The version of the Mozilla firefox which is installed on the computer must be corrupt due to which the browser is not working properly. All the applications which are installed on the computer have lot of files which are associated to it. If any of the files which are associated to the browser gets corrupt or is missing on the computer then the browser will not work properly. Replace all the files which are corrupt or missing on the system and then check if the browser is working properly or not. Uninstall the browser and remove all the files and keys associated to the application. Once all the traces of the application are removed, reinstall the browser and see if it works properly.Sometimes the add-on/applications installed on the browser create problems which you are facing. Some files of the browser are corrupt and if such an application is installed on the browser, it will definitely corrupt the files of the browser. If such a situation occurs then the browser will not work properly. Mozilla firefox has a diagnostic mode which is known as safe mode. In safe mode all the applications/add-ons are disabled. Start the browser in safe mode, to start the browser in safe mode, type "firefox.exe/safemode". If the browser works properly in safe mode then find and remove the application which is creating problem.Follow these steps and let me know if it works Open Windows Explorer. Click on Tools and then select Folder options. Now select Files Types tab.Check if the HTTP is highlighted or not.Now Select Advanced. Check if the Open is highlighted in the Action box.Select Edit.Remove the check mark from Use DDE and then click on Browse.Select the location of Mozilla firefox and click on OK. Check if the path of Mozilla appears in the Applications tab.Now click on the path and add url 1 ending with double quotes.Click on OK. Repeat the same procedure for HTTP with Privacy.Now the there would be no problem in opening the links of Outlook Express in Mospeaceszilla firefox.
