Question about Panasonic DMR-ES35VS
Dvd/vcr combo Panasonic dmr-es35vs
The display says SET 1 and will not do anything. When the channel button is pressed it just goes back to the set 1. Any ideas? The remote or the player?
  • 3 more comments
  • Anonymous Oct 01, 2008
    mine too!
  • Anonymous Oct 03, 2008
    how do you fix this
  • jeffingrid Oct 05, 2008
    I have the same problem...the vcr works without the remote but will not work with the remote.
    jeffingrid@wi.rr.com
    JEFF
  • sloanlake Dec 20, 2008
    I have the same problem.  My original panasonic controller will turn my TV on and off, but not my player.  It says Set 1 each time I try any function.
  • Anonymous Jan 11, 2009
    thank you!!!!!!!!!!!!!!!!!!!!
I also encountered a similar problem and did some research on the internet. The way to fix this problem is hold the 'Enter' key and while holding the enter key, press number 1 for a few seconds until the display changes to C1 or SET 1 error goes away.
This should fix the problem. Atleast it worked for me. All the best!!
Posted on Oct 26, 2008
  • mldkz
    mldkz Jan 08, 2012
    Thank Yoooooouuuuuu It worked for me to!!!!!!
PROBLEM SOLVED
Posted on Dec 25, 2008
3 Suggested Answers
SOURCE: WHEN I TRY TO USE
I called tech support and their answer was simple!
Error Code U30 1.......the fix, press and hold the number one (1) on your remote and at the same time press and hold the ENTER button for 10 seconds while pointing the remote at the units sensor.
Automatically, my unit returned to normal and all my buttons on my remote returned to operational mode!
So, it was confirmed by Vincent at Panasonics tech support, that error codes U30's are rare, but it's a system safety feature. If you were to come across an error U30 2, you would push and hold the number 2 while pressing and holding down the ENTER button....so on and so forth.
I hope this helps someone else out there!
Shelley
Posted on Jan 08, 2009
Bati99
  • 88 Answers
SOURCE: panasonic dmr-es35v
Is the Remote Control sensor in direct fluorescent lamp light or other strong
sources of light?
Press unit POWER button down over 7 seconds. The POWER indicator goes
out. If the Power was On, the screen will also disappear. After 5 seconds, turn
Power On and operate unit normally. If the steps above do not restore normal
operation, disconnect then reconnect the AC plug and turn the power On.
If that does not work, Panasonic offers free tech support 6 days a week 1-800-211-7262 (pana).
Posted on Apr 19, 2009
Panasonic DMR-EZ47V DVD Recorder / VCR Combo RC1 errior message how do I fix this problem
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ47VK
http://www.retrevo.com/support/Panasonic-DMR-EZ47-DVD-Players-manual/id/2811ag420/t/2/
To get into Service Mode, first put the machine in STANDBY mode, then press the buttons ChUp OPEN/CLOSE and REC all at the same time on the front panel (Ch Up is hidden inside the AV3 input flap). Eventually the front panel display will show "SERV" (after its "HELLO" messages). Anyway, pressing [6] then [5] on the Remote Control tells me that I have an Error Code of "04" which is a Digital PCB or Communication Error (whereas an Error code of "02" means a "Defect of RAM drive"). (To exit from Service Mode, press [0] then [0] which should get you back to "SERV" and then POWER-OFF the machine).
Hopefully, your manual will display your error codes.
Perhaps the remote control is not set to the same control code as your DMR-ES40V. Codes may be set to 1, 2, or 3 on the remote by holding down the enter button and one of those number buttons for several seconds at the same time. The factory default is code 1. Try 1 first. If that doesn't work try 2. If that doesn't work try 3. If one of those codes doesn't work you may have a bad remote or a bad sensor on your machine. On DMR-ES35V models the sensor is located just to the right of center behind the black window
Jun 23, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic dmr-es35v dvd/vcr recorder reads hello, then u61, then
Plug AC power cord to wall electric socket if it is plugged into a surge protector or extension, if not try a different socket, if issue still exist have unit service.
Sep 20, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-ES45V - DVD recorder / VCR combo Remote not workin
My remote is not working. When I press a button, I get the following message on my unit: U12, U30, SET #, CHK REMOTE #, or RC #. What can I do to fix this? The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
Jun 04, 2009 | Panasonic DMR-ES46VS DVD Recorder/VCR
Panasonic Dmr es35v VCR/dvd recorder 'Set 1' problem
Feb 10, 2009 | Panasonic DMRES15 DVD Recorder
WHEN I TRY TO USE MY REMOTE CONTROL ON MY PANASONIC VCR/DVD COMBO MODEL #DMR ES35V, THE DISPLAY SHOWS U30 1 AND WON'T WORK THE VCR/DVD. CAN YOU HELP ME?
Shelley
Oct 11, 2008 | Panasonic DMR-ES35VS
Panasonic DMR-ES35V
I have a dmr-ez25eb DVD recorder and it has stopped Recording and playing back , the screen on the TV says that its a none recordable disc but I have been useing them from the time I purchased the DVD
Aug 31, 2008 | Panasonic DMR-ES10 DVD Recorder
Romote control not working
1. The owner's manual is available online:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-ES35VS
Download the manual under Operating Instructions.
2. To remedy "SET1" problem, Press 1 & Enter at the same time.
Hope this helps
Aug 10, 2008 | Panasonic DMR-ES35VS
Panasonic dmr-es35v
sources of light?
Jul 29, 2008 | Panasonic DMR-ES35VS
Getting set 1 code displayed
the code on your remote is mismatched to the unit. Your owner's manual on page 19 will have the cure. In brief, press enter and "1" together for about two seconds. hit enter again and this should fix the problem.
Jul 12, 2008 | Panasonic DMR-ES35VS
Problem with remote
This fixes the *Set 1* problem. Set 1 means the remote cannot communicate with the Panasonic DVR. If the batteries go out on the remote replace the batteries stand in front of the Panasonic DVR, press and hold the "1" button and the *enter* button at the same time and hold for 10 seconds.
May 21, 2007 | Panasonic DMR-ES35VS
Panasonic DMR-ES35VS Logo
338 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
