Question about Maytag PYE2300AY Electric Dryer
Timer problem I am looking for a picture of the back of the timer motor that show where all of the wires go on model number pye3200ayw serial number 10194516wh?
  • 33 Answers
Found on MAYTAG
Wiring diagrams:
data on the whole thing:
7 diagrams
Posted on Sep 24, 2008
Where can I get a wiring diagram for a cold spot model 106.59597993. I need to replace the defrost timer and the new one has a different set up than the old one. The neutral side of the timer motor ha
The part number for that timer should be 482493. I'll venture to say that the black wire is throwing you off. Look at the timer, the pins to be exact, and notice how they are numbered. The black wire slides over pin 3. Once that is done cycle the timer slightly by turning the grey wheel looking thing in the middle. The reason is because the timer comes set in the defrost position and sometimes if not advanced they never come out of it. After this plug it in where the old timer was and plug it in. The machine should kick on and you'll be good to go.
May 15, 2012 | Refrigerators
Clock does not rotate
If clock does not rotate, then check if outlet has power. Check for loose wires.
If clock rotated before and stopped working, then clock motor might have gone bad.
Replacement clock: Taco timer uses the FM1 timer module.
Voltage and timer information appear on back of timer.
Open following links to identify timer and model number:
For example Taco timer module is 24 hour, and 120Volts, and doesn't have battery back-up.
-If timer has on-off-timer switch, then model number is FM1STUZH-120U
-If timer does not have on-off-timer switch, then model number is FM1STUZ-120U
More resources:
Sep 17, 2011 | Taco 265-1 / 563-2 Combination Analog 24...
Tork timer "time clock motor"kaput...someone set
You posted under Tork 8601 timer:
I don't think that clock motor is sold separately.
New timer costs 115 at Chapman:
120Volt Tork clock motor that fits some models is sold at frontier for $43:,Photo.Cells...Time.Controls,Replacement.Motors
Usually the clock motor is held with 2 screws and then wires attach to screw terminals.
Look close at your screw terminals to see clock wires.
Normally timer mechanism snaps out of box and clock motor is on back of mechanism.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 25, 2011 | TORK Variable Cycling Timer 8601
1) First suggestion is for you to add a comment and say what model number Intermatic timer you are working with.
If this is a box timer, then model number shows on inside of door.
In any case, we are guessing at your problem without knowing model number.
2) If this is a box-type timer, main thing folks do wrong is reverse the line and load wires.
Line wires come from the breaker box, and Load wires go to the fan, light, motor.
Line wires have to be connected to the clock terminals or the dial will not rotate.
The clock terminals are usually visible as small white wires connect to two of the terminals. Again, this is dependent on model number.
Jan 23, 2011 | Microwave Ovens
Lost instruction manual. How do I progam my Paragon Electric timer Model EC7004/120
Link below has Paragon EC7000 series timers and manuals
EC7004/120 is 7-day programmable timer.
Single channel 120Volt SPST NEMA1 indoor timer.
Program up to 16 events per week
EC7000 series programming manual shows wiring, explains keypad, has steps for setting current time, and shows 24 steps for programming timer. Plus troubleshooting.
It is impractical to write out those steps when they appear in manual.
EC7000 series Sell sheet with model numbers
Description of model numbers at Uni-line
Dec 01, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
Need manual to set timer
You posted under T-100 series outdoor timer
If you have different timer, add a comment with timer model number located inside cover.
T-104, T-103, T-101 timer manuals show on following page:
If your timer has R suffix, like T-101R, that means box is Raintight for outdoor use.
T-101R and T-101 mechanisms are identical except for box. T-101 box is indoor use.
Click model number and drop-down menu reveals link to manual
If you need simple wiring diagrams, and explanation for each T-104, T-103, T-101 timer:
Here's how to set Intermatic T100 series timers:
Lift and rotate yellow dial until current time lines up with silver pointer.
Silver pointer is stationary at 6 o'clock position.
Put ON-OFF trippers on dial at times you want ON OFF functions.
Minimum on-off is 1 hour because of tripper width.
If timer is not working, add a comment and we'll troubleshoot.
These timers have replacement trippers and clock motors at Grainger
How timer works:
Clock motor, located on back of mechanism, rotates yellow dial.
Trippers on dial push lever that turns power ON and OFF.
Off tripper pushes lever one direction.
ON tripper pushes lever opposite direction.
When lever is pushed, manual override lever clicks back and forth with audible click sound.
Nov 29, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
The Maytag washer is 26 years old. The problem is
Sounds like the timer motor may be dead. Can you hear it ticking when it is on or can you see the gear on the timer motor shaft turning when it is running? If not then the timer should be replaced.
Jan 16, 2010 | Washing Machines
Kenmore Electric Dryer Model 110.6972110 timer motor NG
maybe call a generic appiance store other than sears, try maytag store. the knob pulls staight off and the timer nut is below. then take off the back cover off the control panel, sometimes those screws are on the front corners, sometimes hidden. take a picture of the timer wiring and tape and label all the wires before you remove it. unplug it first!!
Nov 29, 2009 | Kenmore 62602 Electric Dryer
Gets stuck in cycle I have to turn the knob to get it to continue. The machine is the heavy duty large capacity I can't find a model #
Looks like you need a timer. If the model number is really gone there should be a part number n the timer. look everywhere around the door/lid and even on the back. Eric
Aug 12, 2009 | Washing Machines
Maytag 2 speed replacement motor
you may have wrong part , post model serial , and part number that you have i will look them up
Nov 29, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag PYE2300AY Electric Dryer Logo
327 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
