Question about Altec Lansing AVS 300 Computer Speakers
Voltage adapter i just bought a adapter that goes only to 12 volts, will it work for my subwoofer which is 18 volts
  • 4 Answers
I have used a 15vdc 900ma with no problem but never run the volume high. The factory specs are for 18vdc 650ma Center +
Posted on Dec 04, 2008
  • 171 Answers
NO, it is very under rated and powered. You need an 18 volt and not a 12 VOLT. They should not be that hard to find in an electronics store. Also the amp rating is also important. Make sure you are matching both amps and volts AC or DC to the the label on the woofer or you could end up blowing the out.
Posted on Sep 24, 2008
How many volts I have a charger that has different volts which one to set it on I have a whistler 1610 just trying to put the charger on the right voltage
Most automotive electronics work on a 12 Volt DC system. You must be using adapter capable of providing about 12 to 14 volts because car batteries provide 12 volts; but car alternators put out 13.8 volts. Do not attempt to connect to an adapter that put out AC voltage!
May 21, 2014 | De-1610 Radar Detector With Car Charger
Printer will not power up using a 12 volt 1500 watt power inverter, but powers up ok on acdc poer at home.
pay attention on the input values of the printer....Some of them are not on 12V but on 18 ..or so ...and try to find a power adapter that will work on the inverter's value ..and exit the correct voltage and amperage
Jul 05, 2011 | Office Equipment & Supplies
What would be the easiest way to change the voltage on a black n decker 18 volt battery to 12 volts? I will be using both voltages to run my application.
no easy way to change voltage
if you try to run an 18 volt tool with 12 volts, it just will not work may as well just throw a flat battery in it and pretend it is working
Dec 16, 2010 | Black & Decker Drills
I am tryin to install a sony xplode amp and subwoofer in my car to the stock stereo but i dont know what wire to splice into for the rem on my amp
for a remote turn on you can use the acc off of the ing ( test 12volt when car is on befor crank goes to 0 during crank then comes back to 12 voltswhen car is running 12 volts also goes to 0 when ing is turned off and key is in off positon. 12 volts from the battery fused 12 inches from connection and ground. also are you using some sortof high level adapter for an audio signal( this would tap into left and right spks either front or rears and provde you with rcas for your amp
Aug 22, 2010 | Legacy Car Audio & Video
Car power adapter broke.
All whistler models run on 12 volts and the center pin of the power cord is positive.
Mar 08, 2010 | Whistler Vehicle Parts & Accessories
Vgn fs 980 adapter how to tell if it is not working
AC adapter? Test the output voltage.
Use a multimeter.
Stores like Radio Shack, Walmart, and auto parts stores, for a few examples have cheap one's you can buy.
About $12.
Set the multimeter knob to DC volts, and the 0 to 50 Volts scale.
The middle hole of the AC adapter plug is the Positive connection. This is where the Red lead goes.
The outer shield of the plug is the Negative connection. This is where the Black lead goes.
Look on the AC adapter for the OUTPUT VOLTAGE
(Not shouting)
Example:
I'm looking at an AC adapter for an IBM Thinkpad 370, right now.
INPUT: 100V 50-60Hz 130A
OUTPUT: 18V ~~~3.36A
The Output voltage is 18 Volts
The Output Voltage of your AC adapter should be close to this.
Dec 20, 2009 | Sony VAIO VGN-FS980 Notebook
I have a sharper image midi and the red light (cleaning overdue)stays on even after cleaning? Will it still work with the light on? My real question how to fix it
Same problem : after cleaning thoroughly inside by removing the Front& Rear Plastic grid and the stainless blades, I also cleaned the 2wires (very softly and carrefully, not to break them), but the Redlight goes on after only few minutes :
Here is my Solution :
1 - Turn on (Low position) although the Red ligt is on
2 - Release the Rear plastic Grid (or Front plastic grid, or both of them) : That stop the unit automatically
3 - Replace it and make sur it's well locked : the unit turns on automatically.
After that, my unit works well, no more Red light. Maybe it will work for you. I also found this other bit of information. Since then I have discovered a lot of information on the midi. Here is some more reading material that might interest you.
Could be a blade replacement needed but Sharper Image2.gifrecalled the product. Since it was proven in court that it wasn'teffectively cleaning the air by Consumer Reports as well as EPA data. As a result of the legal action, Sharper Image filed for Chapter 11.
Here are a few links about it:
http://www.consumeraffairs.com/news04/2008/02/sharper_image.html
http://www.epa.gov/iaq/pubs/ozonegen.htm
Sharper Image was giving customers a small rebate for the product since it was proven to be ineffective for cleaning the air by Consumer Reports as well data by the EPA.
This has caused a mess for Sharper Image that they went into bankruptcy as a result of it. The Consumer Products Safety Commissionis going to be making a decision on ionizers at the end of year sincethere are hazards in the air from using the devices. It could be thationizers are no longer sold in the US next year.
The industry should have been regulated and unfortunately the government never did anything about it until Sharper Image and Consumer Reports went to court on it. The next step to do if you can't get it to work is to file a report with the company.
The Ionic Breeze would work for a short time after cleaning and the bluelight would start flashing again. We checked the wall cube power adapter with a volt meter. It was putting out only 10 volts instead of the needed 12 volts. It seems The Ionic Breeze needs a full 12-13 volts to work. So we went to Radio Shack and bought a universal 12 volt 800ma power adapter. I checked the voltage in the new adapter, it was 13 volts. This fixed the flashing blue light problem. The Ionic Breeze produces harmful Ozone gas, so we don't use it anymore.
Best wishes. Hope this helps you. If not please leave me a comment and I will do some more research.
Aug 22, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
There is a red blinking light and it is not cleaning.
My Ionic Breeze would work for a short time after cleaning and the blue light would start flashing and the unit would stop working. I checked the wall cube power adapter with a volt meter. It was putting out only 10 volts instead of the needed 12 volts. It seems The Ionic Breeze needs a full 12-13 volts to work. So I went to Radio Shack and bought a universal 12 volt 800ma power adapter. I checked the voltage in the new adapter, it was 13 volts. This fixed the flashing blue light problem. However the Ionic Breeze produces harmful Ozone gas, so I don't use it anymore.
Aug 09, 2009 | Sharper Image Professional Plus Ionic...
Just quit. no seem to be burnt .does not work. no sound. fuses good. similar problem it seems like that posted jan. 15,2009
Please check +12 volts at Q809 emitter pin and -12 volts at Q810 emitter pin on power board. Also check collector voltages on both transistors and let me know to move further.
Jun 04, 2009 | Sony SA-WX700 Subwoofer
Blue amp light lights for 2sec
bad head unit or look at your ground wire good luck
May 24, 2008 | Car Audio & Video
Altec Lansing AVS 300 Computer Speakers Logo
203 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
