Question about E-Machines eMachines Desktop PC
Pc wont boot up after reformat.
I wanted to reformat my computer but it wouldn't boot from the windows xp CD rom, I tried everything with no luck. I took my hard drive out and put it in another computer to reformat it and it worked perfectly but when I put it back into my pc it wouldn't boot up, kept giving me a blue screen saying that the hard drive was either configured wrong or there was a virus. I don't know how to fix this problem...any help would be appreciated
    Novelist:
    Scholar:
  • 141 Answers
Usually after you install an operating system on one computer and then install it on another one you most always have to do a repair (not a recovery). Make sure you choose the repair option after you have to hit F8. Reason being for the repair is that a big part of installing Windows is that it configures the devices that it detects in that machine at that time. So putting the hard drive into another computer it needs the repair to detect the devices that must be configured to that pc.
Try another cd rom drive or the one that was in the other machine. All cd rom drives do not work on all pc's. Then go to the bios/at boot option choose the cd rom drive as first then disable all other boot devices at this time. You will go back after the repair and leaving the rom drive always as the first boot device/hard drive second/ and your choice third. It's best to leave the cd rom as first at all times because by default the system will search for a bootable drive. If no disk is in the rom it will naturally go to the next device; being your hard drive. This is a little assurance in case you can't get into the bios to reset the boot order for some reason one day, it should already be the boot drive. Try to let me know if this doesn't help there's always a few more tricks to try.
Good Luck...
Posted on Sep 24, 2008
  • 22 Answers
Try this :
1. Clear CMOS or JBAT memory by pull off the jumper on the motherboard for 5 minutes and put it back. ( different motherboard have different method to clear cmos, do your research on the net).
2.Check the jumper of you IDE/Sata hard disk and ROM drive. Make sure the jumper is at appropriate location : master/slave/cable select
3. Enter BIOS setting. Default all setting of BIOS. Go to boot sequence setting. Change 1st Boot from : CDROM Drive.. 2nd boot drive : Harddisk.
4. Check harddisk priority boot option (if you're using more than 1 harddisk)
5. Save & exit. Format as normal.
    Genius:
  • 1,124 Answers
After format your computer will not boot if don't have the Sys files on it. Try to put your hard drive back to your computer and start booting with some cd with hard drive utilities like http://www.ultimatebootcd.com/
My operating system was damaged by virus,i need ro reformat my computer..how can i reformat my competer?
Install the XP discs and restart the machine. It should boot from the discs. Then follow the onscreen instructions. You will want to reformat your main drive. (C:)
Apr 04, 2011 | Microsoft Windows XP Home Edition Service...
I just assembly desktop with gigabyte motherboard and ADM CPU, RAM etc...after that i install os Window XP in the 500GB hard drive, the installation done successful, but the problem come out after i done...
This is not a hardware problem, it's a BIOS problem and install problem. Here is my suggestion:
1. Go into the BIOS and set your boot as a) CD-ROM/DVD-ROM
b) Hard Drive
[and it does not matter what is next just as long as the first two are as above.]
2. Reinstall windows os, when ask you want to format drive and install. (This will erase EVERYTHING and reformat the drive space.)
3. When the install is finish, REMOVE the Windows disc and reboot the system.
This should solve your problem. Sometimes if a file was not installed correctly and you leave the install disk in, windows will try to reinstall the files and go from bad to worst.
Good Luck
C2Solutions
Feb 08, 2011 | Computers & Internet
I tried to re-install windows xp to clean my computer (running slow). It aske if I wanted to include web updates and I answer yes. Computer went to a blank screen and no won't load from recovery disc or...
Hi, you will need to reformat your hard drive before installing XP, First boot into BIOS by pressing the F1 key during bootup, change the primary boot drvice to CD rom, save changes. Insert XP cd into drive and reboot PC; select boot from CD when this appears during the initial boot fase. Allow files to be installed. When this finishes, delete partion and then repartion hard drive. Select format hard drive, when this completes your PC will reboot, do not select boot from CD and XP will start to install normally.
Hope this helps, if not come back to me.
Aug 04, 2010 | Computers & Internet
Trying to boot from windows CD and not working
If its the full windows xp cd by booting it from the cd drive it will erase everything and ask if you want to upgrade or advanced install I think. Your correct in choosing the atapi cd-rom as 1st boot device. The cd should be in the drive on startup. IDE is the type of hard disk drive. I'm guessing the FDD stands for floppy disk drive which you might not have that many but you have that many bay windows available.
Put disk in, shut down computer, Start computer and it should give you the xp disk contents. Be aware of data loss though.
Nov 14, 2009 | Microsoft Windows XP Home Edition
Reformatting E-machine desktop computer W3115
Insert the CD to the CD ROM. Set the bios setup to boot using the CD-Rom. Space bar while booting up. If you got the setup press F8, choose NTFS to format the drive. Then go on with the Installation.
Mar 10, 2009 | E-Machines eMachines Desktop PC
NEED WIZ HELP- UNABLE TO BOOT FROM XP OR VISTA FROM DVD DRIVE
first you must check your XP/Vista cd if it is bootable then open the bios setting change the first boot to CD ROM save and exit the bios insert CD wait for a second if the CD is BOOTABLE if so then follow the instructions of formating drive. But before you do that you must be sure that you have all the driver need to you PC for security you must use the black drive then install the XP OS.
Jan 07, 2009 | ASUS A8N-VM CSM (00610839133826)...
Dell D600 CD/DVD boot problem
Looks like you already have Win XP install on ur machine....why you need to boot by using cd? do u want to reformat your pc or upgrade it?
Sep 21, 2008 | Dell Latitude D600 Notebook
Want to erase drive
If your Laptop is purchased with Recovery Disk, you can use that disk to restore the default setting of your laptop. It usually FORMAT your hardisk and erase all programs and files saved on your Hardisk. If Recovery Disk is not available then you can simply use your provided Windows Installer to format your Laptop and install a Fresh Windows on your Laptop, be sure to format the Whole Disk Drive to erase the files.
Jun 11, 2008 | Dell Inspiron™ E1505 PC Notebook
Reformatting
just make sure in bios that your first boot device is cd rom,then install the cd and follow the instruction
May 08, 2008 | Dell Dimension 3000 PC Desktop
Want to downgrade from windows Vista to Windows XP
Hi ginger,
Suggest you back up you're personal data to either a CD/DVD or mem stick.
Windows in general will not allow you to downgrade. It does not matter what version you have. If you put your windows CD in your CD-ROM & boot the Win XP CD you will have to format the hard drive. Only than will windows XP install. Everything on your PC will be erased. If you’re sure this is what you want than put your Win XP CD into your CD-ROM & restart your PC. You should see; to boot to the CD press any key...... (Press the space bar). Win XP should start to load. If windows does not start to load, restart your PC & press the F8 key every two seconds. This should bring up a boot menu, use your up & down arrow keys & highlight the CD-ROM drive than press enter. Windows will begin to install. Choose format when shown on your screen. If you choose to re-install windows you will end up with double folders & that is no fun.
Good Luck!
If I can be of more service, just post back & let me know how thing went.
Mike
Apr 24, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
258 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
