung printers... but it will allow printing with some. It does NOT support multi-function printers features like scanning for any brand of multi-function printers.
    Jan 06, 2009 | D-Link DP 301U (DP-301U) Print Server
    D-Link DP 301U Print Server not continuous print from vista
    Make sure you have byte counting enabled if you are printing through LPR.
    Dec 11, 2008 | D-Link DP 301U (DP-301U) Print Server
    DP 301U and Lexmark 2550 (all-in-one)
    1. Set up your print server with an IP address.
    2. Ping your printer IP address.
    3. If successful, Add printer wizard. Create a new port, Make it TCP/IP port. Put the IP address in the IP address field. Click next and Use Generic 9XXX Raw.
    4. Install the driver provided by the manufacturer for your printer and assign it to the Network port.
    5. Print.
    Hope this helps.
    Jun 03, 2008 | D-Link DP 301U (DP-301U) Print Server
    Unable to setup printer driver fro D-Link DP-301U
    I'm not able to install the printer driver Officejet 5610 when conenct to D-Link DP 301U. It always prompt for missing file such as hpzimc09.dll hpzstw09.exe, I'm using the CD proviede when I purchase the printer and also try on the installtion file downlaod from HP website.
    May 22, 2008 | D-Link DP-301U (790069251979) Print Server
    D-Link DP 301U (DP-301U) Print Server Logo
    354 people viewed this question
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
