Question about Samsung TXR3079 TV
Wont Power up
Samsung txr3079 wont power up. Gets power as indicated by red light but will not turn on.
Thanks in advance.
jwx41600@yahoo.com
Mike Anderson
  • 1 more comment
  • jtfinni Nov 07, 2008
    Same here power led lights solid then pushing the power button causes the tv to do a 6 light blink then repeat.
  • John Guenther II Jan 26, 2009
    Same problem situation LED blicks 6 times when power button is pushed. Won't turn on, dead set.
  • Anonymous May 07, 2009
    Same problem...blinking red powwer LED, but no power.
    Does anyone have a fix for this yet?
    Problem Solver:
  • 7 Answers
Jwx41600:
I had the same problem with my Samsung TV Model: TXR3079WHX. However, I was able to repair my set while it was still intermittant (would turn off by itself after 30 minutes of operating, would have to wait 5 minutes before it would turn on again).
I troubleshot my problem with a can of component cooler from Radio Shack and found my problem to be a defective voltage regulator, identified as "QR015" on the main circuit board (the same board that contains the high voltage section).
Caution:
Before I proceed any further I need to strongly warn you. Do not attempt to remove the back cover, troubleshoot, repair or perform the actions that I have done, if you are not a "qualified service technician". Removing the back cover exposes you (and anyone else) to harmful and deadly electric shock, even though the TV may be unplugged from the wall outlet and turned off. You (or anyone else) can be seriously injured or even killed. If you are not qualified, play it safe by allowing others who are qualified repair this for you.
The defective part (overheats and shuts your TV off) is voltage regulator manufactured by Fairchild. The part number is KA75450ZTA. This part is available from Mouser Electronics for less than 20 cents plus shipping. In order to replace this part a qualified technician will need to remove certain cables and unscrew the main board to allow access to desolder and solder the new component.
Hope this helps.
Posted on Jun 06, 2009
Won't turn. on red standby light changes to on but then goes right back red
TV won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have the Samsung FP-T5084 50" Plasma tv. I went to turn it on the other day, and it wouldn't turn on. No clicking. No red power indicator light. Nothing. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
More results from www.cnet.com
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old. ... I have an old type sony tv with the big back and the red power light keeps flashing and ...
How do you fix a television that won't turn on? - Ask.com
www.ask.com > Technology > Television & Video
Jan 03, 2016 | Televison & Video
Samsung LN46D630 Wont turn on
http://www.tvrepairdoctor.com
Oct 26, 2012 | Samsung LN46D630 LCD TV
ML900wTW transformer gets stuck at the "on" position and stays there. Lights wont come on,unless I advance the wheel manualy. Then the clip will turn the lights on. The lights have no problem turning...
The clock motor has gotten weak and now it is overheating and will not recover.
There are no replacement clock motors.
To buy more time with old power pack, purchase cheap plug-in timer, set power pack to override, and then plug power pack into cheap timer.
For more information on power packs showing replacement trippers, useful links and tips
http://www.fixya.com/support/r8391011-power_pack_not_working
May 25, 2010 | Intermatic Malibu 300W Power Pack...
Wont turn on
The power supply board has been defected. Replace it with a new one.
Aug 15, 2009 | Samsung LN32A330 32 in. LCD TV
When I power on the tv, the light goes to green and then a few seconds later goes to a red flashing light
When a set is powered up, there are internal checks that are performed. The initial green light indicates that power has been applied. The flashing red light indicates that a problem was found that is preventing the set from functioning properly and it has shutdown to prevent further damaeg. If you can supply the model number, I may be able to provide additional details. Also, check to see if the flashing red light has a pattern. Quite often the pattern will indicate what problem was detected.
Thanks,
Dan
Aug 07, 2009 | Panasonic Televison & Video
91 vw passat wont start
there is another fuel pump inside tank,primer pump. check it!
Sep 15, 2008 | 1991 Volkswagen Passat
Sharp 56DR650 shows power but wont turn on, Sometimes it turns on
That's error code 32. Indicates lamp trouble or failure. The system will shut down automatically.
Aug 29, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Jul 20, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Samsung TXR3079 TV Logo
456 people viewed this question
Henry  Thomas
Henry Thomas
