Question about HP DesignJet 750c plus InkJet Printer
ASKING INSTALL COLOR CARTRIDGE
I USED NEW COLOR CARTRIDGES, STILL ASKING INSTALL COLOR CARTRIDGE.
I CAN'T PRINTOUT COLOR
  • egemen Dec 16, 2008
    I have the same problem. The pointer on the black cartridge turn green to black which means the cartridge is empty. Then I changed only the black cartridge with an original one. After that I tried to print a colored image on my plotter but the mode is automatically selected "MONO" when I pressed the "COLOR" "Install Color Cartridges" message appers on screen. Please help me!
I solved it. Firstly clean cartridges peak and the place that cartridges seated on plotter,be sure that the cartridges click into place properly. Propel the cartridges byhand. Then test and align the cartridges it will work!!
Posted on Dec 16, 2008
  • HP Expert
  • 141 Answers
Clean the copper colored flex contacts in the carriage where you install the cartridges. my guess is they probably have ink buildup. spray windex on a paper towel or q-tips and wipe those contacts until clean. reseat cartridges. Good Luck!
Posted on Oct 02, 2008
    Genius:
  • 1,124 Answers
Check if the cartridge was inserted correctly (right slot) (remove it and insert it again)
Check if the cartridge is original and the sticker was removed. Turn off your computer, and your printer. Start up your computer and after your printer. Try again.
If the problem continues, insert the old one cartridge (which was removed before) and see what happen...
If stop asking for install color cartridge, you have failure on your new cartridge
and need to be replaced.
Posted on Sep 24, 2008
My Lexmark printer X2690 will not align properly after I' ve installed a new colour cartridge I have taken the security strip off! please help
You could try to remove and reinstall your color cartridge again.Do a Clean Cartridges cycle.Then do an Align Cartridges cycle.
Oct 26, 2011 | Lexmark X2690 All-In-One InkJet Printer
Can it (HP deskjet F380 all in one) still print with only color cartridge or only black cartridge ? Or Should two cartridges remain together to print even one is empty ? Thanks
the answer to your question is yes,it can still print with only one cartridge installed.
If you do not have a replacement cartridge, and the quality of your printouts is not a concern, you can still print in ink-backup mode. Consider the following guidelines before printing in ink-backup mode:
  • If you remove the tri-color cartridge, printouts will be in grayscale.
  • If you remove the black or photo cartridge, the product will print more slowly and the colors in the printouts will vary.
    press OK button to clear the error message like cartridge missing after removing one cartridge.
Jun 20, 2011 | HP DeskJet F380 All-In-One Printer
I own a canon iP1300 printer and just bought a new canon pg- 40 black cartridge but its not being recognized by the printer, wat do i do
Can be a problem regarding the cartridge. What is the status of the color cartridge. Take a printout with the color cartridge alone. If no problem found get your PG40 cartridge replaced. One thing to be noted is that the printer always needs the color cartridge installed. Printer can work with color cartridge alone. But will not work without a color cartridge
Apr 09, 2011 | Canon PIXMA iP1300 Printer
Printer : canon pixma ip1600 problem: i just changed a new colour cartridge. existing black cartridge is still working. when i print out a colour picture using my laptop with windows 7, the printout is...
this is due to the color management for winXP and win7 are different.. you can try to download the printer driver add on for win 7.. else you will have to install manually the color management.
the add on can be downloaded below..
http://support-my.canon-asia.com/contents/MY/EN/0100226303.html
Jun 21, 2010 | Canon Office Equipment & Supplies
My HP 1000 Photo Smart is not printing in color. The film has been removed from the new cartridge, the printout shows color, grayscale is not checked Where else do I need to check
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 10, 2010 | HP Business Inkjet 1000 - Printer - colour...
Cartridge problem
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 19, 2009 | Canon PIXMA iP1600 Printer
Copier states to ''insert color cartridge''
When you installed the new cartridges, did it ask or display if you "installed a new ink cartridge" press the ok botton to rest the cartridge back to new. Then it will ask you to aline the cartridge and it will print a test print and ask you to place the print out on the glass. Do the same for the next cartridge..... I have one question, is this a new problem with the new cartridges????
Mar 24, 2009 | Office Equipment & Supplies
DCP-130C COLOR INKJET
When inserting a new cartridge, you may receive a prompt
"The installed ink cartridge differs from the original ink cartridge for the printer. Your printouts may be different from those printed using original ink cartridges. Do you want to continue using the currently installed ink cartridge?"
If you click Yes, printing will continue. If you select No, you will be prompted to change the cartridge. Manufacturer prompts may vary.
Nov 21, 2008 | Brother MFC 420CN All-In-One InkJet...
Color Ink Cartridge
the support of both the cartridges is required to get a printout in this printer so if it is showing empty get it refilled properly to start printing again or buy new one.
Feb 23, 2008 | Canon MultiPASS C555 InkJet Printer
Color problem
Chances are your othe cartridges were low...
When you install a new cartridge your printer does a head cleaning, and it uses alot of ink...
If the others were low, your printouts will show magenta as its the only color left...
Feb 10, 2008 | Canon PIXMA MP780 All-In-One InkJet...
HP DesignJet 750c plus InkJet Printer Logo
537 people viewed this question
Ben Johnson
