Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
Hp pavilion dv2000 no lcd dispaly
When i turn on my hp pavilion dv2000 from sleep black screen appear no display i turn it off when i press the power on there is 1 beep & 2 short beep what is the problem
  • lola8344 Jan 14, 2009
    i think there might have been a surge, my hp dv 2000 power button is blinking on and off, i was able to turn on the computer by holding the power button for a minute now it doesnt even want to turn on, i have to turn it on via remote control, once i get it to start the screen is in a shadow, you can see the web page contents but trough a dark screen like if it is in sleep mode. plus i have to apply pressure to the side of the screen to make he screen fully appear so i can send this note, if i let go of the screen it will go back to the shadow or completly shut off, i called hp n they want me to shell out $380 is there a less expensive way to fix my comp? ive only used it for 6 months and bought it 1 year ago. could changing battery help?
    Genius:
  • 1,124 Answers
Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information
This issue can be caused by any of the below situations.
  1. New hardware conflicting with old hardware.
  2. Bad or failing hardware device.
  3. Connections not connected or connected properly.
  4. Recent electrical storm that caused a surge that damaged computer.
  5. Other hardware issue.
Posted on Sep 24, 2008
Will not start up
hi , Reuben
I would suggest you try safe mode.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words "Safe Mode" appear in the corners of the display to identify which Windows mode you are using. If an existing problem does not reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes.
If you don't know the cause of the problem, you can use the process of elimination to help you find the problem. Try starting all of the programs you commonly use, including the programs in your Startup folder, one by one, to see if a program might be the cause of the problem.
Follow the steps to boot the computer in safe mode with networking:
1. Restart your computer if it is powered on.
2. Tap the F8 key after your computer initially powers on.
3. Once you see the Advanced Boot Options menu you can stop tapping.
4. Use the up/down arrow keys to highlight your selection.
5. Select Safe Mode with Networking and press Enter.
6. You should see drivers loading, and then please wait.
7. You should then be at the Welcome Screen.
8. Logon to your computer using an account with Administrator privileges.
May 27, 2015 | Computers & Internet
How to hard reset a WM8880 laptop
Power the unit off (holding power buttom) and selecting Power off, then simultaneously hold the "back" button and on button for about 8 seconds. When the android icon appears, press back buttom, in the menu select wipe data/factory reset pressing the home buttom and then press the back buttom, in the next screen select "yes delete all user data" pressing back buttom, and in the next screen select "reboot system now" with the back buttom and wait.
Nov 29, 2014 | Computers & Internet
How do i turn off the HDD
What happens when entering the sleep mode is the drives will be turned off and the present state will be kept in memory until awakened. While the system is active the power scheme will prevent the drives from idling down after so many minutes with the never turn off setting applied.
With the turn off drives after the default 20minutes of inactivity that doesn't mean all drives turn off at the exact same time. I've never come across any reference for changing the power plan option for individual drives. But I can point you at the guide for the power plan settings with one instruction on drive settings to apply prior to entering the sleep mode.
hope that helps if not let someone here know.
Oct 03, 2014 | Computers & Internet
Why doesn't my HP 4620 print black ink
Either the BLACK INK CARTRIDGE is out of ink of it's possible the ink jets (they eject the ink onto the paper) are clogged/dirty. Your software under HP in PROGRAMS from the START MENU should provide a 'cleaning' cycle. How to Clean Print Heads is a link to help you with how.
How to Really Clean an Inkjet Printer in 5 Simple Steps Printerhacks
Good Luck
PC Doctors - Dallas
Jul 08, 2014 | Computers & Internet
Repeated Paper jams HP photosmart All in one C4200
you can try these steps presented on the HP support page. Paper Jam Message Displays on the All in One. I hope this helps
Jun 15, 2014 | Computers & Internet
HP vp17 screen is turned blue How to get back the colours?
I recommend you check the signal cable plug (from the monitor) is fully inserted into the PC.
Jun 10, 2014 | Computers & Internet
Screeen is upside down
If you have a Windows OS, press and hold the ALT and CTRL (control) keys and then press the Up arrow. (If that doesn't work, try holding the Alt and CTRL keys and pressing the left (or right) arrow key twice.) If that fails, right click on the desktop (Windows+D will minimize all programs), anywhere with no running programs or icons. Then select the Screen Resolution option. Look for the line Orientation; use the drop down menu to select the correct orientation. Click Apply and then confirm the setting change if a confirmation window pops up. (This works in Windows 7 and 8.) For older Windows versions on laptops, you may need to select Graphics Properties (or a similar line) and then repeat this. The Windows screen rotation option is dependent on your video card. With some models, you'll need to open the graphics card properties to undo the rotation. You should see a line for the graphics adapter when you right click on the Display.
For Macintosh OS, make sure that the System Preferences is closed. Then open it by pressing Option/alt + CMD . Select the line Display. Find the button labeled Rotation: Standard then choose the correct screen orientation.
I hope this helps.
Jun 01, 2014 | Computers & Internet
How do i reset my computer to an earlier date?
Most computers have a RTC or "real time clock" in the BIOS. BIOS (or "Basic Input Output System") controls how data gets into and out from the processor (via keyboard, disk, etc.). Be careful making changes. The BIOS is normally only accessable when the computer is powered on or reset, and then only while performing the POST (or "Power On Self Test"). At this time your screen may display text describing memory, drives, controllers, etc. Some machine have a "silent boot" enabled which displays a manufacturer's graphic or logo instead of this data. It is during this time the the BIOS may be accessed. Depending on the manufacturer of your computer, a key (Delete, Escape, F1 or some other) or key combination (ALT + F1, ALT + S, or some other) will be needed. It is required to press the key or key combination prior to the Operating System loading message(s). This can be done be repeatedly pressing the key (or key combination) once every second (or two) during the POST. Holding the key(s) down the entire time - or pressing them too often will result in an error, and require starting over again.
Once the BIOS screen is presented, you will have to scroll the entire page(s) to find the clock. Most BIOS brands have more than just a single page of settings. Using the the up, down, left, right, PgUp, PgDn & Enter keys - navigate to the clock hours and minutes and adjust as needed. Make sure that you SAVE changes before exiting the BIOS screen. Upon exit, the computer will reboot with your settings.
Your Operating System may also provide a way for you to change the system time (and date) as well. Try clicking on the time / date to see if it will bring up a dialog box that allows you to make the change.
I hope this helps and good luck! If my answer was helpful, please rate it "4 thumbs up" Thanks!
Jul 27, 2011 | Computers & Internet
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
478 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
