Question about Acer Aspire 5100 Notebook
Boot hung up
I need the boot sequence is network, CD, and HD. I used PXE+Kickstart to install Redhat. Everything is fine until reboot it after installed the box. The booting is hung up at "Exit PXE ROM". It suppose to start to boot the box from HD, but it is waiting there forever. If I change the boot sequence to let boot the box from HD first. It works fine. I have severl different machines using the same method to install redhat. They work perfectly. My question is why the booting process is hung up at "Exit PXE ROM"? and How to solve it. Does the NIC has some defect?
Thanks,
Goodman
    Problem Solver:
  • 12 Answers
The NIC is fine, however it hangs because it is searching the network for boot information. This NIC's boot timeout is a lot longer than most.
Posted on Nov 11, 2008
HP proliant DL380 gen4 PXE-E61, when trying to install redhat and solaris.
First, it's not booting from a CD or Hard Disk if you've reached that error. The 'last-ditch' effort to boot is to attempt a PXE boot from the network card, but your Ethernet cable isn't plugged in. Unless you know you've setup such a PXE boot server, you'll want to check the BIOS settings to be sure the CD-ROM is set to boot first, followed by the Hard Disc. Be sure you have Disc 1 of the Linux installation set in the CD-ROM Drive and reboot. If you don't get the install screen, you may have another issue (bad CD-ROM Drive, bad cable/controller, no power to CD-ROM, etc.)
Another note on the DL380, if there is a RAID controller, you'll need to setup the RAID before installing the OS. You'll want to make sure your hard drives are properly installed and aren't failed. The RAID configuration screen will verify the RAID status once it has been initialized, which will somewhat verify the drive status.
Nov 12, 2013 | Computers & Internet
Hello, My laptop shows the following message when I turn it on- Realtek PCIe FE Family controller Series v1.19(08/10/09) PXE-EGI-Media test failure,check cable PXE-MOF-Exiting PXE ROM Reboot an
It can't locate a working boot disc. Most likely lost communications with hard drive. Look in BIOS again to see it recognizes the drive. If not try re-seating / reconnecting drive.
Feb 16, 2013 | Dell Inspiron N5010 Black
Laptop not booting
Your computer is trying to boot from a Network or Lan. You need to go into the Bios or System Setup and change the boot order or boot sequence.
Reboot the computer and notice what key the screen says to hit to get into the Bios or System Setup and hit that key. Change your boot order or boot sequence. The best sequence is to have the CD Drive 1st and the Hard Drive 2nd. Changing this in the bios or system setup will make the change permanent. Just make sure when you boot the computer that nothing is in the CD drive unless you have a repair disc or operating system disc in it.
You could make a temporary change but then you will have to change it every time you boot. If you notice the screen when you boot it also gives you the key to hit to change the boot order or boot sequence. This will allow you to change it just for this time that you are booting.
May 03, 2012 | Computers & Internet
I am replacing my Toshiba Satellite A35-S159 hard drive with a scorpio blue. the new HD is installed. when i turn on the laptop i get a flashing message. "pxe-e61 : media test failure, check cable pxe-m0f:...
In the BIOS, look in the boot options and take the "other devices" or "other" out of the boot sequence. Also check to see if boot from LAN is enabled. If it is, disable it. PXE is a protocol that will enable you to boot from a network drive or server. When it says that it failed, it is because it could not find an OS on the network
Jan 17, 2010 | Toshiba Satellite A35-S159 Notebook
I hav an acer aspire 4720z laptop ..... which is
I think there is a problem on the hard drive, you should formatting the hard disk using a third party, I usually use Hiren's BootCD that will be found at this link. you will download the file *. iso than burn to a CD, now try to boot from cd rom with that cd inside. later you will see some options there reply from the CD, choose partition magic. from here you will understand what to do next reply. may be useful.
Nov 16, 2009 | Computers & Internet
Booting M45 without HD/CD drive?
Only if that laptop has the option of booting from external drives or media ... some newer computers can do that.
I would just get another CD drive (CD/DVD) for it and replace the hard drive and re-install it.
I don't think I've ever PXE booted either ... besides what's the point of laptop that you have to PXE boot - you can't take your network on the road with you?
Oct 08, 2009 | Toshiba Satellite M45-S331 Notebook
When I try to boot up my Compaq Presario 2500 laptop I get the following error message: PXE-E61: Media test failure, check cable Operating System not Found. I have tried changing the boot sequence in the...
Boot sequence isn't enough. You have to turn OFF (disable) the boot from network. The error your seeing is result of the network boot rom not finding PXE server to boot from. Again, be sure to disable boot from network.
Jun 06, 2009 | Compaq Computers & Internet
Wont read HD
It could be that the the HDD controller on the motherboard is gone, that's why it does it with several HDD. By the way go under the BIOS and check the Boot sequence, make sure that HDD is first, because pxe error occurs when you select to boot the computer through a network device. If it doesn't find it, that's what it shows on the screen, it can find the MBR.
Apr 02, 2009 | Computers & Internet
Satellite not wanting to boot.... need help
Disconnect any USB or other external drives or network cables connections
Boot to your BIOS (F2) menu and make sure the boot sequence is set to boot first on HD or CD ROM (whichever you prefer).
Jan 04, 2009 | Toshiba Satellite P15-S479 Notebook
HP Pavilion DV1000 doesnt start up.
The unit is not finding any boot drives and is trying to boot from a network.
Make sure no disks are in a floppy or cd drive, and if so, remove and try to reboot.
You may have a dead or troubled hard drive.
Nov 19, 2008 | HP Pavilion dv1000 Notebook
Acer Aspire 5100 Notebook Logo
67 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
