Question about Cameras
I have a great looking Contaflex IV; however, the last owner removed the entire lens housing (not just the small interchangeable lens) and couldn't get it back together. Neither can I. As far as I can see, the camera and the lens housing are both in good condition, but I can't seem to reunite them. How can I do it, or must I resort to a camera repair shop? -- Lee Probst
  • 1,952 Answers
Click this link i think more then problem solved
else ya resort to a camera atharity tecnicianto repair shop
Posted on Sep 24, 2008
  • 97 Answers
I feel its better to get it to a camera repair shop, to avoid damage to ur hardware.
Looking for the manual for the DP Air Geometer Exercise Bike
i couldn't find the exact manual, but this should be able to help since a lot of the parts are interchangeable. so i really hope that I've helped you in some way. enjoy your day/night
Aug 19, 2011 | Health & Beauty
I'm not sure how to explain this, but I think the glass of the lens of the digicam is gone. Like in the lens, there's usually a really small hole, then a glass that protects it, right? When I got...
If the lens element is missing there's no way to repair or replace it without having that exact same lens to take apart for the missing piece. It's easier and faster to look for a refurbished lens online and just swap it out. Don't know your camera model so I can't help with pricing. Hope this helps!
Thomas Drayton
Owner, www Darntoothysam com Digital Camera Repair
Jul 21, 2011 | Cameras
How do you remove the kodak p880 lens?
You don't. It's a fixed lens and is not interchangeable.
The camera just looks rather like an interchangeable lens SLR camera
Jun 01, 2011 | Kodak Cameras
I purchased a used Zeiss Ikon contaflex camera and I can't figure out how to open it and load the film!! Help
Well, on my Contaflex, the two tabs on the bottom must be rotated 180 degrees so you can slide the back off
Dec 02, 2009 | Photography
2000 ford windstar how to install front blinker bulb
The entire headlamp housing assembly sits inside of a mounting bracket - this means it is very easy to fully release, and remove the headlamp to make bulb replacement much less *painful*!
There are 2 headlight retainer clips to find - they are:
1. black, upside-down L-shaped metal clips about 1/2 inch wide
2. located just behind the top edge of the headlamp glass, inside the engine compartment. (Do not confuse these with the two small lens clips)
Release by pulling the top towards you while pulling the clips upward. The headlamp assembly will now pull forward providing great access to the electrical connector and bulb retainer ring.
Oct 29, 2009 | 2000 Ford Windstar
Replace/clean headlight lens - 1998 Buick Century
At my shop we have a product from Ever-Wear, it is a headlight restoration kit, do it on the car and works great. Did one light on my car and left the other one foggy as a demo. Great Product
Nov 16, 2008 | 1998 Buick Century
Lens error: camara has broken gears in lens assembly
Hi kevin3738 and a_nester
ok for kevin3738,
im thinking that since you said your lens doesn't extend all the way out that maybe you might have cracked a gear in the lens housing, the mechanism to extend that is located when you open the camera and take off the front face plate, on the right side of the lens housing **silver part** you see a black plastic casing attached to a motor on top and screws in it, that is what moves the lens housing in and out, in that are a few gears, i think 4 of them lat move the housing, 3 small ones and one big one that reaches down to the bottom of the housing, they are interchangable but im not sure as to where you could find a gear to replace the broken or cracked one,
And for a_nester
im gonna take a guess at what exactly the problem is on your camera, and it might be the lens autofocus
in that case you can look here
Jul 01, 2008 | Casio Exilim EX-Z77 Digital Camera
Grease on the inside of lens
stripping these lenses can be tricky, i suggest you get in done by a panasonic technician. you dont want to damage anything making it worse and cost more in the long run.
Feb 17, 2008 | Panasonic PV-GS35 Mini DV Digital...
Built-in lens
The built-in lens "all-in-one" designed to be digital, which means it is specifically matched to the CCD. Cameras offering interchangeable lenses are designed for 35mm film, which usually does not have sufficient resolution for a Megapixel CCD sensor. When interchangeable lenses are removed from the body, the CCD and internal mechanisms are exposed to dust in the environment. Contaminants are a much bigger problem on digital cameras since the CCD is much smaller that a 35mm film plane. One of the primary reasons for using interchangeable lenses is for a wide variety of focal lengths. The E-20N contains a 4x optical zoom 9mm-36mm (35mm-140mm equivalent in 35mm photography) built-in lens. In addition, there are wide angle, telephoto and macro add-on lenses. Some interchangeable lenses cost as much as the E-20 camera itself. Other lenses that were originally designed for film cameras do not deliver same focal length on a film camera as a digital camera. For example, a wide-angle 28mm lens attached to a digital camera would only provide 56mm equivalence. This system offers great flexibility and will suit approximately 95% of most shooting needs.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Cameras Logo
57 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
