Question about HP LaserJet P2015dn Printer
Unable to print both side though requested
My printout did not print both side of the paper although i have selected the option.
Please advice.
Thank you.
Suzana
  • jbreeds Oct 11, 2008
    Duplex works okay from Windows program such as Word etc. But not on Pagemaker 7 postscript
  • sergeantgrey
    sergeantgrey Oct 14, 2008
    the same. problem with usb-connected printer - it couldn-t print both sides
I managed to find the solution! : )
The postscript print drivers that HP supply with the 2015d printer are NOT suitable for Pagemaker 7.
You need to download a hp Universal Postscript Driver. When printing duplex on Pagermaker 7 adjust 'features' to duplex.
The HP p2015d Duplex printing from Pagemaker 7 now works fine on Duplex and @ 1200dpi.
John
Posted on Oct 23, 2008
  • 3 Answers
As i know, usb-printers don't support both side printing. It is words of the generant
My Canon PIXMA MP145 does not print although there is black ink and no error code. The paper comes out blank when print is selected. Same with photocopy mode.
This problem may be caused by another print cartridge that is empty. This is a ridiculous 'feature' that is apparently common among most printer manufacturers.
If you think this is your problem try the following:
When you select the print option in whatever program you are printing from click on the Preferences button.
-In preferences click the Borderless Printing option, then select Plain Paper as the paper type.
-Next select the Grayscale Printing option.
-Finally click the OK button on the preferences then in the print window click the Print button
NOTE: The above is describing the options for the Pixma IP4700, the terms may be different and there is a chance this will not work on a different cannon printer, (though it is worth noting it definitely worked for mine).
Sep 28, 2013 | Office Equipment & Supplies
Got the C5180 from a relative because it didn't work. I tried a new black ink tank, it doesn't print anything in black. Color print looks weak and washed out without black for shadow, and black...
The printed output is fuzzy, blurry, or grainy, or the edges of objects in the images are jagged. Solution Follow these steps until the issue is resolved. Step one: Check your paper
  • Many papers have printing and non-printing sides. Load the paper with the printing side down.
  • Use the correct paper type for the project. For everyday documents, plain paper works well. For documents with dense printing, such as high-contrast graphics or photographs, use HP Advanced paper for the best results.
  • If these steps do not help, try a different paper. Ink might not bleed as easily on heavier paper. Paper that does not accept ink well is also prone to bleeding and smearing. HP designs its inks and papers to work together.
Step two: Check the settings
  1. In the program being used for printing, click File , and then click Print . The Print window opens.
  2. Make sure the appropriate product is selected, and then click Preferences or Properties . The Preferences/Properties window opens.
  3. Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
    • Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
    • Paper size : Make sure that this option matches the paper loaded in the product.
    To see additional options, click the Advanced tab, and then click Advanced Features . The Advanced Features window opens. Consider changing the following option: Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
Step three: Check image resolution Make sure that the image file has enough resolution for the size of the printed picture. Although many photo applications can enlarge an image or part of an image to any size, eventually the individual pixels become visible and the whole image looks blurry. Here are some general guidelines for image file resolutions:
  • 94 pixels per cm (240 pixels per inch) for images to print on smaller format photo paper, such as 10 x 15 cm (4 x 6 inch)
  • 117 pixels per cm (300 pixels per inch) or higher for larger format photo papers
  • Lower resolutions might produce acceptable images when printed on rough-textured paper
Step four: Align the cartridges If the previous steps have not improved the appearance of the printout, align the cartridges. See the user guide for alignment instructions.
Jul 02, 2011 | Office Equipment & Supplies
My printer prints blurrey out of focus pictures. I download from my camera and print a few on photogaph paper. This happened once before and for reasons that evade me it cleared up and printed fine. ...
Before replacing this awesome printer try this steps first.
First check the paper you're using, load the paper with the printing side down.
Make sure the appropriate printer is selected, and then click Preferences or Properties.
Apr 23, 2011 | HP PhotoSmart C4280 Laser Printer
PRINTING ON PAGE IS VERY FADED AND SOME PARTS NOT PRINTING AT ALL
First, checkthat the USB cable is secure in both the printer and the computer and that theprinter is sitting on a flat surface. The printer may not work if it is tilted.
Next, run a printer check to make sure the printer is operational. To run aprinter check, turn off the printer and the computer and unplug the USB cable.Turn on the printer and press the Maintenance button. Use the down arrow buttonon the printer to highlight More Options on the display screen and press OK.Highlight Nozzle Check and press OK twice. If a page prints out, reinstall theR300 software on your computer.
Lines inPrintout
R300 mayproduce printouts with light horizontal lines that are not a part of theprintout. This is called banding and can have several causes. First, trycleaning the printer head to clear any clogged nozzles. To clean the printerhead on the R300, press the down arrow button to highlight More Options andpress OK. Use the arrow buttons to highlight Head Cleaning and press OK twice.The printer will take about 30 seconds to clean the print head, after which youshould run a printer check as described above. If the printout has gaps, pressthe STOP button to run the print head cleaning feature again. Once there are nogaps in the printout, press OK.
If the printout still has banding, open the Print window on your computer andclick on Properties. In the Properties window you can choose the print quality,speed and printer type. Select a higher print quality and a lower speed andmake sure the paper type matches the type you are using for the printout.
Finally, check that the ink cartridges are not empty or close to empty andreplace them as needed.
Faint Printout
If your printout looksfaint or faded when using the R300, try cleaning the print head. Next, replaceany ink cartridges that are old, low on ink or out of ink. Check that the papersetting on the computer matches the type of paper you are using for theprintout.
Another potential cause of faded printouts is incorrectly loaded paper. Sometypes of paper have a printable side that is whiter or shinier on one sidecompared to the other. The printable side of the paper needs to be loaded intothe printer face up.
Nov 20, 2010 | Epson Stylus Photo R300 InkJet Printer
Why do my pictures look faded with up and down stripes?
Check the paper to make sure you are using the correct paper type for the project. If the paper is too fibrous, the ink applied by the printer might not fully cover the print surface.
  1. In the program being used for printing, click File , and then click Pring . The Print window opens.
    To see additional options, click the The Advanced Features window opens. Consider changing the following option: Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
Press and hold the asterisk (* ) and pound (# ) buttons on the product control panel.
  1. When the control panel reads *******#######, release the asterisk (* ) and pound (# ) buttons.
  2. Press the 3 , 2 , and 9 buttons, in that order.
  3. Press the right arrow button (c00420524.gif ) to select Special Reports , and then press OK .
  4. Press the right arrow button (c00420524.gif ) to select Print Cartridges , and then press OK
Aug 12, 2010 | HP Officejet J5780 All-In-One InkJet...
How do I get all borders to print I am loosing the left side despite changing margins
Its very easy to get the everything print out.
Click Print, you will see option "Print Set up".
Another window will open, in that you will see different options.
Select "Fit to Media" option, click Apply and Click Print
You will get all your borders in printout page.
Cheers
Oct 08, 2009 | HP Officejet Pro K850 InkJet Printer
PRINT IS BLURRY
Step four: Align the cartridges If the previous steps have not improved the appearance of the printout, align the cartridges. See the user guide for alignment instructions. PSC 1600 User guide: http://h10032.www1.hp.com/ctg/Manual/c00276605.pdf Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 11, 2009 | HP PSC 1600 InkJet Printer
Photosmart C6300 pictures are printing very wet and grainy. printer is also very loud - almost as though the parts were scraping and banging.
Sounds like you have the wrong paper setting in your print properties. I would use photo or high bright 24lb paper and set the paper type in your printer properties prior to executing the print job.
Regards,
Worldvet
Nov 12, 2008 | HP Office Equipment & Supplies
HP Laserjet 3330 with Windows Vista
no you cannot print on both sides automatically.you have to give the prints 2 times.at first the paper will print on 1 side then insert the same paper in the printer and give the remaining printout and it will print on the back side of the same paper.as you can do it manually but the automatic printing on both side facility is not in HP Laserjet 3330 printers.
Sep 29, 2008 | HP LaserJet 3330 All-In-One Printer
Problem with printing with HP 1022 laser printer
Hi, Laserjet 1022 printe supports printing through the Laserjet 6L drivers and its tested, please select the same USB port for the Laserjet 1022 printer which is selected for the Laserjet 6L printer and then try printing. Ragards, MukeshS
Aug 18, 2006 | HP LaserJet 1020 Printer
HP LaserJet P2015dn Printer Logo
283 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
