Question about Canonical Ltd. Ubuntu
INetd service stop
I want to know how to stop inetd service since I have to use port 80 for another application.CAn anyone help me with this?
    Novelist:
  • 116 Answers
Open a command prompt.
sudo kill inetd
However inetd may be needed by other applications that you're wanting to run.
Kill command will shut down any application you desire. sudo, of course is to give you root access and will enable you the ability to do anything. It will require the root password as well.
Posted on Sep 25, 2008
Need to unblock a firewall to pick up net flix wireless on my new visio tv how do you do this. it was something like a 80 443 code
80 and 443 are the port numbers,
80 is the default for internet
443 is the default for Secure Socket Layer Internet
There will be an option in your firewall settings of the router
You should be able to forward the exact ports you need to allow them to work
Don't however open all ports as this will leave your computer open to attack
You can assign a pre defined application to by pass the firewewall
You probably need to create a new application, call it "Visio TV" for eg and enter ports 80 and 443 and save it
Apr 05, 2011 | D-Link DIR-625 (790069292637) Wireless...
Tip
Vmware enable SSH
If you want to do advanced features in VMware ESXi you will need to go into the core of ESXi to do this you can use Secure Shell or SSH. SSH is simplar to telnet but the data is encypted.
To enable SSH on VMware ESXi you need to enter an the ‘unsupported’ mode.
Step 1. At the physical console of the ESXi server press the Alt+F1 key combination.
Step 2. Type ‘unsupported’ and then press <Enter>. Note that nothing will appear on the screen whilst you type.
Step 3. When prompted enter in the ‘Root’ password and press <Enter>.
Step 4. You will now be presented with a prompt on the console. From this prompt type the following command
vi /etc/inetd.conf
Step 5. vi (the file editor) has now opened the inetd.conf file. Using the direction arrows scroll through the lines until you reach the line that has ‘#ssh’ and remove the hash (ie: #). This is effectively un-commenting this line so that the ssh service can be started.
Step 6. Now that you have made this minor file you want to save this change and exit out of the editor (vi). To do this press the ESC key (to put vi back into Command Mode) and then type ‘:wq’ *Note: If you want to exit without saving any changes to the file then just press the ESC key (Command Mode) and then type ‘:q!’.
Step 7. With the SSH service now un-commented from this file we need to restart out ESXi box to do this type in Reboot.
on Mar 31, 2010 | Computers & Internet
I am trying to open the router ports to allow a ps3 to connect. when i try to play call of duty:modern warfare 2, i keep losing the connection. can you help me open the ports and configure the settings?
Some times you will need to open the Logical Ports on the router.
These are the logical ports.
For this you will need to open the set up interface of the router.
Once you open the set up interface of the router, you will be able to find the settings on the router where you can open the ports for the particular program.
If you are opening the ports for a special device in your network, then you must know the IP address of that device.
For example, wireless camera, DVR, X-box, Play station ...
You can choose the option PORT FORWARDING for a special device application.
If you just want to open the ports for all the network, then you can choose PORT TRIGGERING
For example ,
You have a Linksys wireless router and you want to open the ports for the X-box.
You have opened the set up interface of the router. You will see Application and Gaming TAB at the top.
If you click on that tab you will find different Sub tabs.
Click on Port Triggering => Here you can open the port numbers for the network.
Click On Port forwarding if you want to open the ports for a special device in the network.
Click Save settings once you open the ports on the router.
Some of the recommended port numbers for different applications :
IMAP ==> 143 SMTP : 25
HTTPS ==> 443 HTTP : 80
DNS ==> 53 FTP : 21
SNMP ==> 161 TELNET : 23
XBOX ==> 53, 80-88, 3074
PS3 ==> 80, 443-447 ,5223, 3478-3479, 3658, 10070-10080.
WII ==> 28910, 29900, 29901, 29920, 80, 443
VPN ==> 1723, 500, 443-447, 10000-20000
World of Wars ==> 3724, 6112, 6881 - 6999
Click Here for more info
Dec 13, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
HOW TO DO THE PORTFORWARD
For example ,
DNS ==> 53 FTP : 21
Dec 06, 2009 | Belkin F5D8631-4 Router (F5D8631au4A)
Port Forwarding on NB7Plus4W router
For example ,
DNS ==> 53 FTP : 21
Nov 22, 2009 | NetComm NB5PLUS4W Wireless Router
I have a zyxel p600 series modem connected to a Belkin wireless router. I am trying to run a web server on port 80. The modem was using port 80 for access to the internal settings. I changed that to...
Your setup looks correct to me. It might very well be that your ISP is blocking port 80. Go here and check from your server if port 80 is accessible.
If you are the only one that wants to connect to you server, you can simply choose another port to use, i.e. www.myserver.com:801. Set port forwarding form port 80 to 801 in your router.
TCP&UDP - from 801 - to 80 - [serverIP] - [Webserver]
The better way is to use a service like DynDNS.com or No-IP.com. You can register a DNS name (like myserver.dyn.com), which redirects to your public IP. The trick is to update your IP address, so even if you have a dynamic IP assigned from your ISP, the redirect will point always to your server. Most routers have the ability to set up with DynDNS, so the process runs in the background and you don't have to update manually - check your router manual.
The second part of this beauty is the redirect to a different port. So even if your port 80 (and 25 for that matter) are blocked, you don't have to have an arbitrary number in your URL (http;//myserver.com:801). You can find more detailed information here.
For a quick check, change your webserver to run on port 801, enter the redirect in your router and see if you can get to your server from the outside (internet). If you still can't access the webserver, the problem is not a blocked port.
Hope this helps, but if you have any more questions, just come back here and leave a comment - I'm happy to help you figuring this out.
Oct 23, 2009 | Computers & Internet
I need to do port forwarding
You need to access the router setup screen if you want to do port forwarding on the router. also you need to check the IP address of the unit, or device you want to forward as well as the port service.
in accessing the router setup screen;
> open IE, on the address bar type 192.168.1.1 - username is blank and password is admin in lowercase.
> go to applications and gaming
> look for port range forwarding, input the name- any name will do
> the service port for example it is only one port service to open and that is port 80 and then you should have to put there 80 to 80 then check if tcp/udp protocol as well, check the IP address of the computer and then enable.
> to check the IP address of the computer go to start> run > cmd and hit okay > then type ipconfig check the IP address after.
hope
Jul 11, 2009 | Computers & Internet
Gears of war for pc connecting to windows live
To open TCP ports use these steps below:::
To create an application profile for 4.x and higher:
  1. Open a Web browser and access the gateway user interface by entering http://gateway.2wire.net
  2. Click the Firewall tab -> Firewall Settings link -> Edit Firewall Settings page.
  3. Click Add a new user-defined application in the Application panel to open the Edit Application page.
  4. Enter an application profile name in the Application Name field. It is recommended that you use the name of the application (for example, GEars of War).
  5. Create your application definition in the Definition panel. A definition consists of a series of protocol-specific ports that are to be allowed through the firewall. You can find this information in the documentation provided by your the company that produces the application.
  6. Select the TCP or UDP button in the Protocol field. If the application you are adding requires both protocols, you must create a separate definition for each.
  7. Enter the port or port range the application uses in the Port (or Range) field. For example, some applications require only one port to be opened (such as TCP port 500); others require that all TCP ports from 600 to 1000 be opened.
  8. Optionally, enter a timeout value in the Protocol Timeout (seconds) field for the amount of time that can pass before the application “times out.” The default values are 86,400 seconds for the TCP protocol, 600 seconds for the UDP protocol.
  9. Enter a value in the Map to Host Port field that maps the port range you established in the above step to the local computer. For example, if you set the value to 4000 and the range being opened is 100 to 108, the forwarded data to the first value in the range will be sent to 4000. Subsequent ports will be mapped accordingly; 101 will be sent to 4001, 102 will be sent to 4002, and so forth.
  10. Select the application type from the Application Type drop-down list. If you do not know the application type, select None (Default).
  11. Click Add Definition to the profile definition list.
  12. Click Done.
  13. Repeat steps 1 through 12 for each port or range of ports required for the application profile.
If you need more help:: access this link
http://support.2wire.com/?page=view&article=21
Cheers
Jun 10, 2008 | 2wire 2700HG-B Router (2700HGB)
Everytime i log on the message A websever is already running on port 80 for best results please stop the sever and restart the application!! have do i stop this!!!
Can you supply the operating system you have loaded?
e.g. MS XP, Vista, 2000, other.....
What program are you using for "message"?
From the sound of it, a program is already using port 80. The solution will depend on if you need both programs running at the same time or if the programs can be configured to use a different port.
waiting responce.....
May 07, 2008 | Computers & Internet
Web Server Crashes on port 80.
A couple of questions for you...
1) What do you mean by 'crash'? How do you know its crashed?
2) Can you look in the Windows Event Viewer to see if there are any warning/error messages in the Application or System logs around the time of the starting or crashing of your web site on port 80? If so, anything that suggests the issue. If you don't understand the errors, try posting some of them here.
3) Is there any other web server running on port 80? If your running Internet Information Server, open the Internet Information Server Manager (mmc) console and click on "Web Sites" and it should list all the sites in the right pane. If you have anything 'running' on port 80, it will conflict.
4) Are you running Apache or any other web server on the system? If so, you're going to need to look at those configurations as well.
5) How about any other applications that might have a built in web server?
Let me know.
Jan 14, 2008 | Computers & Internet
Canonical Ltd. Ubuntu Logo
96 people viewed this question
Top Canonical Ltd. Computers & Internet Experts
Dennis Gutowski
Dennis Gutowski
Jaipal Reddy
Jaipal Reddy
Are you a Canonical Ltd. Computer and Internet Expert? Answer questions, earn points and help others
