Question about Casio Parts Cash Register PC Desktop
CASIO 130CR How do i switch the receipt to off on REG mode as receipt comes out on all transactions made, as long as i can press Z at end of day to get total. thx
  • 171 Answers
Without Clerk Function codes 4000 = receipt; 4100 = journal
With Clerk Function codes 4002 = receipt; 4102 = journal
Posted on Sep 24, 2008
Getting error in E004 for Casio TE-2200 reg how do I get out and running
Try this:
Turn key to PGM (program) mode
Turn power off at the wall socket
Hold down RECEIPT FEED button (keep your finger on it)
Turn power back on and wait 5 seconds before taking your finger off of the receipt feed button (the paper may feed out. This is normal).
The LLLLLLLLLL part of the display should change to FFFFFFFFFF.
Press SUBTOTAL once and wait for the printer to issue a receipt.
Turn key back to REG mode and try it. You may need to sign on using a clerk button or a clerk code if you use one.
Sep 22, 2015 | Retail Supplies
How do i print receipts to see my changes
Press POST RCPT button after a transaction
Aug 01, 2014 | Casio PCR-T2000 Cash Register
Can you print a receipt from the previous business day?
Only if it hasn't "batched" yet.
You can press the "Reprint" button (second from right purple button) to reprint the last receipt. You can also print any receipt that hasn't batched yet (normally from the current business day) by entering the receipt number. You can guess the number if you don't know it. Number 1 is the first transaction of the day, number 2 is the next one, etc.
If for some reason your transactions from the previous business day didn't get sent as a batch to the processor successfully, you would be able to print receipts for them. Otherwise, contact your processing company, and they should be able to send you a copy of the receipt.
Jun 19, 2014 | VeriFone VX510
Error e001
E001 error is the generic Wrong Mode error message on the Casio tills.
It simply means that a transaction was started in one mode without being finished before the key was turned to a different.
Return the key to the mode you were in before, complete the transaction then try turning the key.
If you keep getting the error turn the X and press SBTL.
Thanks,
Shopstuff
May 19, 2014 | Casio Parts Cash Register PC Desktop
How do I print a journal receipt only?
1 turn your key to the position between REG and Off
2 Press rcpt button once
3 turn back to REG
Jul 16, 2013 | Sharp XE-A404 PC Desktop
E004 Error INIT/FC
You need to finish the flag clear.
Turn key to PROGRAM mode. Turn power off at wall. Hold RECEIPT FEED down - keep your finger on it. Turn power on at wall. Wait 5 seconds, then let go of RECEIPT FEED. You should see "FFFFFFFFFF" on display. Press SUBTOTAL. Wait for print out. Turn back to REG mode (you may need to sign back on)
Feb 28, 2011 | Casio Parts Cash Register PC Desktop
We just got a new xe-a102, we do not need to print receipts...how do you turn off that function?
To disable receipt printing:
  • Press the Rcpt/PO key in the OP X/Z position. This key toggles the receipt printing status ON andOFF.
  • To check the receipt printing status, turn the mode switch to the OP X/Z position or press the CL key in the REG mode.
  • When the function is in the OFF mode, the receipt off indicator “_” illuminates.
To issue a receipt when receipt ON/OFF function is set to OFF:
If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function in the OFF
mode, press the RCPT/PO key. This will produce a receipt. If more than 50 items were entered, the receipt will be
issued in a summary receipt format. Your register can also print a copy receipt when the receipt ON/OFF
function is in the “ON” status.
Oct 27, 2009 | Sharp XE-A404 PC Desktop
How do i get it to stop printing customer receipts
The following is the process to stop customer receipt printing. It will also describe how to print an individual receipt on demand. Best of luck and thank you for using Fixya! Kindly return to rate this solution.
Greg
Receipt ON/OFF function
You can disable receipt printing in the REG mode to save paper using the receipt ON/OFF function. To disable
receipt printing, press the Rkey in the OP X/Z position. This key toggles the receipt printing status ON and
OFF.
To check the receipt printing status, turn the mode switch to the OP X/Z position or press the lkey in the REG
mode. When the function is in the OFF mode, the receipt off indicator “_” illuminates.
The register will print reports regardless of the receipt state, so the paper roll must be installed.
"To issue a receipt when receipt ON/OFF function is set to OFF:
mode, press the Rkey. This will produce a receipt. If more than 50 items were entered, the receipt will be
function is in the “ON” status."
Sep 24, 2009 | Sharp XE-A404 PC Desktop
Change on/off receipt function to off
The following is the method to turn the receipt printing on/off:
OFF.
All the best!
Greg
Aug 01, 2009 | Sharp XE-A404 PC Desktop
Receipt not printing
I believe this might help, not exactly familiar with this exact model but here it goes.
When you use the printer to issue receipts, you can disable receipt printing in the REG mode to save paper
using the receipt ON/OFF function. To disable receipt printing, press the Rkey in the OP X/Z position. This
key toggles the receipt printing status ON and OFF.
If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function being OFF
status, press the Rkey. This will produce a receipt. However, if more than 30 items were entered, the
receipt will be issued in a summary receipt.
Copy receipt
You can print a copy receipt by pressing the Rkey when the receipt ON/OFF function is in the “ON” status.
To realize this function, you must enable the function. Please refer to page 62 (Job code 63).
Nov 11, 2008 | Sharp XE-A404 PC Desktop
Casio Parts Cash Register PC Desktop Logo
193 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
tomferryman
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
