Question about Minolta magicolor 3100 Laser Printer
Printing issue My magicolor 3100 preints a reddish jagged streak down one side of the paper near the margin
  • redavdp Feb 19, 2009
    The same as above, I don;t think resetting will work, has anyone tried?
  • 171 Answers
In order to proceed with the solution to your problem, we'll need to save the current settings on your Crown printer and then restore the printer to its original factory settings as shipped. Your current settings will be saved, and can be restored after we finish this troubleshooting session. You will need to access the printers front panel in order to perform the following settings.
Procedure to save your current printer settings
Procedure to restore printers original factory settings
Procedure to restore your saved printer settings
1. Make sure the Online light is lit and that the display reads Idle.
2. Press the Online/Offline button to take your printer offline.
3. Press the Menu button once. The display should read Operator Control.
4. Press the Right Arrow button once. The display should read Administration.
5. Press the Select button once. The display should read Communications.
6. Press the Left Arrow button until you see Miscellaneous in the display.
7. Press the Select button once. The display should read Save Defaults.
8. Press the Select button again. The display should read No.
9. Press the Left Arrow button once. The display should read Yes.
10. Press the Select button.
11. A few seconds should pass until the display reads Yes Is Selected.
12. Press the Online button twice to take the printer online while the display reads Idle. Your current printer settings are now saved and you are ready to proceed with returning the printer to its original factory settings.
6. Press the Left Arrow button until you read Miscellaneous in the display.
8. Press the Right Arrow button. The display should read Restore Defaults.
9. Press the Select button once. The display should read Factory Defaults.
10. Press the Select button again. The display should read No.
11. Press the Left Arrow button once. The display should read Yes.
12. Press the Select button. Yes Is Selected will appear in the display.
13. A few seconds will pass and the printers display should read Disk And Flash Sys Loader.
14. Your printer will reboot with the original factory settings and return to Idle.
Try a test print. Does the problem still exist?
10. Press the Right Arrow button. The display should read Custom Defaults.
11. Press the Select button. The display should read NO.
12. Press the Left Arrow button once. The display should read Yes.
13. Press the Select button. Yes Is Selected will appear in the display.
14. A few seconds will pass and the printers display should read Disk And Flash Sys Loader. Your printer settings are now restored to their original saved settings
Try a test print, does the problem still exist?
Posted on Sep 24, 2008
SOURCE:
Konika Minolta Magicolor 2480 MF streaks where the ink doesn't print
What color? replace that image unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 15, 2014 | Konica Minolta Magicolor 2480MF...
Konica minolta 4690mf color streaks
replace the image unit for yellow and magenta
try this site for parts as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 22, 2014 | Konica Minolta Magicolor 4690MF...
Text is printing too low on the page
I have a Magicolor 2400w and had the same problem... I hope I'm not to late because I almost put mine in the trash.
How I fixed the problem was I adjusted the solenoid behind the fan on the right side. I made a video and posted is on YouTube. Search YouTube for Magicolor 2400w paper size error. or follow the link.
http://www.youtube.com/watch?v=jlyuPJW6RjU
Hope this helps
Dec 29, 2012 | Konica Minolta magicolor 2400 Laser...
I have Minolta 2300W Laser Printer and it folds the first page only about 3 to 4 inches down makes a nice one inch fold but take that out and print again...next page fine.....now printing with two wide...
The is blocked by dust on the side of the paper on the image unit that would have color associated with the print. Remove all the image units and clean all the laser glass. Replace those image units also if streaking as for the paper ensure correct paper side and media type.
Jul 12, 2010 | Minolta magicolor 2300W Laser Printer
Getting streaks down left margin
I guess you have a problem in your fuser assembly
Mar 12, 2010 | HP LaserJet 1320 Printer
Color streaks on page
Had a similar problem. Tried lost of things. In my case, the streaks cleared up after I cleaned the toner drum.
Aug 25, 2009 | Brother MFC-9420CN All-In-One Laser...
Dell 3100 CN Prints a stip on black all the way
There is a known issue for these printers to "streak." If under warranty, call Dell. If not, there is a fix
for the defective drum unit design but requires a little technical expertise.
The procedure is explained here:
http://www.ahfx.net/weblog/133
Jul 08, 2009 | Dell 3100cn Laser Printer
Problem with konica minolta paper margin
You don't have any solution but to increase the above margin to be equal as the bottom margin. To successfully print the pages, this printer need a larger bottom margin compared with the above margin. Just use the 'Center on page' option from your graphic application.
Jul 18, 2008 | Konica Minolta magicolor 2500 Printer
Black bullets down left side of paper
inspect the pc drum, if there is no dots, then its ok, also inspect fusing unit rollers and transfer belt for dots and clean laser glass.
Apr 24, 2008 | Konica Minolta magicolor 2300DL Laser...
Margin problem???
I can just guess it has to do with the paper being fed. either you have the paper wrong or the paper settings to a different size then the actual dimensions of your print material.
Oct 24, 2007 | Dell 3100cn Laser Printer
Minolta magicolor 3100 Laser Printer Logo
731 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
