Question about Seagate Barracuda 7200.10 500 GB SATA Hard Drive
Sata drive not detected
I have an Intel D915GAV motherboard with 2.8 Ghz processor. I have a Windows XP sp2 installed on 80 GB IDE Hard Disk. A few days back I installed Seagate 500 GB SATA Drive. Now I have two Hard Disks 1) Seagate 80 GB HDD (for OS); 2) 500 GB Sata HDD (for Storage).
The problem:
The system is unable to detect the Sata drive properly. It wents off while working. Even the BIOS is unable to show the SATA drives. But after a few restarts and Bios troubleshoots I am again able to gain access to the drive.
Solution:
I tried to update the BIOS with the latest version. The problem is solved for about 2 days, and from then onwards I am facing the same problem.
  • anoop28feb Oct 19, 2008
    1. mt sata hdd is not detecting nor the sata dvd writer
  • mirzamvali Mar 07, 2009
    I too have the same problem. My system is Intel(R) Desktop Board D915GAV, Intel(R) Pentium 4 CPU 3.0 Ghz, HItachi 80 GB SATA HDD. Recently a 750 GB SATA Seagate HDD was installed for storage purpose. The new HDD of 750 GB was detected for few days and now it is not. I shall be thankful if someone can give a viable solution to fix this problem.
    MIRZA VILAYAT ALI, HYDERABAD, A.P, INDIA
    My e-mail address: mirzamvali@rediffmail.com
  • 849 Answers
Just no other solution except upgrading BIOS properly
Posted on Oct 27, 2008
Windows xp does not install
If your hard disk is a SATA disk then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Jan 23, 2013 | AMD Phenom II X2 Processor 560 (3.3 GHz)...
I've zebronic 845 gl mother board, p4 2.4 ghz intel processor, samsung 80 gb hard disk,256mb hynix ram. when i run any program in windows xp sp2 , my system is hangged after few minutes, i press c
First you might need to have service pack 3
XP Service pack 3
http://windows.microsoft.com/en-US/windows/help/learn-how-to-install-windows-xp-service-pack-3-sp3
a slight overhaul of your computer
second clean your computer of dust using a fine air blower from a compressor specifically around your CPU central processing unit making sure there is no MOISTURE in the airline
as dust will cause a lot of static which will make a computer overheat and cause lots of problems
test or replace all the leads that attach to your hard drive including electrical extensions IDE SATA the ones that attach from your motherboard to hard drive make sure they have secure dust free connections
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
then click start run type cmd then type chkdsk/r/f which will automatically scan for and attempt to repair bad sectors and fix any corrupt files this will schedule to happen on restart
another way of running the chkdsk utility
click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start should schedule this task when restart
you should not do anything while the chkdsk utility is in progress any input may damage your computer your hard drive then defragment your hard drive
you have to keep a computer very clean & free of dust and give it regular maintenance
also you might download and use this registry cleaner it is 100% totally free to use
http://download.cnet.com/ccleaner/
and you might need to uninstall some unnecessary programs
right click in the bottom toolbar select task manager applications you will see whats running
also in processes see whats ticking over
do have any tune up programs installed on your computer
hope this helps
Apr 26, 2012 | Intel Computers & Internet
I can't install AUTOCAD 2009 in my windows XP computer.It asks to install direct 3D
Most probably your hardware ie graphic card do not support software requirements.
Autocad 2009 system requirements for Win XP.
32-bit AutoCAD 2009
Running under Windows XP:
•Microsoft Windows XP SP2 operating system
•Intel® Pentium® 4 processor or AMD Athlon®, 2.2 GHz or greater
or
Intel or AMD Dual Core processor, 1.6 GHz or greater
•1 GB RAM
•750 MB free hard disk space for installation
•1024x768 VGA with true color
•Microsoft Internet Explorer 6.0 (SP1 or higher)
If you are using AutoCAD for 3D modeling, you should bump up your system as follows:
•Intel Pentium 4 processor or AMD Athlon, 3.0 GHz or greater
or
Intel or AMD Dual Core processor, 2.0 GHz or greater
•2 GB RAM or greater
•2 GB of additional free hard disk space
•1,280 x 1,024 32-bit color video display adapter (true color) 128 MB or greater, OpenGL or Direct3D capable workstation class graphics card.
Hope it helps.
Mar 22, 2011 | Computers & Internet
Finding Intel 845GVSR & 915GLVG Compatible Motherboard & Proc
you can use intel dg41 mbd , dualcore processor,1 gb ram,160 gb hdd or use intel atom for support contact 91-9645071021
Aug 11, 2009 | Intel D845GVSR Motherboard
Sata hdd not Detect
To install Windows XP on SATA or advanced IDE hard drive, you will need to insert a driver diskette at the time of starting the installation process and pressing "F6". For more details visit the link below:
http://ufixitnow.blogspot.com/2009/04/oem-driver-support-during-windows-xp.html
Apr 09, 2009 | Microsoft Windows Xp Home Edition Sp2...
Unable to install RHEL5 in D101GGC
http://www.linux.iastate.edu/rhel5/...READ THIS IT WILL SOLVE THE PROBLEM.RICHARDM69
Nov 07, 2008 | Intel D101GGC Motherboard
Unable to detect 250GB Seagate hard disk on P4 PC
you need bios update
download bios express installation file
install first any 40 or 80 gb ide harddisk install windows and run express installation file
your motherboard will update your bios
download from http://www.updrivers.com/search/d845glly
or
http://www.updrivers.com/getdriver/Motherboard/Intel/D845GLLY-BIOS/10018.html
Oct 17, 2008 | Intel D845GLLY Motherboard
D845GLLY mother board unable to detect 250 GB SATA seagate hard disk
have u installed sata raid driver in Win XP ur system might not contain the driver for SATA drive pls download and install
http://downloadcenter.intel.com/T8Clearance.aspx?sType=&agr=Y&ProductID=2300&DwnldID=17268&url=/17268/eng/iata87enu.exe&PrdMap=&strOSs=45&OSFullName=Windows*%20XP%20Home%20Edition&lang=eng
pls rate me FIXYA if ur problem is resolved
Oct 16, 2008 | Intel D845GLLY Motherboard
Detection & installation problem
in bios ide configration selecl ATA select both ur sata HDD will be detected
Nov 28, 2007 | Intel Motherboard
Open Questions:
bricked hard drive? Would folling this lead to a full hard drive format or just unbricking a drive like people sat it does?? Also any other ways that might help would be great to know, heres what i'm talking about! "Fixing The Drive NOTE: Commands for you to type are in red boldface. Pay attention to upper & lower case - it is important. Turn on power to the RS232-to-TTL adapter and the hard drive. After a few seconds, Press CTRL+z. You should then see a prompt like this: F3 T> If not, swap TX & RX wires. Access Level 2 (type /2): F3 T>/2 (enter) F3 2> Then spin down the (disconnected) motor: F3 2>Z (enter) Spin Down Complete Elapsed Time 0.147 msecs F3 2> Very carefully, remove the cardstock that you placed between the PCB and the drive head contacts. Carefully replace and tighten the 3 loose screws. I suggest using a small piece of masking tape to help you hold the screws while you put them back in place. Then start the motor: F3 2>U (enter) Spin Up Complete Elapsed Time 7.093 secs F3 2> Next go to Level 1 (type /1): F3 2>/1 (enter) And do a S.M.A.R.T. erase (create S.M.A.R.T. sector): F3 1>N1 (enter) Cycle power to the drive, then do partition regeneration: F3 T>m0,2,2,0,0,0,0,22 (enter) After 15-30 seconds, you should see something like: Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewrite Retries = 00C8 User Partition Format 10% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 00000080, Elapsed Time 0 mins 05 secs User Partition Format Successful - Elapsed Time 0 mins 05 secs Do not turn off drive until you see this message. Once seen, drive can be turned off. Power down everything, place drive back into your computer, and confirm that it's working." Thanks.
Apr 12, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate Barracuda 7200.10 500 GB SATA Hard Drive Logo
1,375 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
