Question about Polaroid TTM-2401 TV
Electrical Arching in back of tv
My 1.5 yr old polaroid ttm 2401 is arching in the back from the component that is connected to the vacuum tube from the tv tube. How can I get a replacement component part?
    Problem Solver:
Can a substandard wiring connection produce electrical arching?
Posted on Aug 12, 2009
  • 525 Answers
Check the connection of the ground. Bad connection of ground usually create this problem.
Especially the ground connection between the crt board and the wire who surround the picture tube. Let me know what you will get after this.
Posted on Sep 24, 2008
One night our screen just blacked out. I could
From your description it sounds like you TV is experiencing a shut down and re-set condition. This is usually caused by some type of voltage irregularity in the power supply section of the TV. Unfortunately, this is not an easy fix and will require a trip to the shop. Get an estimate before approving repair. In the new world of disposable electronics the cost of repair may exceed the value of the set.
Aug 28, 2009 | Polaroid TTM-2401 TV
Can a substandard electrical wiring installation at home produce electrical arching?
Yes it can. It can burn the house down if not corrected. That's why, there are laws controlling the installations.
The National Electric Code.
Aug 12, 2009 | Polaroid TTM-2401 TV
Does model Polaroid TTM-2401 TV have a built in digital tuner?
You TV does not have a built in digital tuner, so is not HD compatible.
Jan 08, 2009 | Polaroid TTM-2401 TV
Does the model Polaroid TTM-2401 TV have a digital tuner?
Your TV will need a HD converter because it doesn't have a digital tuner but only if you are receiving over the air signals. If you have a cable box or satellite receiver, then you do not need the converter HD box.
Click here for more info on the TV specs.
Polaroid ttm-2401
To me, sounds like a picture tube issue. horizontal / vertical controls don't fix it. then its dead.
Jun 22, 2008 | Polaroid TTM-2401 TV
Picture turns green!
The CRT (picture tube) is failing. This is classic in these TV sets, and including many models of the Sony.
There is a short occuring in the electron gun. The CRT would not be feasible to replace even if it was available!
Jerry G.
Apr 12, 2008 | Polaroid TTM-2401 TV
Power will not come on
EEEEEEEEh check the power supply, from your power cord , fuse, rectifier bridge diode, whith out forget that the old TV got the bad connection in old solder!!!!
Dec 26, 2007 | Polaroid TTM-2401 TV
Chuy
The power supply is going in to protection. There is a short somewhere.
Since you sound like you are able to service the set, remove the CRT socket and see if the set starts up and has high voltage. If so, the CRT may have a short in the electron-gun, or it is being over-biased from the CRT board.
I don't know the particular model design of your set. In the models that I do know, I have had components on the CRT board go defective and cause over-biasing of the CRT and cause a shutdown on startup.
Sometimes the components on the CRT board fail because the CRT is at fault, and it is arching some very high voltage back out to the devices on the CRT board. In this case, they will soon fail again.
If the above does not work, then it is possible that the flyback transformer has some shorted turns, or there is a failure in the HV multiplier.
Other things that can cause a shut down is if there is any components in any of the areas of the set that are causing too much current pull from the supply.
These sets can become very involved and a challange for the most experienced of techs to service.
Jerry G.
Nov 17, 2007 | Polaroid TTM-2401 TV
Polaroid TTM-2401 TV Logo
138 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
