Question about ViewSonic VG150 15" LCD Monitor
Resolution on my vg150 squeezed on Mac
When I updated my Mac from 10.4.10 to 10.4.11 for Final Cut Studio 6, my 150 monitor will now only come up as 1280x768, which is rather distorted.
It seems to be a driver problem. If I downgrade the computer to 10.4.0 then the 1024x768 standard resolution becomes available.  Any incremental upgrade, erases this and all other resolutions leaving me with 1280x768.
The wild thing is that it seems to be an OS level problem as the same things happens on my Due 1 G G4 and a dual 2G G5.  Any thoughts?
tribedigital@mail.com
  • 12 Answers
SOURCE: Unable to have 1280x768 full screen with DVI cable
Use the menu button on the monitor itself to adjust for the screen size in DVI mode.
On your SVGA adapter, go to your display properties (right click on desktop) click ADVANCED and change the refresh rate to fix the first problem mentioned.
Posted on Oct 15, 2007
SOURCE: Monitor won't display resolution properly after Windows Update
I was having the same problem. Believe it or not I fixed it by unplugging the monitor, and when I restarted my PC I again had the 1440 × 900 option.
Regards,
Jeff
Posted on Dec 08, 2007
map9966
  • 2351 Answers
SOURCE: the screen resolution
Your going to love this. Open control panel, open display. Click the settings tab. Click Advanced. Click the Monitor tab. Remove the check mark from "hide modes". Click the drop down menu & set it to 75 hertz. Click Apply & than ok. You are now back to the Settings window. At Screen resolution move the slide bar to more. Pick what you want. Again click Apply & than ok. Bingo there you are! Have a nice day.
please vote...
Posted on Feb 05, 2008
pravinbhavsa
  • 348 Answers
SOURCE: Hi i have big problem with my ViewSonic VX2235wm monitor
check did you insert external display card or using internal if not inserted then internal display card will not support above 600x800 if you want to work with high resolution then insert AGP card and reinstall drivers there are 4 type cards 1x,2x,4xand 8x you use 8x AGP card then select high resolution also you can look best movie and good support to 3D games
Posted on Nov 23, 2008
Big Poppa Ma
  • 302 Answers
SOURCE: Resolution
Have you tried updating your graphics card? Go to ATI's website and try updating your video card and hopefully that solves your problem. Go to amd.com and go to ATI tab to update your driver. I forgot ATI is under AMD's umbrella
Posted on Dec 06, 2008
Need serial number for Final Cut Studio
Contact software manufacturer or distributor and they will assist you, otherwise the code will be provided with the software that was provided at purchase.
Apr 21, 2013 | Apple MA888Z/A Upgrade Final Cut Studio to...
Tip
Best Mac MXF File Converter-Import/Edit Canon MXF Files to ProRes 422 MOV to FCP...
MXF file format comes from like Panasonic HVX200/HPX300, Canon XF300/XF305, Sony EX camera, etc. It is not compatible with many programs just like Apple Final Cut Pro. So Convert MXF file to FCP MOV Video is a necessary step to do if you want watch your video from your camcorder which export mxf file.
And we know that Apple ProRes 422 , Apple ProRes 4444,introduced in Final Cut Studio, was advertised to one of the codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro.
Below is the step-by-step guide for you to quickly Convert/Edit MXF to Apple ProRes 422 (*.mov) Final Cut Pro on Final Cut Studio,Final Cut Pro 7 on Mac.
Step 1. Add MXF videos to Aunsoft MXF Video Converter for Mac.
Connect your MXF Camcorder to iMac with USB 2.0 cable or use card reader to transfer the .mxf files to Apple hard drive disk. Run Aunsoft Video Converter for Mac as the best Mac MXF to FCP Apple ProRes Converter . and click the "Add" button to load .mxf videos.
Step 2. Choose Apple ProRes codec for Final Cut Pro.
Click the "Format" option, choose the Final Cut Pro > Apple ProRes 422 (*.mov) and navigate to the Final Cut Pro group, you will notice that there are profiles with Apple ProRes 422, Apple ProRes 422(HQ), Apple ProRes 422(LT), Apple ProRes 422(Proxy), Apple ProRes 4444. Here we choose Apple ProRes 422(HQ) (*.mov) as output format. (The Apple ProRes 422 (Proxy) codec is intended for offline editing and contains 30 percent of the data rate of Apple ProRes 422, and I recommend you to select Apple ProRes 422(HQ), Apple ProRes 422(LT) MOV for outputting.)
Step 3. Merge Canon MXF files. (Optional)
Tick the checkbox for "Merge into one file", and the Mac MXF Video Converter will join and combine the video clips into a single file as output.
Step 4. Convert MXF to Apple ProRes MOV for Final Cut.
Click the convert button under the preview window, the Mac MXF Video converter starts converting MXF videos to Apple ProRes MOV, and joining the MXF files for editing in Final Cut Studio.
After Converting and Merging the MXF files, just import the output Apple PreRes 422 .mov files to Final Cut Pro 7 or Final Cut Pro 6 for editing and the video .Optimize your workflow and save time with the Apple ProRes compression for Final Cut Pro. You can also import the output videos to Final Cut Express (FCE) 4 for editing in full HD.
on Jul 13, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
Join various MTS files-Import and Convert different AVCHD MTS files to ProRes...
Join/Convert Panasonic/Canon/Sony/JVC various MTS to ProRes for FCP without rendering <br />Edit all MTS Videos on FCP-Merge/Convert HD Camcorder MTS files to FCP ProRes on Mac <br /><br />As the reason of recent activities, I have a lot of <b>different .mts Videos for Editing</b>. These .mts video most are from camera, camcorder, like Sony CX700, XR520,Sony Nex-5, Canon HF G10, HG20,HF100,Panasonic HDC-TM90,SD700,Lumix GH2.etc.Some .mts videos can be directly into FCP editing, some not. So in order to <b>Edit all MTS Videos on FCP</b>, I need a converter to <b>Import and Convert various MTS</b>. But separating each video conversion is a lot of trouble, so I will need to <b>merge those mts videos into one and convert</b>. Through Google search, I found Aunsoft Final Mate for Mac is the recommended <b><a href="http://www.aunsoft.com/final-mate-mac/">MTS Joiner/Converter</a></b>- can <b>join and convert mts to FCP for editing on Mac</b>. Then I download and try it. And I had successfully <b>converted a total of 15.8G mts files to MOV and edit on FCP</b>, I choose the Apple ProRes MOV as output format, so that I can <b>import prores mov to fcp without rendering</b>. <br /><br />Following is the experience of using Final Mate for Mac to <b><a href="http://prores-converter.com/2011/06/joinconvert-panasoniccanonsonyjvc-various-mts-to-prores-for-fcp-without-rendering/">Merge and Convert Panasonic/Canon/Sony/JVC various AVCHD MTS files to ProRes 422 for editing on FCP</a></b>. <br /><br />Step 1 : Import various mts Files from Computer to <b>Final Mate for Mac</b>. <br />Click "Add" to browse computer and select a folder where video files are saved, then click "OK" to display all video files including various MTS files in Resource Tab. <br /><br />Step 2. Create a Movie for <b>Combining/Converting AVCHD MTS files</b>. <br />Soon after the mts files are imported, you need to create a movie for conversion. There are two ways for you to create a Movie for <b>converting imported various MTS files</b>. <br /><br />- The easiest one is dragging and dropping displayed various MTS files from Resource Tab to a single Movie. <br /><br />- Another way is clicking the drop-down button of "Add Movie" icon and choose "For Conversion" to create a blank movie. And then drag and drop the video clips from Resource Tab to the blank movie in Movies Tab. In this way, all video clips will be merged as one single movie for conversion. <br /> <br />Step 3. <b>Export ProRes video file for Final Cut Studio</b>. <br />Click the Export and choose Final Cut Pro &gt; Apple ProRes 422 HQ (*.mov) to output format for editing in Final Cut Pro. <b>Apple ProRes 422 , Apple ProRes 4444</b>,introduced in Final Cut Studio, was advertised to one of the codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro. <br /><br /><b>Tips:</b> You are free to set/adjust output ProRes MOV files parameters (Bit rate - high quality, Frame rate - 30, Resolution/Size - 1920 x 1080, channel - 5.1 channel) to make a good output quality. <br /> <br />Step 4. Click OK to start <b>Joining and Converting different AVCHD MTS to ProRes</b>. <br />Click OK button, the software will automatic <b><a href="http://www.aunsoft.com/final-mate-mac/">Join and Convert the various mts files into one big files</a></b>. <br /><br />When the conversion is finished, you can get big files for <b>importing and editing on Final Cut Pro without rendering</b>. <br /><br /><b>Tips:</b> If you are using Final Cut Pro 5 or lower version, ProRes is not the best format for you. However, you can choose QuickTime Movie Format &gt; Apple InterMediate Codec(AIC) as output format for editing on Mac.
on Jun 21, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Can't find serial number for Final Cut Studio
Call Apple. 1-800-APL-CARE and ask to speak with "Pro-Apps".
Final Cut Studio Install disc Scratched
I think your out of luck from a legitimate standpoint. If you wanted to go the pirate route you could download a copy from the Web. You would need three items. 1) you would download a Torrent client and install. 2) You would need a torrent file. 3) You would Google the following words "Final Cut Pro or Final Cut Studio 2." Once you have your Google results then you would click on a link and DL your torrent file. Use the torrent client to open your torrent file and start DL'ing.
Aug 03, 2009 | Packard Bell ixtreme 9222 (P491000102) PC...
Tip
Convert Sony HDR-XR550V AVCHD to Apple ProRes for FCP with AVCHD to Prores...
Sony Handycam HDR-XR550V records your memories and snap 12.1-megapixel photos directly to the massive 240GB hard disk drive (HDD). The shooting quality of the HDR-XR550V is impressive and naturally lives up to its flagship status and price. In line with Blu-ray formats in the market, recording is supported up to 24Mbps. High definition videos are recorded at 1920 x 1080 resolutions primarily to the in-built HDD. Picture quality was sharp and crisp, a result which was equally pleasing when viewing on a HD monitor or TV. <br /><br />Many people say Sony HDR-XR550V is the best hard drive camcorder from Sony at the moment and its excellent performance has won hearts of many customers. A lot of our customers use Sony HDR-XR550V for recording family videos, such as holiday vacation at east coast beach, your children?s birthday party or your pet?s playing video. In most cases, they want to do some basic editing and make great home movies to preserve their memories with highest quality. <br /><br />For windows users, it might be not such a problem as bundled software from Sony Picture Motion Browser is capable of basic editing and output videos to BD/DVD or upload to YouTube. But <b>How do you edit AVCHD on Mac OS X</b>? <br /><br />Final Cut Pro 6.0.1 update adds AVCHD transfer capabilities but is everything ok now? <br /><br />Apple's own Final Cut Studio 2 suite had a minor update for Final Cut Pro to version 6.0.1 which added the capability to transfer the AVCHD footage. But is everything really so promising for Mac users? I guess not. We?ve been receiving complaints and problems from our customers about their frustrating experience with AVCHD on final cut pro 6 or 7. <br /><br />Is there a simple and useful tool for Mac users to handle AVCHD for smooth editing in FCP without rendering? <br /><br />Aunsoft Studio nearly released product on Mac OSX <b><a href="http://www.aunsoft.com/final-mate-mac/">Aunsoft Final Mate for Mac</a></b> is specifically designed for camcorder users to easy <b><a href="http://www.aunsoft.com/final-mate-mac/">handle, convert, share, playback AVCHD, TOD & MOD</a></b> high definition videos. <br /><br />In the article, I will take Sony HDR-XR550V as an example to show how to convert AVCHD MTS/M2TS video footage to Apple ProRes for smooth editing in Final Cut Pro 6 & 7. <br /><br />1. Capture/Import Sony XR550V AVCHD files to Aunsoft Final Mate for Mac. <br />There are two ways to import videos to Aunsoft Final Mate for Mac: you can directly capture video recordings from camcorder to the program or you can browser videos from your computer. <br /><br />- Capture Sony XR550V AVCHD videos from camcorder. <br />Connect camcorder to computer via USB cable, and then launch Aunsoft Final Mate for Mac in Application folder. With built-in wizard, you can easily to capture mts video files from XR550V to the program. Select ?Import? instead of Backup to quickly capture videos from camcorder. You can find imported videos under Camcorder tab in the main interface of Final Mate. <br /> <br />- Import Sony XR550V mts videos from computer. <br />If you have already backup all your video recordings from XR550V to your computer, you can browse your video path and the software will automatically show your AVCHD clips in Resource tab. <br /><br />2. Merge Sony DSC-XR550V AVCHD files into one movie for conversion. <br />Click the drop-down button of ?Add Movie? icon and choose ?For Conversion? to create a blank movie. <br /><br />Once you?ve imported your video footage, drag and drop the video clips from Camcorder Tab (imported from your camcorder) or Resource Tab (imported from your computer) to the blank movie in Movies Tab. In this way, all video clips will be merged as one single movie for conversion. <br /><br />3. <b><a href="http://www.aunsoft.com/sony_hdr-xr550v_review_-_convert_avchd_to_apple_prores_for_editing_in_fcp/">Convert Sony XR550V MTS files to ProRes MOV</a></b>. <br />Click the Export button and choose ?Export into Editor?. Follow Final Cut Pro&gt; Apple ProRes 422 HQ (*.mov) to choose export format for further editing in Final Cut Pro. Or you can also choose QuickTime Movie Format &gt; Apple Intermediate Codec (*.mov) for editing in FCE/iMovie. Click OK to start converting XR550V MTS files to ProRes MOV. <br /><br />When the conversion process is done, you can directly import the output ProRes MOV files to FCP for editing without rendering and make your great home movies. <br /><br />The steps above are also applied to other AVCHD camcorders developed by Sony, Panasonic, Canon or JVC brands. <br /><br />Featured product from Aunsoft Studio Aunsoft Final Mate for Mac is the ideal companion for camcorder users who also use Mac machine to easy <b><a href="http://www.aunsoft.com/final-mate-mac/">convert AVCHD to Apple ProRes</a></b> Codec. <br /><br />Tip: You may also be interested in converting <b><a href="http://www.aunsoft.com/mac_convert_sony_hdr-tg5v_avchd_to_apple_intermediate_codec-aic_for_fce-imovie/">AVCHD to Apple Intermediate Codec</a></b> for editing in iMovie or Final Cut Express or <b><a href="http://www.aunsoft.com/mac_merge-join_sony_cx360v_avchd_without_conversion_for_playback_on_dune_hd_player/">merge AVCHD without re-encoding</a></b> to preserve original quality.
on Jun 15, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
Mac Canon DSLR Video Converter-Transcode Canon EOS 5D H.264 MOV to iMovie on Mac
Converting Canon 5D Mark II Videos to iMovie 8/9 on Mac with Best Quality <br /><br /><b>Mac DSLR Video Converter</b> functions as the <b>Mac Canon DSLR video converter</b>, Mac Sony DSLR video converter, Mac Panasonic DSLR video converter, Mac Nikon DSLR video converter, Mac Kodak video converter, Mac Flip video converter and even Mac iPhone 4 video converter for your Apple computer with PowerPC or Intel CPU. <br /><br /><b>Mac DSLR Video Converter</b> enables you to <b>import H.264 MOV videos from Digital SLR cameras</b> to editing software like iMovie 8/9/11,Final Cut Express,Final Cut Pro,Final Cut Studio,Adobe Premiere Pro,Avid etc. <br /><br /><b>Mac DSLR Video Converter</b> helps you organize DSLR recordings from camcorders like Sony VG10, Canon 600D in AVCHD MTS/M2TS, MOV formats, and <b>convert MTS/M2TS and H.264 MOV to Mac</b> editable format. <br /><br />Below is the quick guide for you to <b><a href="http://www.aunsoft.com/video-converter-mac/">convert Canon 5D Mark II videos to iMovie</a></b> with Aunsoft Video Converter for Mac OS X like Snow Leopard, Leopard and Tiger. <br /><br />Step 1. Import Canon DSLR MOV to Aunsoft Video Converter for Mac. <br />After the movie clips are transferred to Apple computer hard drive, run Aunsoft Video Converter for Mac as the best <b><a href="http://canon-videoconverter.com/2011/06/mac-canon-dslr-video-converter-transcodingconverting-canon-eos-5d-mark-ii-h-264-mov-to-imovie-on-mac/">Mac Canon DSLR Video converter</a></b>. Click the "Add" button to browse the Canon DSLR .mov files for conversion. <br /><br />Step 2. Choose QuickTime MOV format. <br />Click the "Format" option and navigate the mouse cursor to Common Video &gt; MOV - QuickTime(*.mov) as output format. The Mac DSLR movie converter will <b><a href="http://www.aunsoft.com/video-converter-mac/">transcode Canon H.264 videos to iMovie</a></b> supported videos with original resolution in 1920x1080. <br /><br />To change video frame rate, just click the "Settings" button and choose the frame rate option. <br /><br />Step 3. Convert Canon DSLR EOS MOV for iMovie. <br />Click the convert button under the preview window, and the Mac Canon DSLR movie converter will start <b><a href="http://www.aunsoft.com/video-converter-mac/">converting Canon H.264 MOV to QuickTime MOV</a></b> for editing in iMovie with high quality. <br /><br />After the conversion, just import the output videos to iMovie 8, iMovie 9 or even iMovie 11 for creating your own movies.
on Jun 08, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Hooking up speakers to MacPro
goto straight to the aja card if its final cut pro compatable and upto date.   Look for studio monitors, a good brand for instance yamaha hs80m 8inches that have built in amp other wise you'll need an amp generally for studio monitors.
Jan 25, 2009 | Computers & Internet
Tip
Convert TM900 1080/60p and 1080/50p AVCHD MTS footage to ProRes 422 for Editing...
Edit TM900 1080p 28Mbps AVCHD MTS to ProRes 422 in FCP
The HDC-TM900 High Definition Camcorder is a HD offering from Panasonic.While you record 2D videos in 1080/60p (1080/50p for PAL model) at 28Mbps with Panasonic HDC-TM900 .If you would like to put the AVCHD videos from TM900 to Final Cut Studio for editing, a third party software shall be needed to handle the 1080/60p and 1080/50p footage to ProRes 422 for FCP 6/7. Aunsoft Video Converter for Mac is the recommended Panasonic TM900 AVCHD to ProRes converter for high quality video editing on Mac with less compressed Apple ProRes format.
Here is the step-by-step guide for you to Convert,import and edit Panasonic HDC-TM900 MTS to Apple PreRes 422 MOV to Final Cut Pro/FCP7 without rendering on iMac/MacBook Pro with Mac OS X like Snow Leopard.
Step 1. Load Panasonic HDC-TM900 videos to Aunsoft Video Converter for Mac.
Run Aunsoft Video Converter for Mac as the best MTS video to ProRes converter on Mac, click the "Add" button and you can browse the TM900 28Mbps videos for conversion.
Step 2. Choose Apple ProRes for Final Cut Pro.
Click the "Format" option, and navigate the mouse cursor to Final Cut Pro > Apple ProRes 422 (*.mov) as output format. The video to ProRes 422 converter will transcode Panasonic HDC-TM900 1080p AVCHD to Final Cut Pro native format.
Step 3. Choose 1080p size with 60 or 50fps.
Click the "Settings" button and choose 1920*1080 from the video size drop-down box to keep the original HD resolution. Click the drop-down box for frame rate, and choose 60fps or 50fps as output video frame rate. The frame rate option depends on your source videos in NTSC or PAL model. Click the OK button to save the changes and the Mac AVCHD video converter will convert 1080p AVCHD videos to 1080p ProRes 422 Mac FCP compatible native format.
Step 4. Convert 28Mbps MTS to Apple ProRes for FCP.
Click the convert button under the preview window, the conversion from Panasonic TM900 AVCHD to ProRes 422 MOV Final Cut Pro Native Format will start immediately.
After converting and merging the Panasonic HDC-TM900 AVCHD files, just import the output Apple PreRes 422 .mov files to Final Cut Pro 7 or Final Cut Pro 6 for editing and the video is in HD 1920×1080.Optimize your workflow and save time with the Apple ProRes compression for Final Cut Pro.
on Jun 06, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
How to Export Movie from Final Cut Pro (FCP) to FLV? After editing your own...
After editing your own movies on Final Cut Pro or Final Cut Express, you may want to put them on your website for presenting your introduction or promoting your services/products. For users with the older version of FCP, FCE or iMovie, it is easy to export FLV by choosing File > Export > Using QuickTime Conversion. However, if you could not find Flash FLV as output format from FCP/FCE/iMovie, you may need a FCP to FLV converter to get Flash videos.
Aunsoft Video Converter for Mac is the best FCP to FLV converter for you to handle videos on iMac/MacBook Pro with Snow Leopard or Leopard. The Mac FCP to FLV converter supports loading .3gp, .m4v, .avi, .dv, .flc, .mp4 videos from FCP/FCE/iMovie and converts FCP movies to FLV as short film. Below are the steps to export Final Cut Pro movie to FLV with Aunsoft Video Converter for Mac.
Step 1. Load Final Cut Pro movies to Aunsoft Video Converter for Mac.
After exporting movies from Final Cut Pro, run Aunsoft Video Converter for Mac as the Mac FCP to FLV converter, and click the "Add" button to load FCP short films for conversion.
Step 2. Choose FLV output format.
Click the "Format" option and choose Flash Video > FLV-Flash Video Format(*.flv) as output format. This format is compatible to most machines.
Step 3. Transcode FCP movies to FLV.
Click the "Convert" button under the preview window, and the Mac FCP to FLV converter starts converting Final Cut Pro movies to FLV for playing on webpage.
Tips:
1. After converting Final Cut Pro movies to FLV, you need Flash players to navigate the video playback on webpage. You can use free web players like JW player, Moyea PlayBox player and Flow player to present your short films on website.
2. You can set the video resolution of the FLV videos by clicking the "Settings" before conversion.
3. The above step-by-step guide with Aunsoft Video Converter for Mac also works for the movies exported from Final Cut Express and iMovie. In other words, you can also convert FCE movies to FLV, iMovie videos to FLV on Mac OS X.
on Jul 22, 2010 | Cell Phones
ViewSonic VG150 15" LCD Monitor Logo
47 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
