Question about NetGear MR314 802.11b
Mitel WLAN Stand connecting to Netgear MR314 802.11b wlan
Having issues with my Mitel 5212 phone on wireless LAN stand connecting to Netgear MR314 802.11b wlan router across sbcglobal.net...... The wLAN stand is in bridge mode with DHCP enabled but the phone goes up and down like a yo_yo..... if a static ip address was given to the phone for the netgear router to identify with, would this resolve the problem.... seems I'm the only one going this route and didn't want to buy a new router and internet connection to facilitate new gig.
Not sure how to set a static IP up with netgear box as I search for step by step instruction...
your kind response is apprecaited.
4 Suggested Answers
  • 130 Answers
SOURCE: Does the MR314 Wireless broadband router have an internal DHCP server?
Yes, ALL of NETGEAR routers come with a DHCP server, which is set to be active by default.
Posted on Feb 19, 2006
Cameron07
  • 110 Answers
SOURCE: Netgear WG602 wireless router, Connection Local only !
What I think is you unplgged them at the wrong times.
Do this:
(in this order)
  1. Turn off the router.
  2. Turn off the modem.
  3. take out all the Ethernet cords from the router, EXCEPT the one coming from the modem
  4. Now turn the modem on.
  5. Wait for the lights, then wait about another minute for it to settle.
  6. Turn on the router, make sure the Internet,Lan,Wlan,etc lights are on and functional if it doesn't display a light let me know.
  7. Now depending on what your wireless network (SSID) is called try to connect to it. Go to Start>Network>Click Network And Sharing Center at the top>on the left select Manage Wireless Networks>now click add, if your network is already on the list shown select it and click remove otherwise click "Add" click "add network in reange of this computer" select your network name and click connect.
Now tell me the errors, like if it says connection limited,etc...
Thanks,
Cam
Posted on Oct 19, 2007
  • 378 Answers
SOURCE: I have Netgear N router and having problems trying
The phone is intended to be connected to a Mitel PBX telephone system. If you're using the phone at home, you must set the phone in Teleworker mode and use the IP address of the teleworker server. This will allow your phone to tunnel into the phone system.
OR the phone must be set up in SIP mode. Press and hold the 6 key while booting the phone. You will also need to set it up and tell it where the SIP server is located (IP addresses).
If you don't have this information, you should contact your vendor or system admin for further assistance.
If you are trying to use the phone without the above servers, I have bad news - it won't work.
Posted on May 01, 2011
How to i connect my nokia e5 to wifii
Hi there
Select Menu > Ctrl. panel > Connectivity > WLAN wiz..
The WLAN wizard helps you to connect to a wireless LAN (WLAN) and manage your WLAN connections.
If the search finds WLANs, to create an internet access point (IAP) for a connection and start the web browser using this IAP, select the connection and Start web browsing.
If you select a secured WLAN, you are asked to enter the relevant password. To connect to a hidden network, you must enter the correct network name (service set identifier, SSID).
I also found the full manual in pdf format which you can download from here
http://nds1.webapps.microsoft.com/phones/files/guides/Nokia_E5-00_UG_en.pdf
Good luck
Nov 11, 2014 | Nokia E50
Mitel 5212 IP: PC output has stopped working, no LAN connection to my laptop?
possible dropped out the LAN driver
good bet if you are using win xp or win 7 OS
Feb 11, 2018 | Mitel 5212 IP Phone
Mywifiext net
Have you first established the connection between the Router and the Extender?
If so, have you connected e.g. a laptop to the Extender?
So if your WLAN networks SSID is NETGEAR, the WLAN network of the Extender is NETGEAR_EXT and you have to connect the laptop to NETGEAR_EXT.
Then you have to open your favorit internet browser and have to type in www.mywifiext.net, which I guess is a buildin Setup-Assistant.If this doesn't work, make sure, your laptop is configured, to get an ip address automatically via DHCP.
Or read http://kb.netgear.com/app/answers/detail/a_id/20912
Apr 26, 2013 | NETGEAR CONSUMER New - Netgear Wn3000rp...
Acer aspire 5310 Wireless LAN indicator light on windows 7
That sort of comes with a OS upgrade, in upgrades from XP to Win 7, I'm supprised that's the only thing that is a issue. I upgraded a old gateway (2005) from XP to Win 7 Pro N 64bit. and had some hardware issues to deal with. Consider yourself lucky. You can get use to it or search endlessly for a fix. Try the Acer forums, you may run across the issue.
Dec 27, 2012 | Computers & Internet
I have a wifi at home, im using now a wifi phone, it displays, netgear found, when i search for wlan it says wlan network netgear but when i wnt to connect to the web it says wlan unable to connect wlan...
try unplugging your router for 1 minute, plug it back in and wait for it to properly boot, make sure you do not have a secured wireless network (WEP,WPA, ect...)
or make sure that the phone is able to accept the connection with a security key. If not you might have to disable your security in order to use the phone.
May 06, 2011 | Computers & Internet
HVING PROBLEM ACESSING THE INTERNET THROUGH THE ROUTER . WIRELESS OR HARD WIRED . IFI RUN STRAIT FROM MODEM I HAVE INTERNET . ONCE CONNECTED TO ROUTER I DONT
connect the router wan port to one of the modems lan ports,
then connect to the router per lan or wlan and everything works.
Feb 24, 2011 | NetGear WNR2000 Wireless Router
Hi =) I have a mitel 5224 which i connect to my
the stand requires configuration to tell it how to connect to your Wireless router. The default IP address is 192.168.1.20
The firmware should be upgraded to 2.0.3.ap51. This provides for better security and more options.
Nov 09, 2010 | Mitel 5224 IP Phone
Sometime ago, i had accidentally dropped my lappy on the ground, causing the hard drive to malfuction. i later replaced the laptop's hard drive but now, its wireless LAN dont work properly. i mean i can...
First check if its a drivers issue.. Unistall the drivers and reinstall the latest drivers from the support website of tashiba... Then try to take the WLAN and reinsert it.. Try to get all the wireless networks again and try to connect.. If the issue is not fixed you may have to replace the WLAN card....
Sep 20, 2010 | Toshiba Satellite A135-S4527 Notebook
I m havin BSNL ADSL2+ DNA-A211-1 modem..i don know how to connect my laptop wit modem in wifi mode..pls tell how to configure n connect it..modem has ethernet port oly not having usb port..pls suggest some...
Secured Wireless is better than a unsecured one. Configuring a secured wireless network easy.
· First Check it the Wireless is turned on in the modem.
You must see the wireless light glow on.
Wireless LAN (WLAN) should be Enabled before configuring the wireless network
· To make sure, if the WLAN is enabled you can check the WLAN light glow.
· If it is off, then you can be sure that WLAN is disabled.
May 27, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Got full bar wireless signal...........
Connet to your router using a LAN cable.
Be sure you can browse
Configure your Wlan with same protocol WPA/WEP) and Keys (TKIP)
or remove every protection from your Wlan (not recommanded)
Do you see your SSID in your PC?
Dec 26, 2008 | NetGear RangeMax WPN824 Wireless Router...
NetGear MR314 802.11b Logo
452 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
