Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Refrigerator and freezer temperature control
I just got my kenmore trio refrigerator today. I touched the temperature control buttonf on the door and they both got lower. How do I get them back to 0 for the freezer and 37 for the fridge?
  • john gagnon
    john gagnon May 11, 2010
    hi thhanks for the question did you try pushing the temp control to higher
  • john gagnon
    hi thanks for the question i would need the model # thanks
Keep pushing the temp buttons, they'll cycle through to as low as it will go, back to the highest temp setting. From 2 repair bills I've had, suggest you leave them on the factory defaults. Simply unplugging for a minute, then plugging back up should restore to factory setting.
Posted on Oct 03, 2008
  • 943 Answers
Hi. thanks for te question. since you asked the question. has your fridge settled down and cooling sometimes the fridge will set itself
Posted on Sep 28, 2008
How do I take KENMORE ELITE TRIO 596.75533400 out of demo mode?
Try pressing ultra ice and home while the refrigerator door is opened,or ultra ice and the refrigerator pad with the freezer opened. Hold for five seconds. Hope that works.
Jun 12, 2014 | Kenmore 22 cu. ft. TRIO French Door Bottom...
KENMORE TRIO 2004 59675523400 REEFER/FREEZER NOT COOLING
it should not be the compressor as the bottom is only not cooling.
Jun 23, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Hi. I have a 24.8 cu ft Bottom Freezer Refrig...over the last 24 hrs it does not seem to be keeping cold. Help!!
Did you set the control to a warmer temperature by accident while cleaning? Check to make sure the temperature control is set to a position that has the cooler turning on. Usually 4-5 will suffice.
Apr 20, 2012 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
The temperature settings for the refrigerator and
I have the same problem with this refrigerator. It looks like Sears Parts Direct sells all the parts for this unit except for the printed circuit board and temperature control switches. I called my local repairman and set up an appointment. He called back to cancel his appointment because he was also unable to get the electronics. Were you able to fix your unit? What did you replace?
Jul 28, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore elite trio 596.76539500 control panel says OFF.
On a Kenmore Trio 78729 made by LG, open left door and push the Ultra Ice and Refrigerator button simultaneously for 5 seconds. The display will change from 0 OFF to temperature settings.
Dec 10, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer working but refigerator not...
Mullion heater is not the problem. If the refrigerator is not cooling look to the freezer compartment for your problem. Air from the freezer is used to cool the refrigerator(s) section. If the freezer coil frosts up it stops air circulation to the rest of the system. Although you may think the freezer is working properly it may have a defrost problem and will show up there also. Look for signs of frost on the back wall of the freezer as a sign of the coil freezing. The mullion heater is designed to put out just enough heat to stop condensation between the outside temperatures and the inner compartmant temperatures. If the inner compartment is warm the heater will seem warmer than normal.
Jun 26, 2008 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Control pad flashing temp and all lights continuously and ice door continually cycles open and closed
With the problems it is presenting, I would say it's very likely.
However it may take a bit of detective work to find which board is defective.
Check a part suppliers link Here for price comparison so you have some ideas.
Jun 26, 2008 | Kenmore TRIO 77314 Side by Side Bottom...
It is the compressor that has failed. The hum is it trying to start and the following click is the overload protector opening. What is the temperature where the refrigerator is located? Allow the compressor to cool down before trying to restart it. If it still does not restart after it has cooled off it is done.
May 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Temperature control
For the Kenmore, keep pushing the button and it should cycle back to the top of the temperature range.
Sep 04, 2007 | Kenmore 63822 / 63824 Bottom Freezer...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
203 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
