Question about Kenmore 4.5 cu. ft. Oasis Canyon Top Load Washer
F1 error I had the same EXACT problem as you I called Sears with same recall results as you had I replaced the circut board as other readers said ( after 1st trying to disconnect & reconnect with no luck) and it worked Sears said part was backordered until oct 5th but received in 5 days was about $130 to fix myelf beats $400 for service call it is a shame that this breaks in less than 2 years but I thought it was worth taking a chance for a little over $100 vs $900 for a new washer. To stop the hassle of wasting time to reset at start of rinse cycle was worth the price I will still try to get something back from sears but at least the washer works (for now anyway) Hope this helps ?
  • 15,935 Answers
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!!!
Posted on Sep 18, 2010
F1 error message comes on every time I start our washer after lid lock engages!
THE PRINTED CIRCUIT BOARD IS BAD. DO NOT BLAME SEARS FOR THIS I SHOULD OF HAD A SURGE PROCTECTOR ON THE MACHINE. THIS may cost you like $250
Oct 03, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Error f1 flashes after just a few seconds of turning on the wash cycle. if i turn off power and try to start again it will somtimes start if not i turn off and try again sometimes it takes 3 or 4 times to...
The Whirlpool Cabrio and Kenmore Oasis (same machine) are infamous for this problem. Depending on the serial number you may be entitled to a new control board installed for free under a recall program. Call Whirlpool for eligibility. I had just had mine replaced last week for free and it runs fine now.
Apr 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have the exact same problem with my Oasis that everyone else is describing.....when the machine is started, I get an F1 error code. I can push stop and start, usually 4-5 times and the machine starts...
Mar 13, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Oasis 110.273 "F1" error on inital and rinse cycle fill. Have already checked to make sure all connections were secure.
The F1 error on the Oasis is a known issue. Sears recalled the computer module because it's defective and produces this error along with F71 code errors. Unfortunately, unless your serial number meets their current criteria, they won't honor the recall because it expired on 08/31/2009 for some serial numbers. Best bet is to call and find out if they'll honor it. If you talk nice & originally bought it from Sears, they might. They did for me. But then we had to replace the RPS. Now the stator. This machine is an expensive piece of junk.
Nov 23, 2009 | Kenmore Oasis HE 27082 Top Load Washer
F1 error on cabrio washing machine
Whirlpool Cabrio F1 error code - NOW A RECALL ISSUE! model # WTW6600SW2
  • I called Whirlpool 1-800-253-1301 today 10/15/08 and they said the F1 issue is now under a recall.
  • Whirlpool scheduled a repair service -during our phone call- to repair this under a 'recall' & at 'No Charge' to me.
  • I'll let you all know how it goes after the repair..
Nov 10, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 Error Codes
sorry to be the bearer of bad news, but its the machine/motor control unit (circuit board). if you don't want to involve sears to get them to pay a portion of the bill, then go to searspartsonline and order one yourself. you'll need your model number to get the right part number ECU (which should be W10189966 rev A) which will run you about $150. replacing it is relatively easy is you're handy at home. sears service will charge you another $130 to install it. this will fix the F1 problem.
not sure if sears has finally recalled this washer. if they finally do, then all our problems go away (yeah, right).
Jan 18, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis He 27082603
Folks F1 means the board is bad, I would definitely call the line listed above with model and serial number. They will schedule a tech, maybe me if your in Phoenix and they will give you a receipt, but if there smart the call will be set to transfer the charge to Sears:)
Sep 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Wtw6600sw whirlpool cabrio
First off I hope you have a Sears unit and second you did not pay a penny. Your F 1 error is a Primary control failure. Part W10104830 and one other do F1 and a oL code.
If you own a Sears machine you qualify for a recall under sf26-779B.
There is two parts to this call the board and a washplate
MCU part # W10201186
Washplate # W10077050
Recall will need your name and phone number and the machine model and serial number.
If you meet all of these conditions to the letter call Sears Recall at 1-800-659-7026
Aug 06, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Recall on kenmore oasis
I have one of the first kenmore oasis and I get the F1 and off balance error all the time I called the recall number line is 1 (800) 659 7026 they said that they are doing a free upgrade to replace the control board the only problem is the board is on a back order and it may take a week to get the part in.
Jul 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore 4.5 cu. ft. Oasis Canyon Top Load Washer Logo
69 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
