Question about JVC GZHD7 60GB Hard-Drive Camcorder 60 GB USB Hard Drive
JVC GZHD7 frame dropping problem
The JVC GZHD7 cuts up long event filming into files about 18 and a half minutes long (18:23:23 to be precise), which is a real problem, because it doesn't play back perfectly over the joins. The first frame of a new file seems to follow the last frame of the previous file OK, but then there seems to be several frames missing before continuing on as normal. Then at the end of each file, the second and third last frames are the same (duplicated). But what is worse is the fact that the audio is totally missing from the last 9 frames of each file, which produces a noticeable glitch in the sound during playback. It's enough to miss a whole word during speech. This is noticeable both when playing the original TOD file or the resulting quicktime file (converted with MPEG Streamclip) during editing in final cut pro. Is there any fix for this, or better yet, is there a way to stop the GZHD7 from cutting up long continuous video shoots into multiple files?
5 Suggested Answers
SOURCE: Capturing GR-PD1 Hi-Res clips in Final Cut Pro 6
I have a similar problem, i - by mistake - shot some footage in ps 50 mode. Now i can capture it in my mac by playing it analog, and than capture it. This seems to work fine only.... date and time keeps showing in the footage and that's not what i want cause that makes the footage totally useless.
Problem is, i don't have a manual i can't seem to figure out how to 'not display' date and time of the recording. Does anyone have a suggestion or maybe an english pdf manual you can send me? Any help would be higly appreciated. (tonvanderkolk@gmail.com)
Regards
Ton
Posted on Nov 03, 2007
  • 10 Answers
SOURCE: .TOD file extensions
u can rename the .tod file to .avi. once you have renamed it, you can import it into after effects or premeire.
if you dont have them softwares than use ulead video  studio pro x2
Posted on May 26, 2009
  • 80 Answers
SOURCE: My JVC GZ-hd7 TOD files won't play on final cut
import tod to final cut express after converting tod to mp4, mov, or dv, m4v video.
Posted on Sep 23, 2009
hawkform
  • 217 Answers
SOURCE: JVC GZ-HD3U I cant find any video programs to edit
Hi and welcome to Fixyah,
All you have to do is to copy all the files from your camcorder and then save to your documents.
Download video converter to the website. Google it and type it there .TOD convert to MPEG4.
Posted on Apr 07, 2010
I have a 2009 Yamaha rhino 700 cutting out at half throttle and popping cuts out at 35 mph
Cutting out at 32mph - Yamaha Rhino Forum - Rhino Forums.net
www.rhinoforums.net > ... > Members > Forum Help, Questions and Info
Apr 23, 2011 - 12 posts - ‎8 authors Once it cuts out I let off the gas to let the speed drop a little, it pulls fine then ... The reason I say that is because feathering the throttle gets you 4 mph more .... Spent halfa night starting it and reving it trying to go somewhere but I'd give it ... Join Date: Sep2009 ... 2008 yamaha rhino 700 cuts out at 40 mph. 700 Sputtering with constant throttle
Jul 18, 2012
Rhino missing/dying/backfiring when running on top ...
Aug 12, 2011
2009 Rhino 700 Crank No Start
Dec 12, 2010
full throttle
Aug 31, 2009
More results from www.rhinoforums.net
Sep 27, 2015 | Yamaha Motorcycles
After 45 minutes of run time drops to half power
it is droping to half power to stop the motor from over heating check the water level and oil top them up.
Jun 27, 2015 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Film was in camera, frame 18. Batteries had failed at frame 17, had to depress "B Lock" button" and set shutter to 60 to release shutter. Replaced batteries with fresh batteries, battery...
This camera is somewhere between fifteen and thirty years old. It is highly unlikely that spares would be available, and it would be extremely expensive to have it repaired in any case, most artificers familiar with the internal layout having probably retired years ago. Maybe the camera should be retired too ?
Apr 16, 2017 | Olympus OM-4TI 35mm SLR Camera
I have this product primarily to scan 2 1/4 film. There are no guidelines on how to place the film in the film frame provided by epson.. Frequently I get only half a frame. I have tried moving the film...
I found some documentation on this product from Epson.
I don't know if this is what you where looking for, but here is the info i found:
Main users guide:
http://files.support.epson.com/htmldocs/prv6ph/prv6phug/index.htm
Placing films on slides info:
http://files.support.epson.com/htmldocs/prv6ph/prv6phug/set2_2.htm
Hope this helps!
Oct 27, 2010 | Epson Perfection v600
After develop the pictures i found that some images are completely blank and the images are cut into half. Half develop and half not. what the cause of it?? thanks
Might be film coming loose when inserting in loading spool and skipping when winding forward after making a shot. Could try bending first 1/2" of film tongue before inserting in slot in windup spool so that it won't slip out and be sure film sprocket holes are engaged with film transport sprockets and a bit under tension when loading film before closing camera cover. Your 'half-frame' problem might be that you are shooting at a 'flash' shutter setting of 1/60 when not using flash.
Oct 08, 2009 | Canon EOS 5000 35mm Film Camera
What do I need to view my clips on a pc?
You must first backup (download the video files) to your computer before you will be able to view them.
Apr 09, 2008 | JVC GZHD7 60GB Hard-Drive Camcorder 60 GB...
Canon EOS Rebel G - The picture is cut in half
I'm afraid this is almost certainly a shutter fault - the second curtain of the focal-plane shutter is getting stuck half-way across the film and therefore not shutting properly. The fact that the other half of each frame is OK makes me think that the second curtain is not sticking totally but just moving very slowly for half of its run, thus seriously overexposing that half of the film. This is a repair shop job - unless you want to try it yourself: it may be just some dirt stuck in the track the shutter curtain runs in, but a fair bit of skill is needed to get to it & clean it without damaging anything!
Sep 29, 2007 | Canon EOS Rebel G 35mm SLR Camera
JVC GZHD7 60GB Hard-Drive Camcorder 60 GB USB Hard Drive Logo
52 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
