Question about Minolta EP1083 CS/PRO Copier
Help please - my Minolta EP 1083 won´t work properly.
I have got a used Minolta EP 1083 . it runs but the copies are gray all over and with lines on it. I have tried to pull out the corona, and clean it, but the problem is the same after cleaning /a little better) but not good. What can I do??
  • 1 more comment
  • Erik Olsen Sep 29, 2008
    Hi jqsababa967
    Thank you for your reply. I did have cleaned the optics and the mirrors. There are still toner on the drum but the cleaning blade seems to work. I do´nt hope I have to get a new opc unit!!!
  • Erik Olsen Sep 30, 2008
    Hi oracle jqsababa967..
    Cleaned all after your instruction - still gray copies!!
    I can´nt understand why the drum - after one copy - has toner on the surface.
    When I try to pull the cleaners in and out nothing happens ... I can only clean the drum properly with
    a cloth..
    Can you recommend a site for buying spare parts...
    hope you can help - best regards
  • Erik Olsen Oct 19, 2008
    Hej jqsababa967. Just to tell you that I bought new cleaning blades and removed the old ones.
    Thanks to your advice everything now works OK - but - a smal white stripe, app. 5mm wide, appear on the middle of the paper and all the way over..... I can´t find the reason why.
    Do you?
  • 145 Answers
Did you try to cleane the optic section ,make sure to remove the lens cover and clean mirror on the right side too underthe len cover,2 remove drum check and c if toner on drum?
Posted on Sep 29, 2008
  • sam gerban
    sam gerban Sep 30, 2008
    try and cleane the cleaning blade and the drum ,and make sure the blade is seated rite,if that helps than change cleaning blade,the other thing you want to do is clean the cel lamp obove the drum in the main body,,,
    hope that helps,if not pm it
  • sam gerban
    sam gerban Oct 04, 2008
    try a company by the name of Precision Roller
Minolta cspro 1083 makes gray copy
has the developer been replaced and the required F8 run along with the drum counter reset. Also was the F5 run and F3 all of these F# are run in service mode.
Nov 13, 2012 | Minolta EP1083 CS/PRO Copier
Date 18th May 2010 Dear Sir What is the
THEY ARE BASICALLY THE SAME MACHINE THE 1085 HAS MORE FEATURES.THOSE MACHINE ARE ABOUT 10 YEARS OLD AND PARTS ARE BECOMING HARD TO GET. I WOULDNOT BUY EITHER.GET A NEW DIGITAL COPIER AND YOU WILL BE ABLE TO PRINT FAX SCAN AND COPY AND PARTS WONT BE AN ISSUE FOR MANY YEARS
May 18, 2010 | Minolta EP1083 CS/PRO Copier
I have a Minolta EP 1083 the copies that it gives smudge
If fuser rollers are getting hot - you either lack pressure between upper and lower rollers Restart; remove/dump old developer - instal correct compatible starter reinstal imaging unit remove toner ctg. key in stop 0 stop 1 tec rep run F-8 mode runs apx. 2 min. exit svc mode If whats not fusing is gritty(starter) - other issues
Jan 19, 2010 | Minolta EP1083 CS/PRO Copier
LOOKING FOR A MANUAL ....MINOLTA EP 1083
get it here:
http://safemanuals.com/user-guide-instructions-owner-manual/KONICA%20MINOLTA/EP1083-_E
*please rate me :)
Mar 24, 2009 | Minolta Office Equipment & Supplies
Minolta ep 1083
why is this still posted?
this was solved
Oct 30, 2008 | Minolta EP1083 CS/PRO Copier
PAPER FEED
you can disconnect the sorter.if that's all you need
Oct 16, 2008 | Minolta EP1083 CS/PRO Copier
MINOLTA COPIER EP 1083 IMAGES TO DARK, NEW TONER, CHANGE PAPER
what is your exposure lamp brigthness condition? checkyour upper high voltage adjustment , check your exposure lamp & bright it & clean your copier lens.thanks.
Oct 05, 2008 | Minolta Office Equipment & Supplies
EP 1083 service /reset codes
Press on keyboard, stop o stop 1. Press 4 to enter counter mode., the first counter should be the pm, displaying a counter with a negative sign. Press cancel key to reset to 0. Exit service mode by pressing panel reset 2 or 3 times and you should be back in business.
Jul 06, 2008 | Office Equipment & Supplies
142 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
