Question about Toshiba Satellite P205D-S7479 Notebook
"A" Key on the keyboard sticks from time to time.
At times, the "A" key does not work. I need to push it a couple of times for it to work. It has happened since I first bought it. It is very noticeable when playing online games that involve the "A" Key.
  • claireanne Oct 02, 2008
    HI
    I have the same problem with my S. Did you find a solution? I think the keys are removable and I probably need to take it off and clean beneath it but I don't know how to do that.
    Claire
  • 33 Answers
My first thought is to press the manufacturers warranty. If that is gone then the next thing I would do is to replace the keypad. If you search Ebay for the keyboard for this laptop you will find a replacement. Prices I found are in the $57-100 range, but a good internet search is worth the savings.
How to replace Laptop Keyboard
First off, DON'T FORCE ANYTHING
The replacement procedure for the keyboard as with most laptops is not too painful:
1. The strip of plastic just above the keyboard, pry it up with something plastic that the laptop is not
scratched.
2. There should be 2-4 small screws holding the top of the keypad down, remove these and you
should be able to gently lift toward the screen and up. Look for any other fasteners that may be
holding it down.
3. There should be a ribbon cable going from the keypad to the main board with a pinch connector.
Some connectors have end tabs that lift up or slide out to release the cable.
4. Replace with working keyboard reversing the procedure.
Any issues please post back
Posted on Sep 24, 2008
Sup man you should pop the button of da lap top then push on hard
Acts like the keys are sticking have to push buttons several times
Cheap keyboards are not built to last. If you want a long lasting keyboard get a good mechanical one. They may cost a little more up front but you wont need to replace it for a long time.
Mechanical Keyboards for Clicking Tactile Typing Feel
Oct 08, 2014 | Computers & Internet
My keyboard only works when it wants to, i thought it was a virus but my laptop is now virus free and my keyboard still does not work properly, sometimes does not work at all sometime the number two holds...
If you have a sticky key that you know of you may have a couple that you haven't noticed. The number 2 key sticking usually means something was spilled on it at one time.If nothing is spilled you will only see the keys at the sides act up and usually the longer or larger ones. These act up from not hitting them straight but at an angle.
The next time it does this try thumping the keyboard to jar stuck keys loose. The key may look ok but is stuck just enough to do this. You just need to flick a finger at the keyboard to knock them loose. You may have to do this a few times before it dislodges the offender. On a normal keyboard you flip it over and knock on the back like knocking on a door to do this. On a laptop you can't hit it as hard.
If the keyboard keeps doing this your option is to replace it. Depending on the make and model a new laptop keyboard is about $45-$75 and is installed in a few minutes.
Sep 02, 2011 | MSI Computers & Internet
The shift key on the keyboard worked half the time for a while and now it won't work at all
Try the following:
1. Press the shift key several times and check if it changes anything. This is to make sure the inner part of the key isn't sticking onto the connector.
2. Press other keys as well, like Ctrl and Caps Lock.
3. Is the other shift key working? If it is, it is most likely that the other one is faulty. If it's the case, you need to buy one from ebay.
Try to search on ebay and see if you can find just that single key, some sellers are selling just the key for a much cheaper price. If you can't find one that's selling single keys then am afraid you should buy yourself a keyboard replacement.
Hope this helps.,
May 06, 2011 | Sony VAIO VGP-WKB1 Keyboard
Keys Sticking
no! you don't want to do that if you unscrew the back plate all the plastic suction cups with fall off and you will never be able to type on it, until you place the suction cups back what you want to do is get some WD-40 (the tool for fixing almost everything) or a can of pressurized air with a areosole top and aim it at the key or under it, press it and it will blow every piece of junk under the keys cleaning it.
Feb 09, 2010 | Logitech Wireless Access Duo Optical...
Trouble with keyboard/space bar sticking and few keys. how to solve
I would take a butter knife and pop off the keyboard, clean it out, make sure the two metal objects are aligned and pop it back in.
Thanks,
Brandonmxb
Dec 11, 2009 | Acer Aspire 3610 Notebook
Some key are sticking cant type that good as normal, key are sometime hard to push , blow it ot with that stuff in a can
If they are still sticking after blowing the keyboard out you may have spill some form of liquid on it that is causing your problems.
If you are pretty adept you could carefully remove all the key caps and clean it out a little better.
If not you may want to consider taking it to a local repair shop.
Again if you are confident enough then laptop keyboards are not that expensive to replace (probably cheaper than a repair) It is usually a pretty simple task that would take anyone with some common sense about 15 -30 minutes to do.
In the mean time you could always buy a cheap USB or PS2 keyboard and use that (check which type you need)
If this information was useful please click below
Aug 18, 2009 | Compaq Keyboard
Keyboard spacebar sticking
Just solved it, after a bit of tinkering...
the prongs of the floating plastic frame need to sit inside the clips of the spacebar key, you can't just clip it back on with the prongs either up or down. It's fiddly, you need a paperclip or thin screwdriver to do it, but it's stopped the sticking problem.
Oct 25, 2008 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
I cant get the keyboard letters to work that have the blue numbers on them without pushing the fn blue button in the bottom row at the same time
that is how the function keys on some keyboards work. Other keyboards have a key that says Fmode. When this is pressed then the blue keys will work all the time. Other than that the Fn key needs to be pressed at the same time as the function key you are using.
Oct 20, 2008 | Acer Computers & Internet
Keyboard not responding
Solution. My wireles keyboard stopped working except for the F-Lock key, the Media key and the sleep key. It wasn't batteries, even though I tried, communication was there because the above keys were working. Remove the batteries from your keyboard and let it sit for about 10 minutes. Press the red connect button a few times and other various keys every few minutes during that time. This may be the whole "capacitor discharge" trick, but I tired that with someone elses instructions and my keyboard did not work after 2 minutes of key pressing. I think it just needed more time to clear out the secure settings. Good luck, I was about to trash this keyboard until I tried again
Nov 26, 2007 | Elite Logitech Media Keyboard(KB9675590403
Toshiba Satellite P205D-S7479 Notebook Logo
77 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
