Question about Sewing Machines
HOOK TIMING ON BROTHER CE-4000 SEWING MACHINE
HOW DO I SET THE HOOK TIMING ON A BROTHER CE-4000 SEWING MACHINE?
  • 136 Answers
SOURCE: need to retime singer ce-200 sewing machine
What you really need is a sewing machine tech. You are trying to time it the wrong way. The hook tip should be just above the eye of the needle when the needle is in the extreme left hand position
Posted on Jul 12, 2009
SOURCE: Set the timing
bbragg77 solution lacks a few points that I found out after talking to someone who repairs the machines.
Turn the balance wheel (counter-clockwise) so that the needle moves down and the hook is supposed to be spinning counterclockwise. As the needle reaches the bottom and starts to come back up, stop when the need reaches approximately 2 mm off the bottom. In this position, the point of the hook should be directly behind the needle.
Posted on Jul 25, 2009
  • 371 Answers
SOURCE: husqvarna sewing machine - viking 400
Take to authorized Husqvarna Viking dealer for repair. This is not something that can be done by the owner. Check Husqvarna Viking website for dealer closest too you.
Posted on Sep 24, 2009
  • 980 Answers
SOURCE: brother sewing machine circuit board is out need new one
If you have any problems with sewing machines with electronic boards or if the machine is computerised it is wise to take it to a specialist for repair.
Posted on Nov 04, 2009
  • 980 Answers
SOURCE: Replaced the hook gear in a singer 720 sewing
email me drivewithken@blueyonder.co.uk and I will attach timing instructions
Ken
Posted on Nov 25, 2009
E1 error brother ce 4000
Hi.
You can get the E1 error if the presser foot is not down. If you use the walking foot attachment it can keep the foot from coming all the way down.
Apr 08, 2017 | Brother CE4000 Computerized Sewing Machine
Where can I find this board model#XE 7316001 for a brother CE 1100PRW computerized sewing machine?
somewhere like this or direct from Brother
http://www.brother-usa.com/homesewing/
Brother - Machine Accessories (feet, needles,globes,spare parts ...
www.sewingmachinewarehouse.com.au/machine...needlesglobesspare-parts/brother/
  1. Cached
  2. Similar
Sewing Machine Warehouse are authorised dealers for Pfaff, Singer, Brother, ... Parts and Accessories to suit Brother Machines. ... 7mm- For machines with a 7mm stitch width (feed teeth are set wider) ... Brother Open Toe Free Motion Foot. Missing: ce ‎1100prw
Brother Sewing Machine Parts & Brother Serger Parts
www.sewingpartsonline.com/brother-sewing-machine-parts-model-list.aspx
  1. Cached
  2. Similar
We have a very large selection of genuine and replacement Brother Sewing Machine & Serger parts available. If you can't find the Brother Part(s) you are ... Missing: 1100prw
Brother Sewing Machine Parts ' eBay
www.ebay.com/bhp/brother-sewing-machine-parts
  1. Cached
  2. Similar
Find great deals on eBay for Brother Sewing Machine Parts in Machine Parts and Attachments for Sewing. Shop with confidence. Missing: 1100prw
Sewing Machine Parts warehouse all Singer Brother Janome Pfaff ...
www.sewingmachinesales.co.uk/sewingmachineparts/
  1. Cached
  2. Similar
Suppliers of sewing machine parts attachments and accessories for Singer Brother Janome Paff, Toyota and Husqvarna sewing machines or overlocker spares. Missing: ce ‎1100prw
Sewing Machine Accessories & Spares ' Janome, Brother, Elna, Pfaff ...
https://www.gursewingmachines.com/sewing-spares-accessories
  1. Cached
Sewing Spares & Accessories: UK's biggest dealer of Sewing Machine Parts, Needles, Sewing Foot and all ... CE 5500, 8080. ... At GUR we have sewing feet for Brother machines and all styles of sewing, have a look at our invisible and ... Missing: 1100prw http://www.brother-usa.com/homesewing
Nov 20, 2016 | Brother Sewing Machines
How can I set shuttle timing?
go google and type in ---singer sewing machine needle and hook timing procedure
yes it is a singer but the principle is the same for all makes of machines and the detail is good
If you like change the search from singer to brother and include the model number
Jan 23, 2016 | Brother CS-8060 Computerized Sewing...
E2 error message
I have brother sewing machine CE 4000, it became jam, I opened the machine & tried to rotate it with hand, I took out the belt, it became easy to move, again fixed the belt, but now it does not turn on, may be the timing of belt has disturbed, it shows Er2, how to fix it.
Dec 09, 2011 | Brother CE4000 Computerized Sewing Machine
E6. Motor locked up because the thread is tangled. I have re-threaded machine and bobbin; thread still tangles after 2 or 3 stitches. HELP!
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
Jan 18, 2011 | Brother CE4000 Computerized Sewing Machine
CE-4000 brother sewing machine error
F4 means that the machine is losing a disconnect from the foot control which could mean a main pc or new foot control
Jul 15, 2009 | Singer 7462 Mechanical Sewing Machine
Timing
That needs a repairman because you have to reset the gears, if it is still having the same problem take it back to the repair center and they should fix it again for free because they did not solve the problem. I am sorry to tell you but those machines have been nothing but headaches to my customers, many have just bought new machines (our shop sells Brother and Babylock).
Jul 03, 2009 | Singer CE-200 Quantum Futura Computerized...
My CE 200 jammed and I cleaned it out now it won't pick up bobbin thread how do i reset the timing?
To reset the timing on your machine there are timing marks that show you where the machine must be set.
Remove the needle plate and bobbin case. Turn the hand wheel towards you until the needle bar is in the lowest position. You will see two marks on the needle bar with the top one being flush with the bottom of the bushing. If it is not, loosen the needle bar screw and move it up or down to set the marks. Make sure you keep the needle bar straight (needle clamp screw should be straight to the right).
Next turn the hand wheel until the lower timing mark is flush with the bushing. At this point, the hook tip should be just above the eye of the needle.
If the hook tip and needle do not line up, turn the machine on its back making sure the needle bar does not move. Loosen the two timing screws on the hook pulley (only loosen them 1/4 turn). Move the hook to line it up with the needle. Tighten the screws and recheck the timing. The feed dogs should be in the down position when timing the machine. If the feed dogs are up when the timing is done, the hook timing is out 180 degrees.
May 12, 2009 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
327 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
