Question about Avion AV-DVR100 DVD Recorder
Playing a VCD
Just tried to play a VCD I made minutes before on my PC. The DVD player/recorder recognizes it, brings up the screen where I can choose which section I want to play but has this message "PBC ON" briefly on the screen and also on the dvd player/recorder readout.
I can find nothing in the manual concerning what PBC is, nor do any of the remote (or player) buttons respond.
Any ideas?
I have a Sony trinitron model KV 2135M3 and I have just bought this Sony DVD player (SR 200p). When I watch VCD the color is clear and excellent but when I use dvd the color automatically changes to black...
dear your tv have three color systems and when you play vcd which is recorded in pal and you watched color when you play dvd which is recorded in ntsc system which is not available in your tv so you watch as black and white
Feb 10, 2018 | Sony Televison & Video
ONIDA DFX-7100 DVD player unable to play VCD/CD
dvd player s-video pin use to tv tuner card
May 18, 2010 | Televison & Video
I am trying to record with a sony dvd-r disc and the recorder don't recognize it. the only disc that works is the dvd ram 4.7 but that disc does not work on other standard dvd players. what is the answer?
According to the official description of that recorder, you should have no problem, this is from the description for the DMRES15:
Recordable DVD Media
Record your favorite shows onto DVD-RW, DVD-R, DVD+RW, and DVD-RAM DVD discs. The DMR-ES15 is also compatible with DVD+R Double layer media and provides up to 14 hours of media recording.
Multi-Format Player
Don't worry about limited playback capabilities, the DMR-ES15 can play DVD, DVD-RW (VR Mode), DVD-RW (Video Mode), DVD-R, DVD+R, DVD+RW, DVD-RAM, VCD and CD-DA discs. Also, you can play your favorite songs from CDs or MP3 files, and JPEG images.
Nov 29, 2009 | Panasonic DMRES15 DVD Recorder
Our Canon video camera will record in both HD and SD. We've recorded all of our video in SD so far and I burned some of it onto the Canon DW 100 burner and I can't get it to play on my DVD player. please...
You should burn your videos to a video format that should be compatible with your DVD player to get play. Some video formats will not be able to play to a certain DVD if the DVD player does not support it. You should burn your videos to VCD format to avoid problem because almost DVD nowadays have backward compatibility for all VCD movies. Hope this could help you..Please don't forget to rate me..:-) Thanks..
Nov 04, 2009 | Canon DW 100 DVD-RW Burner
Dvd-vr375dvd not playing some discs
try cleaning the lens but be careful when doing this,also your dvd machine may not be compatible with other disc formats, normal dvd players can only play dvd video and some vcd. Not all dvd players will play DVD-R/Rw or DVD+R/Rw discs, check your owners manual.
Aug 14, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
I have toshiba dvd recorder,the problem is the recorded dvd cannot play with other player. Do I have to return this recorder as it just a week away since i buy it
Make sure you Finalize the disc when you are done recording, otherwise it won't be read on other players or computers. To do this you go to Setup> Disc and choose Finalize. It takes a few minutes per disc, don't turn off the player while it it finalizing. In the same Setup menu you can choose an option to autofinalize the disc when you are done recording, so you do not have to to it manually each time.
Dec 07, 2008 | Toshiba D-KR10 Multi-Drive DVD Recorder
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Recorded a DVD on computer but will not play on DVD player
dvd players play only certain kinds of discs and formats. Older ones played -R's, most newer ones play everything. You have to look in manual, or on box before you buy player. If it won't play -R,+R, -RW,and +RW's I pass it by. Find out if your player is limited to certain discs. Some will play VCD and some will not. Some will play DIVX and some will not etc. Stick to the discs and formats your particular player is compatible with.
Nov 29, 2007 | iLO DVD Recorder DVDR05
"no disc" message
sounds like you have a problem with the laser.laser has to focus a lot sharper to play dvd thus will play vcd but not dvd.Try cleaning first and if this doesnt work would suspect laser faulty,.
May 29, 2007 | Cyberhome CH-DVD 300 DVD Player
Avion AV-DVR100 DVD Recorder Logo
Top Avion Televison & Video Experts
Are you an Avion Televison and Video Expert? Answer questions, earn points and help others
