Question about Maxent MX-42VM10 42 in. HD-Ready Plasma Television
Maxent MX-42VM7 42 in. Plasma TV
TV will not turn on when power is connected.  Green power light flashes and then turns to yellow.  The readings on the AC EMI FILTER ARE 123 VOLTS ON THE HOT SIDE AND 63 VOLTS ON THE NEUTRAL SIDE.  THE FUSES ARE GOOD ON THE VOLTAGE BOARD.  COULD THE PROBLEM BE THE EMI FILTER THAT CONNECTS TO AC POWER?
  • mrousey Sep 24, 2008
    Where could I purchase this EMI filter (Yunpen YM15T1)?
SOURCE: Maxent MX-42VM10 42 Remote
Trying to program a universal remote can sometimes be a frustrating process. Successful programming of a universal remote depends on whether the universal remote manufacturer included our company’s information in the remote when it was assembled.
Then a cable company (ie., Comcast) or satellite provider (ie., Dish Network) orders their decoder box and universal remote control from a manufacturer (ie., Scientific Atlanta, Motorola, etc.), the decoder box manufacturer provides a list of all the possible remote controls this universal can duplicate. From that list the cable company or satellite selects which manufacture’s products to include on their new universal remote. Once those manufacturers names have been decided, they are placed on the universal remote and a numeric code is assigned. If they choose not to include our company on the universal remote, the universal remote may not access the Maxent screen.
If you cannot locate Maxent on the list provided to you by the universal remote provider, please try the following:
Through contact with various cable and satellite content providers we have developed a list of the most common numeric codes that are used with universal remotes.
Content Provider/Most commonly used code
Comcast: 1755
Comcast (ML-3251HLT Model): 0054
Insight: 1755
Direct TV: 11755
Dish Network: 742
Cable Vision: 165
Adelphia: 0156, 1755
Universal: 0762
One4All: 0036
Time Warner: 0230
We have identified other manufacturers of display products that have similar remote control information to ours. Depending on the universal remote you are using these manufacturers may work. Please use the documentation that accompanied your universal remote, and look up the following companies. Input the numeric code associate with that company.
Gateway
Sampo
Viewsonic
Magnavox
Phillips
Marantz
Pilot
If the universal remote you are trying to program contains a Code Search (the remote will scan through all the codes contained within the universal remote) function, we recommend that you try that procedure. It is possible that there may be another manufacturer code that may work with our monitor.
You may also want to try a Learning Remote from another manufacturer. This type of remote control can absorb or record the information coming directly out of the Maxent remote control. The learning remote then duplicates that information and acts like the Maxent Remote control. This type of remote can also record the signal coming from your other universal remotes in the same manner. In which case you can use this learning remote for your entire audio video system
Posted on Jun 29, 2008
Tech4lfe
  • 42 Answers
SOURCE: Parts for Maxent 42" Plasma TV
The TV was made by LG. You should be able to google an LG distributor or try ebay. The 953 is readily available but the 917 may be hard to find. Won't be cheap for new ones, around $350-$400 for both unless you can find used.
Posted on Mar 06, 2009
  • 23 Answers
SOURCE: I have a 3 year old Maxent MX-42VM11 plasma tv with no pic/sound
swollen capasitors, replaceing will cost $500, so best to get another one, 42'' samsung will sell for about $800. the pn42a450
once a plasma has a problem, fixing it or not, more problems will occure, trust me, i am the flat pannel guru.
Posted on May 02, 2009
pilot210
  • 39 Answers
SOURCE: Picture problem with Maxent Plasma MX-42HPM20
Very common problem on these sets caused by bad surface mount caps. Check on ebay for a repair kit it's the only place I know where one exists.
Posted on May 18, 2009
roety
  • 585 Answers
SOURCE: Black line on Plasma Tv
Hi my name is Eric,
I hope I can help you with your issue ,
Bad news is you need a new panel. that is the screen itself.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Eric
Posted on Sep 27, 2009
Testimonial: "Thanks for your speedy replies and help. "
Maxent MX-42HPM20 won't turn on
i have the same thing but what i do is unplug the tv and plug again till i hear a click then replug immediately and wait for the tv to come on .this is normally a symptom of a weak surge protector in the back, inside of the tv.it is normally not an expensive repair and better still if the tv is still on gaurantee it should cost nothing.
Nov 21, 2011 | Maxent MX-42HPM20 42 in. Plasma HDTV
I have a 42" Maxent plasma tv. When turned on,
one or your tv mainboard was crashed, change it with new one
Jan 18, 2011 | Maxent MX-42HPM20 42 in. Plasma HDTV
Hello, our TV is not working. It is a Maxent MX-5020. The screen is black and the status led turns green for about 5 seconds and then starts blinking. Thank you for your help
Ur power board is dead.Must know how to solders?Take the tv aparts check power board for capacitors for puff up or burst open must replaced these capacitors.Or replaced the whole power board.Tries Shopjimmy.com,Ebay.com.
Jan 17, 2010 | Maxent MX-50X1 50 in. Plasma Television
May 02, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Feb 23, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
MAxent plasma will not turn on
open the back and reseat the LVDS cable(looks kinda like a computer data cable)...also check your other circuit board connectors..literally unplug the connectors..and reseat them...Question...is the set working now?...or is it not coming on?
Jan 16, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Maxent 50" plasma problem
We seem to have had the same problem. Green light keeps blinking but will not turn set on or off. I unplugged the set for a few minutes, plugged back in and works fine but will happen from time to time for no reason.
Sep 12, 2007 | Maxent MX-50X1 50 in. Plasma Television
Maxent 42' Plasma sound but picture looks like red, green and whites digital specks
the color card in the plasma is not okay.ihad the same problem and fixed it.
Apr 25, 2007 | Maxent MX-42HPM20 42 in. Plasma HDTV
Maxent MX-42VM10 42 in. HD-Ready Plasma Television Logo
Top Maxent Televison & Video Experts
Michael Harrier
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
