32lcd. When turned on it display vertical colored lines and then they all fad away to a blank lit screen. All voltages normal.
  • burett Sep 24, 2008
    Model ns32lct mfg 2006
    Lcd brand is INSIGNIA; mfg is unknown
    Novelist:
    Champion:
  • 203 Answers
What is the model number?
Posted on Sep 24, 2008
  • experttv
    experttv Sep 24, 2008
    What manufacture is that?
  • experttv
    Most likely is a bad main board and in order to fix it you will need to replace it. The only other possiblity would be the lcd panel itself being bad but i doubt it, if this were bad the whole set would need to be replaced. I am having trouble finding you a part number for the main board. If i find one I will post it here. Anymore questions, just ask!
    Tim Nolan
Samsung LED TV, Model# UN55B6000VFXZA turns on to black screen then displays large blocks of colored vertical lines?
check every flat cable main boerd to t-con t-con to display if dont help display is a problem
Feb 24, 2017 | Samsung Televison & Video
How to fix Multi color Vertical Lines on a Vizio E470i-AO TV
Does the menu function display the same lines? What kind of cables are using ? (HDMI, Component vid, S-video, co-ax)
Were you as tenacious checking all cables/connections as you were the electronics? Lets rule out this all too often over-looked possibility.
Do you still get the lines with nothing connected to the TV? (no source connected)
Feb 28, 2016 | Vizio E-Series E470I-A0 47" LED TV...
Half screen in blank
Check and replace its back-light inverter board. Contact any service technician. If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Jan 28, 2014 | Vizio M421nv 42 Edge Lit Hz 1080p Razor...
Sound no picture
A educated guess here (model is a rather old Sony) this set will blank or shut the tubes off if loss of vertical or horizontal deflection---the slight line at top suggests vertical
What I have done to confirm this is either use a scope and check for deflection or turn blue screen up slowly(blue is less likely to burn the tube screen) and see if just a line.
The set blanks the tubes to prevent a line being burnt instantly at normal brightness (all concentrated into a line) on the face of the tube.
If you are technical and have a volt meter you may be able to locate online a free copy of the service manual to check voltages etc.
Dec 03, 2012 | Sony KP-61V85 61" Rear Projection...
Verticle lines appearing near top. Reminiscent of more extensive problem a few years ago that repair man said were related to electronic equipment used nearby such as vacuum cleaner. He fixed it with...
Case 1:
If the horizontal lines are red, green or blue or white, and are slanted about 15 degrees up going left to right, they are "vertical retrace" lines. These are caused by the beam current in the offending gun being left on while the vertical deflection is retracing from the bottom to the top on its way to start drawing the next frame. The usual cause is the CRT screen setting being too high (too bright), but (rarely) it could be something wrong with the vertical blanking circuit. Since it is dependent on vertical position, I would check the power supplies feeding the vertical deflection circuit and the CRT bias voltages, especially if they share the same filter capacitor.
Case 2:
If the lines are true horizontal, and colored similarly to the picture (sometimes alternately white and colored the same as program material), the top of picture is folded over itself because of over-voltage distortion ("clipping") in the vertical drive. In this case, reducing the height of the picture also reduces the fraction of the picture with the lines, and may eliminate it. If you are unable to get a full-height picture without the lines, then you should check the vertical deflection circuit for leaky capacitors (also check the power supply voltage going to it).
Case 3:
Several times I've observed bright white lines with random interruptions at the top of a picture supplied by the local cable company. These often occur on one or a few channels for a time (once or twice I've seen it on all channels), and go away after a while. This is a glitch in the cable service.
Case 4
You have a zone of weird colors at the top of the screen. This is probably caused by magnetization of the shadow mask inside the front of the picture tube that is not being erased when the TV is first turned on. Check to see if somebody left a magnetized object on top of or above the TV (look behind the set also). If you find something remove it, turn off the TV, wait a few minutes, then turn it on again. (Explanation: the TV has an internal demagnetizing coil that operates only when you first turn it on. It uses a self-heating temperature-dependent part to gradually reduce the alternating current going through it to override and "fade out" any stray magnetism in the shadow mask.) If the internal demagnetizing (AKA degaussing) coil isn't strong enough, you'll need that "ghostbuster" gadget again. If you don't find an external magnetic source, the internal coil may have slipped out of place at the top of the picture tube and is too far away from the shadow mask, or something is wrong with the degaussing circuit.
If none of these cases match what you see, try a more detailed description of the lines and I'll give it another shot.
Nov 27, 2010 | Sony Televison & Video
Screen show vertical lines from center to left. I open the front bessel and everything looks ok but when i apply some presure to the upper center between the two latches. that will make the display be...
Do the lines go away with the bezel off? You could put a piece of foam on the screen behind the bezel. Sounds like something is loose and if you can't tighten it, you possibly can keep the pressure on the screen to keep the display normal.
May 24, 2010 | Dell InspironTM 1501 Notebook
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
Monitor: Compaq TFT5015 Displays vertical lines
Check that the signal cable from the computer is firmly connected and that there are no bent pins in either end. If the trouble continues, the problem is in the monitor itself. Given the low replacement cost, it's uneconomical to try repairing these.
Apr 13, 2009 | Compaq TFT5015 15" LCD Monitor
Panasonic TV-Sound but no picture.
    According to the symptoms, There is a problem in vertical out section.Just check it there must be a capacitor that has been burst or leak.And second one reason could be the malfunctioning of vertical IC.Which is also in the vertical section.
Thanks for using fixya.
Dec 01, 2008 | Panasonic CT-27D12D 27" TV
Hp pavilion f1523 lcd monitor
You are not alone with this problem. Some lines (like mine) run vertically rather than horizontally. The solution - sue HP. These screens have a known fault ie the Nvidia graphics chip is known to be the culprit. The company knows all about this issue but expect us to pay to put it right - sue them, you can do it online for around £35 (UK).
Oct 02, 2008 | HP Pavilion zd8000 Notebook
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
