Question about SAMTRON 55V 15" CRT Monitor
Control lock meassage come out in the screen
"CONTROL LOCK OR UNLOCK" MEASSAGE COME OUT IN THE SCREEN. MENU KEY AND ANY KEY OF MONITER IS NOT WOKING.
PLS. REPLY AS SOON AS POSSIBLE FOR RECTIFICATION PROCESS.
  • 151 Answers
Its aproblem of command section.Check its components one by one.you can identify this section (the front panal buttons goes in this section and a ic in big size and pasted horizantally in the circuit).if the components are ok then change command ic with new one.This will solve your problem
Posted on Sep 28, 2008
How can I unlock the function keys without the remote control?
Hi
How to Release the System Lock
Turn on the power. If the system lock is applied, the system-resetting screen appears. Press the following keys in this
order.
MENU ? ENTER ? ENTER ? MENU ? UNDO ? UNDO ? MENU
After pressing the MENU key first, press the remaining six keys within 10 seconds.
Mar 19, 2016 | Sharp Notevision PG-M20X Multimedia...
How do i get my tablet screento rotate
What type of tablet? If it's an iPad this is available a few different ways.
If it's an iPad 1 running on iOS5:
1. Check the little toggle switch on the side, depending on your settings this functions as both a mute and a rotation lock. Try changing this.
2. If your toggle was set as a mute control and not a screen lock then the screen lock is kind of hidden. Double click the home button and when the little menu pops up swipe right on it, you should see an option to lock/unlock the rotation.
If you are on a newer iPad
2. f your toggle was set as a mute control and not a screen lock then the screen lock is kind of hidden. Swipe up from the bottom of the screen to access the control panel. The screen lock/unlock option is directly on the control panel.
Dec 11, 2014 | Tablets & eReaders
Zenith Z42PT320. I set parental lock code for my son and forgot password. How do I reset or retrieve?
Zenith TV unlock [Child lock]
Tune the television to a channel blocked by a child lock. The words "Enter Lock Code" will appear on the screen with four dashes underneath
Press the numbers on the remote control to enter the child lock pass code to unlock your Zenith television. When the code is entered correctly, the blocked channel becomes visible. The words "Enter Lock Code" remain on the screen if the password is not correct
Enter "0000" if you did not change the password on the television prior to enabling the child lock feature. This number is the default pass code for the child lock.
Push "7777" if you changed the pass code for the television but no longer remember the code. This number allows you to bypass the child lock and watch the programming.
Key lock
Press the "Menu" button on the remote control to access the "Main Menu" screen on the television.
Scroll to "Special" using the up or down arrow buttons and press the right arrow button to access the "Special" sub-menu.
Push the up or down arrow button to highlight "Key Lock" and then press the right arrow button.
Press the up or down arrow button to change "Key Lock" to "No" and then press the "Menu" button to save the setting.
Wish to get more? http://electrohelponline.blogspot.com/
Jun 07, 2013 | Televison & Video
How to turn off child lock without remote control jvc lt-32sh6
Press the "Menu" button to set the lock code for your JVC TV. A padlock icon will appear on the menu display.
Press "Zero" to access the lock code function then use the left and right arrows to select the four-digit number for your code. Use the up and down arrows to move to the next area of the display.
Select the up or down arrow to finish your lock code then use the left or right arrow to save your lock code settings and exit the menu. You can return to this display if you forget your four-digit lock code and set another code.
Write your four-digit lock code down and keep it in a safe, private area.
Select the locked TV channel you desire to watch or want to unlock. A message will appear on the display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by entering your lock code on the 10-key pad. The message "Invalid Lock Code!" will appear on the screen if you enter the wrong lock code.
OR
Select "TV" from the menu then select "V-Chip" from the drop-down list on the screen. "Please Input Password" will appear on the screen.
Enter your four-digit password by selecting numbers on the 10-pad that appears on the V-Chip menu display or your remote control. Create a new password if you forget it by unplugging your TV power cord from the outlet then reconnect the power cord. This procedure resets your password to "0000." Enter four numbers for your new password using the keypad on the screen or your remote and select the arrow to advance to the next number. Press "OK" on your remote or select "OK" on the screen to set your new password.
Unlock a TV rating or TV channel by selecting "MPAA" or "TVPG" from the V-Chip menu. Use the up or down arrows to select the locked rating then select "OK" on the display or press the "OK" button on your remote control to unlock it. The MPAA represents the U.S. Motion Picture Association of America rating system, such as "NC-17," meaning not intended for viewers 17 years or younger.
Nov 01, 2012 | Televison & Video
A konica 7030 displaying a meassage " remove paper from the exit tray" on the screen, how do i fix it? tnx
check if there is a paper at your exit feeder try. at the fuser.
if not. see if the paper sensors are not stuck.
Nov 15, 2011 | Office Equipment & Supplies
There. Is a channel lock on my tv. So I can't change the channels. How do I take it off?? Help!
Hello
you have to unlock your jvc set, and reset the V-Chip settings. There are two ways to unlock JVC TVs, you have to find out which proceedings frome below mentioned will work with your TV.
[1]
[2]
Unlock a TV rating or TV channel by selecting "MPAA" or "TVPG" from the V-Chip menu. Use the up or down arrows to select the locked rating then select "OK" on the display or press the "OK" button on your remote control to unlock it. The MPAA represents the U.S. Motion Picture Association of America rating system, such as "NC-17," meaning not intended for viewers 17 years or younger. TVPG provides you
May 10, 2011 | JVC AV-27020 TV
Lock the channel.than how to unlock
Hello
T unlock your Apex TV do the following. Apex TVs use a four digit code to control the V-Vhip. For most models it is 6688. Other sets may not have one, or may have a default lock code 1225 instead of an override code.
To use the override code:-
Press menu key to get into Menu.
Go down to the 'System' menu, and hit the right arrow on the remote control.
Once in the system menu go for "parential Guide" It will ask you the code.
Enter the override code listed above. From here you can turn ON and OFF different rating settings and to set a new code.
No matter what the V-Chip code is set to; the override code will work. If you have a blank screen, showing a red Key on the bottom left side of the screen, simply press the [Function or F] button togetherwith mute button at the same time. This will unlock the screen and allow you to view the channel as you desire. OK.
Apr 08, 2011 | Apex Digital PF2020 20" TV
Control lock
Temporarily you can -- hold down, while monitor is on and the menu button for 10 seconds (source Samsung faq). This hould unlock the buttons.
This problem is due to abad 7805 regulator ic ora memmory ic
To completely stop this you will have to replace the 5 v regulator
Jun 09, 2008 | SAMTRON 55V 15" CRT Monitor
Apex tv pf2030 child lock
I'm afraid you will need the original remote control hand unit folks. Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
  1. To use the override code:
  2. Hit the MENU key to get to the menus.
  3. Go down to the SYSTEM menu and hit the right arrow on the remote control.
  4. Once in the SYSTEM menu, go to PARENTAL GUIDE. It will ask for your code.
  5. Enter the override code listed above. From here, you can turn on and off different rating restrictions, as well as set a new code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired
Jan 19, 2008 | Apex Digital PF2025 20" TV
SAMTRON 55V 15" CRT Monitor Logo
124 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
Richard Lilja
Richard Lilja
William Miller
William Miller
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
