Question about Dyson DC07 All Floors Bagless Upright Cyclonic Vacuum
No suction I cleaned and checked all hoses, sounds like something is stuck inside, like a sock, took machine apart as much as I could and couldn't find anything. Any suggestions?
  • 372 Answers
Ok first thing to do is remove & clean the 2 piece premotor filter or purchase new.
Now remove soleplate from bottom of machine to do this rotate the 3 plastic screws to unlock position. Lift sole plate off now remove any blockagers or fluff that may be built up over the brush roller.
Remove hair from brush roll using scissors.
Check short clear hose for blockages & any damage rips or tares if it is damaged purchase new hose.
Now look at belts & rotate brush roller it should turn relatively easy if it is difficult to turn by hand remove the brush roller & pull off the end caps the axle will come out with one of the caps.
Check the roller bearings clean away dust build up replace end caps & axle spin roller holding on to end cap if freely to spin refit back on to machine.
If its stiff to rotate you will need new roller.
Now pull off the 2 inspection ports check them for bits of paper etc especialy the (U) shaped port at bottom rear of machine this can contain pens pencills stones all sorts of items that hinder the suction.
Now check the long flexi hose & metal wand for any obstructions.
If after all this machine is still not working correctly go to this site http://dysonmanuals.llc.nu/
On this site you will find Dyson service manuals covering poor suction, clutch,motor, etc.
Chris...
Posted on Sep 26, 2008
My dyson animal sounds like something is stuck and flapping in the hose,filter, etc. I have taken it apart and I can not find anything. Have you had anyone else experience this issue?
try changing the filter. could be it is coming apart and making the noise. Also sometime these hoses will tear on the inside (lining of hose) and make a flapping or knocking sound. Check the hose as well.
Dec 06, 2016 | Dyson Dc50 Animal Bagless Upright Vacuum -...
We have a30yr old electroux that has been loosing vaccum. i took it apart and found a black foam rubber althrough the cannister and on top. i guessu i8ng that foam has something to do with the vaccum.
The foam may be a sound suppressor. Your vacuum may need a new hose. Old hoses have a liner on the inside that can collapse. Try removing the hose and see if you have good suction on the vacuum without the hose on. If you do it. Means the hose is bad or clogged
Mar 27, 2014 | Electrolux Vacuums
Little suction
Most vacuums have an air intake adjustment. If this intake is opened,the suction is affected. It is on the hose usually and is a simple procedure to turn it to closed. If yours is an upright, there may be something lodged in the machine that keeps the air from flowing as it should. And of course, the bag or filter needs to be cleaned, emptied or replaced (depends on the type of vacuum) to assure good suction. Oh, also if you have a hose type vacuum, there might be something lodged in the hose. I usually take a mop or broom handle, remove the hose from the machine, and plunge the handle into both ends of the hose to dislodge the stuck item.
Nov 14, 2010 | Hoover Vacuums
Suction
hello tnwalkergal the hose may have a clog inside the hose at the bend you can take the hose loose and run a broomstick or a yardstick thorgh the hose this is how I find the clog
Jan 24, 2009 | Dirt Devil M086700 Vision Bagless Upright...
Kenmore Progressive Direct Drive Upright - noise and bad suction
Had the same problem tonight. Took the entire thing apart only to find there was a much simpler solution. Check the small hose that runs from the brush rollers where the longer hose (on the back) attaches to the side of the vacuum. Easiest way to do this is to lay the handle down and stick something (coat hanger worked good) through it until it comes out of the head. I found a pretty good sized fuzz plug in mine. As soon as I removed it, everything worked great again - and no noise!
Mar 15, 2008 | Kenmore 31912 Progressive Direct Drive...
Bissell Healthy Home
1. Make sure the hose attachment is pushed all the way down into its receptacle. It will click softly when it's all the way down.
2. Detach the hose from the machine. Do this by twisting the grey fitting on the back of the machine. (Note: leave the attachment end of the hose plugged into the machine) Turn the machine on. Hold your hand over the hose fitting. If there's strong suction then there is a blockage in the hose.
3. If not, check in the fitting to see if something is stuck in there. On the back of the machine there is a long clear tube that travels down the back of the machine. Sometimes larger peices of paper get stuck in there. If something is in this tube, take a phillips screwdrive, remove the 7 black screws off and remove the blockage. Reassemble and try the machine.
4. There are two filters on this machine. The one that may be clogged and affecting the suction is located below the canister in the front of the machine. Simply pull ouot the tray and reomve the grey foam filter to clean. Rinse it out with warm water then allow it to dry. Replace in its tray then slide the tray back into the machine. The other filter is the HEPA filter and has nothing to do with the suction of the unit. It is an exhaust filter and does need to be changed at least once a year. It filters the air coming out of the machine. The first few times we used ours the whole house smelled "clean". Whne a new filter is placed in the machine that "clean" snmell returns. The filters are $25 apiece at Amazon.com.
5. As a maintainence item, remove the canister as though you were going to empty it. Place it on the ground, locate the two buttons (one clear plastic/one blue) on the front and back of the canister and remove the clear plasctic housing. This will allow you to clean the hundreds of little holes on the grey surface of the top of this section. (This looks like a circular colender.) To clean this, use an old toothbrush and scrub the dust and stuff into your grabage can. I do this once or twice a year. (Since I have a Shop Vac in the garage, I use this instead of a toothbrush.)
Hope this helps.
Dec 19, 2007 | Vacuums
Red stopper suction keeps popping up
There is a splash sock around that valve. When the air is drawn through the sock, it sets up too much turbulence and this causes the valve to lift and block the opening. Remove the sock and it will solve your problem. The first series of these machines had a 7 amp motor that didn't develop enough suction to affect the valve, but later models were 12 amp and there was too much air flow for the splash sock, so they were removed. The later production models incorporated a screen over the motor opening in the tank which substituted for the sock.
Oct 21, 2007 | Hoover F5886-900 Steam Vacuum
Eureka Enviro Vac Model 4470 Not Sucking
First, check to see if there is suction without the hose on the base. If not, and there is no blockage, the problem is likely a damaged impeller, the small fan that makes the suction. That will have to be replaced.
May 21, 2007 | Eureka Smartvac 4870 Bagged Upright Vacuum
No suction
Hmmm...I have the same problem...if you remove the water tank and the water collection bucket and look at what is remaining. Now step on the lever to lean the upright part back and there is a hose there that goes from the hand held hose into this hose into the dirty water tank. MINE is broken at that center point between the handheld hose and the dirty water square thingy...It's probably fixable...maybe this helps you?
Nov 05, 2006 | Hoover F7431-900 SteamVac Vacuum
Dyson DC07 All Floors Bagless Upright Cyclonic Vacuum Logo
184 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Roger Potts
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
