Question about Microwave Ovens
No power Microwave oven (samsung brand) does not work -No power .
  • Microwave Ovens Master
  • 9,086 Answers
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
The TCOs you need to be concerned usually with have all black or white wires only. Please reply with photos of your interior if you have questions.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can order Samsung parts here or you can find your nearest Samsung-authorized service center here.
Posted on Sep 27, 2008
Why won't Samsung OTR microwave work?
thanks a lot for informative reply everyone! worked well for me, sharing it with http://dissertationwritingservices.org/ now!
May 17, 2017 | Samsung Microwave Ovens
Samsung Microwave Oven SMH7159 No Power
The power outage may have been accompanied with a power surge. That can happen with lightning strikes, or if a large inductor (electric motor or equivalent) happened to be on the same power line at the time of the outage. There's a good chance a surge took out the control panel.
Aug 06, 2016 | Samsung Microwave Ovens
How do I unlock my microwave
all brands Microwave Display Repair circuit board repair ...
031d26d.namesecurehost.com/mwd/?3e3ea140
Jul 1, 2015 - All brands Microwave Oven Display Repair brand nationwide Sharp Dacor GE G.E. General Electric Samsung Kenmore Frigidaire Whirlpool free help tips. ...Press the "Custom Help" pad and follow the on-screen instructions to unlock the oven....... MH6150XLT-1 MH6150XMB MH6150XMQ MH6150XMS ...
Aug 04, 2015 | Whirlpool MH6150XMS Microwave Oven
I have a samsung smh7185 microwave and fan doesnt work anymore. Any ideas what to do?
if every thing else works normally you shoul have a defective fan becouse the same power feeds all components at the same time..
Oct 19, 2013 | Samsung SMH7178STD Microwave Oven
Kenmore microwave 911 41479791 no power?
see this causes and fix it. God bless you
No Lights or Power, Unit seems Dead First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
Sep 24, 2012 | Microwave Ovens
Samsung Microwave SMH9207ST lost power after cooking a meal, the power outlet works fine.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';
Apr 18, 2011 | Microwave Ovens
Over head fan not working
Since FixYa is not currently notifying us Experts when Clarification Requests are answered, you will need to post a NEW help request.
I
n your new post, please include your brand name and the full model number from the tag in or on the unit, your symptoms, as well as the answers to these questions:
- have the cooktop lights recently failed?
Oct 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My samsung microwave oven mw5470w is dead. it was working perfectly wee yesterday night
Check the Ac fuse on the power board in side the over.If it is blown off replace it
May 07, 2009 | Samsung MW5470W/MW5471G Microwave Oven
Samsung Microwave repair
This would be the turntable coupler, and you can get it here. The best way is to search by model number. If by chance you don't find it, call them at the number on their site.
You need to unplug power, then remove the bottom cover of the oven. In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 24, 2008 | Samsung MD800SC Microwave Oven
Power levels
You can download a manual that's close to yours here: http://www.samsung.com/support/productsupport/download/index.aspx Or contact Samsung for the exact answer: http://www.samsung.com/support/index.asp
Mar 18, 2007 | Samsung MW4350W Microwave Oven
Microwave Ovens Logo
94 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
