Question about Maytag Refrigerators
I have a fairly new Maytag frig with bottom freezer which cools well but I can't seam to change the temp and more importantly, a lot of fog comes out of the frig port, the frig and freezer seam to have excessive moisture all of the time.
  • katybri Sep 24, 2008
    The house is conditioned with a heat pump and the relative humidity runs 30-45% in the house. We have had the frig for three years, and during the first two years, there was no fogging sen from the air outlet in the frig (sometimes there are water drops, or ice crystals on the outlet). This problem started this year, so something in the frig has changed. It acts like it can't get rid of internal humidity quickly enough. Any further ideas?
  • 943 Answers
Hi thanks for the question if you have fog coming out of fridge it sure is cold enough you must live in a very hot climate i wouldn't worry at all thanks the appliance doc
Posted on Sep 24, 2008
Maytag side by side msd264rheb freezer works frig isn't cold. We found ice on bottom freezer side and did melt it with a hair dryer. Frig vent is letting in, now a little cool air, but not a lot.
If you found ice in the freezer then there is usually a lot more behind the back plate. If you let it defrost completely it should work good for a couple days until the ice builds up again. you more than likely have a deefrost issue. There are usually nthree components in a typical defrost circiut. The heater, defrost thermostat and a defrost timer or control. one or those is bad.
Jul 28, 2014 | Maytag Refrigerators
make sure that there is nothing blocking the flow of air coming in. the fridge is cooled by the air in the freezer. also you might think about replacing the relay on the compressor. it may be going out.
Aug 11, 2008 | Maytag Refrigerators
Maytag ptf216lhr
thermostate stuck in defrost mode. sometimes they are inside frig(were temp controls are) sometimes in bottom rear of frig. IF you can find it you will find a small knob with slit in it. turn it clockwise just a little and clicking will stop and frig will start cooling however it will probably do it again. recommend replace thermostate.
Jan 24, 2014 | Refrigerators
Maytag plus frig bottom freezer
Whirlpool refrigerator and freezer problem. a cup was place in the refrigerator to catch the percipitation coming from an inlet from the freezer. Which they are two inlets located in the center back of the refrigerator from the ceiling adjacent to the floor of the top freezer. the Freezer back t-shape vent goes down to these inlets where the percipitation is coming from. What is this the damper
Mar 17, 2010 | Maytag MBF1956HEQ / MBF1956HEW /...
Runs all the time and seal is hot
sounds like the defrost timer is stuck on defrost while the cooling cycle is engaged this could be from a faulty limit switch in the defrost element circuit! to a temp controller in the freezer have to remove the inner boxes and panels to get too this area takes a lot of time and patience as to not break the plastic panels
Jan 13, 2010 | Maytag MSD2434GE Side by Side Refrigerator
8 yr old maytag msd2758drw side by side isn't freezing
If the clicking noise is comming from the rear of the frig it could be your compressor trying to start. The motor would be the fan in the freezer running. That part would be normal.
If it is the compressor it could be replaced but if it were me I would buy a new frig.
Dec 29, 2009 | Refrigerators
Freezer Works Frig Stays at 70
Wow, pay for the Premium Assistance Plan to get a quick solution ! I fixed my issue but thanks for the help ! I went to a FREE online forum and got my fix.
Mar 25, 2009 | Maytag MFD2561HE Stainless Steel Bottom...
Ice maker wont make ice
Nov 25, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Mar 27, 2008 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
239 people viewed this question
Top Maytag Refrigerators Experts
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
