Durabrand CD Home Music System Model hm3817dt
Just purchased this cheap system. Popped cd in player and it sounded pretty good for about 1 mnute. The sound just quit. I only had it up to about 20 on the volumne control. At first, it sounded like the cd was skipping but it was also a brand new cd. Then after the skip sound, the speakers just went dead. I checked the connections and they all seem to be okay. I tried to play the radio but there is no sound either. Any suggestions other than taking this product back to Wally world.
  • 2 more comments
  • gandl65 Oct 03, 2008
    Sound quits after a minute,then comes back on periodically.Almost like it is skipping on the disc,but the disc is good after playing it elsewhere. The radio works fine so it is only the cd component.
    Larry
  • Anonymous Oct 15, 2008
    Does not work after working for a month. Any ideas how to get working since it is not under warranty again?
  • matty21386 Nov 08, 2008
    had for a couple months and worked fine. Now no sound from cd, radio, or aux....and cd player wont even OPEN.
  • kashifashar Feb 26, 2009
    Same Issue
  • Audio Player... Master
  • 5,342 Answers
If the unit is not under warranty then you can open it and have a look inside. Keep your eyes peeled for bad soldering joints and if it is dusty clean it out.
However if it is under warranty and you open it, then you will break the conditions of the warranty and if it needs repairing then you will be charged the full amount.
Posted on May 29, 2017
4 Suggested Answers
treefrog75
SOURCE: Durabrand HM3817DT
Just in case you try to follow directions like me, make sure that you have removed the cover inside the cd slot. No, directions aren't great. They are as difficult as any I have ever seen, but when I tipped the unit up, I saw a note on the bottom of the cd shiny cover that says remove before playing. After removing the flat cover press the button to turn the light off. Light on means standby, not on. Insert cd and push function. Then push play/pause button on right. Hope this helps. If not, return to store.
Posted on Dec 26, 2008
  • 18 Answers
SOURCE: WEAK SOUND WHEN CONNECTED TO DURABRAND AMP
The electrical output from a turntable actually comes from the cartridge on the tone arm. Specifically, it's generated by an interaction between a magnet and a coil inside the cartridge. They come in two types, MC ("moving coil") and MM ("moving magnet") according to which of the two elements moves and which is fixed. MM cartridges produce more current but MC cartridges usually sound better. No matter which you have though, the total output is too low for the regular line inputs on amplifiers. Ten or twenty years ago, amps has special "phono" inputs. This would have a special pre-amplifier in it that would amplify the cartridge's singal to a level suitable for the rest of the amp. Most amps having a phono input only deal with MM cartridges, which have a higher signal.
I use an MC cartridge with an amp that doesn't have a phono input at all; therefore I needed to buy a special external phono pre-amp. I bought a Musical Fidelity X-LPS. But cheaper pre-amps do exist.
Posted on Apr 13, 2009
  • 9 Answers
SOURCE: Durabrand model HM3817DT radio/CD player- cd eject,radio volume
Durabrand products are prone to alot of problems!!! In other mords they really ****!!!
Posted on Aug 25, 2009
Volume defaults to 17 when turned on
My durabrand (model no. hm3817dt) always default to volume 17 when I turn it on. Any ideas?
Oct 24, 2009 | Audio Players & Recorders
My durabrand cd home music system wont come on
If you have no lights or power to the unit, check on the back of the unit to see if there is a twist and pull type knob for a fuse. If so, unplug the unit/player and take the fuse out. If it is damaged/broken/wire element burned/cracked, it will need to be replaced. Take the old fuse with you to make certain of a correct match(volt/amp/slow or fast acting)Most Radio Shack/Walmarts/Ace Hardware stores stock these type of fuses. They are very inexpensive, usually less than a $1 or $2. They are on most home entertainment equipment/t.v.s etc. to prevent some degree of lightning or power spike damage the unit.
Oct 13, 2009 | GPX HM3817DT Shelf System
Aug 24, 2009 | Audio Players & Recorders
HM3817dt
You will not believe it, but he solution if Homer D'OH! simple. Had the same thing, until I realized that what I thought was the CD hold spindle is acually a cardboard protector for the CD components. It seems to be a very flexible CD player "face" correct? It's actually removable cardboard - pull it out and the CD components are now exposed. The CD will properly mount on the spindle...has pretty good sound.
Feb 19, 2009 | GPX HM3817DT Shelf System
Default volume for durabrand hm3817dt
It appears there is no "good solution."
BUT! I didn't discover that this unit is not actually made by Durabrand. It's made by GPX and I've included a link to the user manual for this product (It's the same model, but the GPX version is black and sports the GPX logo).
http://www.gpx.com/owners_manuals/HM3817DT-IB.pdf
Dec 27, 2008 | GPX HM3817DT Shelf System
Durabrand CD Home System Model # HM3817DT - suffix no: E1/M1
if i turn my cd home system of i will have problems so it can turn on back. what can i do
Sep 01, 2008 | Durabrand STS92 System
CD Home Music System HM3817DT
Try a laser eye cleaner. It possibly may need to be dusted on the inside. Overheating can cause strange things to happen to electronics.
Jul 15, 2008 | Durabrand Anti-Skip CD-895 Personal CD...
Durabrand CD Home Music System - Volume default
HM3817DTBLK:Default volume
I sent a note to the manufacturer. Communication attached below.
Dear Customer,
We thank you for your interest in GPX and our products. We apologize, but the volume level on the unit is a factory setting that we are not able to override or alter.
Once again, we apologize for any inconvenience this may have caused.
Best Regards,
GPX Consumer Service
>>> "Chris" 12/27/2008 2:02 ">x.x@eds.com> 12/27/2008 2:02 >> PM >>>
The default volume is set way too high on this radio. It is at 17 and we would like to reset it to a much lower level. How do I do this?
Chris
Jan 08, 2008 | Audio Players & Recorders
7,691 people viewed this question
 Grubhead
Grubhead
