Question about Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive
Acomdata is Kaputz
Can you help. It is not recognized on my PC. It also was clicking and running noisy.
Thanks
JM
  • 304 Answers
The clicking and running noisy is a bad sign. The actual drive in the unit has failed. Sometimes the controler board in the external case goes and you can simply replace the case for $10 online and be up and running. I'm a data recovery expert. If you have irreplacible data on the drive that you need recovered let me know. I'll recover the data for you I have all the required equipment. The only thing you need to pay for is the exact same make and model of the internal HD in the case and postage both ways. I'm retired and I do this for a hobby now. Let me know if you need me services. Hope you find this helpful. My e-mail address is geokohler@gmail.com if you want to send me your number and we can discuss the procedure.
Thanks,
George
Posted on Sep 25, 2008
Acomdata is only clicking but is not being recognized by computer
Sorry to inform you, that once your hard drive clicks, it's already dead and unusable. It is called the "Click of Death" for hard drives.
You may want to try bringing your HD to the nearest data recovery center and see if they could recover the files from the HD to another media.
Thank you and good luck!
Aug 03, 2010 | Acomdata Computers & Internet
Acomdata HD120U2FE-72 120 GB external Hard Drive
OK, 2 things to check. First and foremost, when you plug it into the PC does it make that nifty noise to let you know it sees a new piece of hardware?
Second, if it does, you probably need to initialize the disk. Hit the windows button, right click on computer, and select manage. Under the storage category highlight Disk management. If you see the drive there, you can right click and select initialize, or format. From there the system should see the drive.
Feb 06, 2010 | Acomdata HD120U2FE-72 120 GB Hard Drive
Acomdata 250 external (SATA) hard drive not showing up on desktop
be safe
go on line to acomdata web site and down load the driver from there
Oct 11, 2017 | Acomdata (HD250SE5-72-PCI) (HD250SE572PCI)...
My hard drive is recognized but won't open on my win xp pc. everything runs slow when i have it on. back to normal instantly when turned off. please help.
may be your xternal hardrive wasnt alocated..
try to allocate it
start>my computer (right click select manage)>click disk managment ( look at the right area below) > see the black line with non allocated> right click then allocate > select extended then next .. the black line will turn into green.. you hard drive now could recognized with your pc.
Aug 06, 2009 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
Problems with Hard Drive
Appreciate the direct "Ask Me".
T your concern:
  • initially, pls verify that it is indeed an external storage problem rather than a laptop USB issue by trying other USB devices and determine if they are recognized and working;
  • disassemble the enclosure of the Acomdata external hard drive and remove the actual hard drive;
  • you would need the use of a 2nd PC, a desktop that could accommodate the HD from the Acomdata (IDE or SATA);
  • install the HD from the Acomdata as a Secondary Master or Slave internally to the 2nd PC;
  • boot the 2nd PC and determine if the HD from the Acomdata will be recognized as a local drive;
  • chances are that the partition of the HD from the Acomdata was messed up. This would explain the blinking blue light;
  • download and install a file recovery program. An example is GetDataBack (unfortunately not a freeware but DEMO is available) and do a recovery. It would take some time based on the size of the HD from the Acomdata;
  • temporarily save the recovered data in the 2nd PC. You can burn this likewise into a DVD backup should the 2nd PC be capable of that;
  • after recovery, re-partition and format the HD from the Acomdata while still attached to the 2nd PC;
  • should the re-partition and format be successful, you can transfer back the temporarily saved recovered files;
  • a nice, simple, fast and safe partitioning/formatting software is Partition Magic (unfortunately not a freeware but FREE TRIAL is available).
  • should the re-partition and format be not successful, you can replace only the HD and/or claim warranty.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 01, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Wont recognize drive
Try checking your power cord adapter.
I found the same problem was with the cord.
Luckily, I had another Acomdata HD cord to check the problem.
Aug 19, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Acomdata PHD160 didnt work for Window VISTA
My probleme is who to get drivers to install it on my PC.
Thank you.
May 09, 2008 | Acomdata PHD060U2E-54 60 GB USB 2.0 Hard...
External drive recognized as CD drive
You need to do a firmware flash. It worked for me. Here's the link to the fix.
http://www.techsupportlive.com/index.php?_m=downloads&_a=viewdownload&downloaditemid=29
Mar 13, 2008 | Acomdata HybridDrive E5 Hard Drive
Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive Logo
300 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
