Question about Radio Communications
Regency R1070 scanner Fr Err
I tried to change a frequency and now it wont scann any more. It stops on Fr Err. Can anyone tell me how to get rid of this code or reset it?
Thanks
    Problem Solver:
  • 11 Answers
If an out of band frequency is put in that channel you will get the Fr Err message as well, just put in a frequency within the scanners specs
Posted on Apr 20, 2009
Supported ranges are:
30-50 Mhz
144-174
440-512
You can reset the memory by hitting Search and Scan simultaneously (or unplugging it)
Posted on Nov 03, 2009
  • judij6 Jan 12, 2011
    THANK YOU IT WORKED!!!!
  • 90 Answers
This is a very old unit & it's getting tired. This problem is generally caused by a component failure in the frequency synthesizer circuit & will not be cost-effective to repair. Time to invest in a new scanner. Sorry.
Posted on Sep 26, 2008
Whenever i put in a frequency to my scanner it always says fr err i need help
You are entering frequencies in the wrong format or in the wrong band.
Jun 28, 2016 | Radio Communications
Where can I buy an antenna for a Regency model R1070 scanner
search ebay for "regency r1070 scanner antenna" and many will pop up. Also Radio shack..
Jul 09, 2012 | Uniden Radio Communications
How do you program a Regency Programmable Scanner R1070?
Regency R1070 Frequencies for people with no manual
These are the ranges it supports.
30-50 Mhz
144-174 Mhz
440-512 Mhz
To make it scan, first set the range by pressing Manual and then Search. It will ask for the LOwer end and the UPper end of the range. Enter them, press Scan and then Search, and it will start scanning. When it locks and you want to keep going, hit Search again. You can press Delay to stop at a channel temporarily. To save a frequency in memory, hit Manual and pick a number, then type it out and hit Enter. When you have a few channels saved and you want to check up on each of them, Scan scans through memory. The Lock button is to skip a particular channel while scanning.
That's pretty much the whole manual right there.
Jan 30, 2012 | Radio Communications
I have a Regency Touch K 100 ( NO MANUEL ) Scanner
I have searched like crazy and cannot get you a specific answer. I found the Manual for sale on eBay in PDF format.
http://cgi.ebay.com/Regency-Touch-K100-Scanner-Manual-PDF-File_W0QQitemZ150385008548QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2303a51fa4
For $5 it might be worth it.
For all of your scanner needs: ScannerMaster
Nov 17, 2009 | Radio Shack Radio Communications
Need schematic for Regency z30 police scanner
Make sure you lock the memory switrch in back to on this should slove your problem Good Luck
Sep 28, 2009 | Radio Communications
Regency scanner r1070 error message fr err, will not scan
i have same problem with my scanner what my prob was is moisture got into the radio and it sat for while and corosion ate one of the pins of a crystal causing it to have fr err on any channel i put it on replacing the crystal fixed it for me but with scanners anything could be wrong
Jul 18, 2009 | Radio Communications
Regency 1099 Scanner
Fr Err usually means that the freq entered into a certain channel is too high or too low for the band of the scanner. Also could mean that the freq's have been lost out of the memory. Maybe a dead memory battery, or been unhooked from the wall too long and lost it's charge. Been a loong time since I've seen one of those models,,, Let me know if it helps,,, Mechanic
Nov 04, 2008 | Radio Communications
How to program an old regency 1060 scanner
I'm not too sure about this particular model, but other Regency variations require you to push the "Manual" button, enter the channel number you want to set (usually 01-09 for single digits) and then enter the frequency you want. On some you may need to enter the frequency first and then the channel number.
Oct 11, 2008 | Uniden BC72XLT Handheld Scanner
FINDING FREQUENCIES
87ff97c.jpgNo it can't sorry. If you want to scan things all the way up to the 900 MHz frequency you should get a Regency Touch K500. Its not a portable scanner however. It may be a little hard to find because Regency went out of business a while back, but look on e-Bay you'll find it there.
Jun 28, 2008 | Uniden BC72XLT Handheld Scanner
Programming
Most Regency Scanners have the same basic programming setup.
Try the following.
Press "Manual"
One of the channels will show up in the display, probably channel 1.
Enter the frequency you want to enter, example 162.550
Press "Enter"
The channel number will flash,
Enter the channel number you want to put that frequency in, example to put that frequency into channel 4 enter the number 4.
Note that on some models for channels 1-9 you must enter the channel as a 2 digit number so enter 04 for channel 4.
You can repeat this process to enter all the frequecy's you want and just change the channel number.
Also check out
http://www.w7fg.com/index.html
for scanner and old radio manuals.
from WikiAnswers
good luck
-voodoomox
Dec 06, 2007 | HP PSC 1410v All-in-One Printer
Radio Communications Logo
817 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
