Question about Motorola Canopy 5.2 GHz Wireless Access Point - AES Encryption (5201AP)
Motorola canopy what is the otimum setting for my canopy? and how can i adjust the down-link and up-link allocation, because mine is only 500downlink 500uplink
    Problem Solver:
  • 10 Answers
Just go to the configuration tab then QoS (quality of service) and set your sustained up and download links at 20,000 each. that will open you up to all thats available.
Posted on Dec 13, 2008
To access canopy via laptop
Go to your main router's page and look for a section that lists the connected devices. The canopy should be listed there.
Mar 11, 2014 | Motorola Canopy PTP 54300 Wireless Bridge ...
My motorola canopy cannot detect LAN Destination Host Unreachable?
Sir raymond, how can i access my Motorola canopy? when i upgrade the firmware to the latest version and didn't specify the correct IP address of canopy instead of example: 10.223.41.42 i used the 169.254.1.1 in CNUT after upgrading the version my PC LAN card cannot detect anymore the canopy. canopy lights still blinking inside but in PC LAN card not blinking and its says network unplugged. how to fix the problem.. please send me the step on how to fix it.. here's my email add: amanics007@hotmail.com waiting for your response. thanks!
Apr 20, 2013 | Computers & Internet
I have a set Motorola Canopy 2400BH but i forgot ip address and username and password, how can i access it for using.
You need to user an Override Plug, which can be fabricated this way:
To fabricate an override plug: 1. Install an RJ-11 6-pin connector onto a 6-inch length of CAT 5 cable. 2. Pin out all 6-pins. 3. Short (solder together) Pins 4 and 6 on the other end. Do not connect any other wires to anything. The result should be as follows: Pin 1 ? white / orange ? Pin 1 Pin 2 ? white / green ? Pin 2 Pin 3 ? white / blue ? Pin 3 Pin 4 ? green ? Pin 6 Pin 5 ? blue ? Pin 5
Regaining access to the module To use the override plug 1. Insert the override plug into the RJ-11 GPS sync port of the AP. 2. Apply power to the module through the Ethernet cable. RESULT: The module reboots with the default IP address of 169.254.1.1, password fields blank, and all other configuration values as previously set. 3. Set passwords as desired. 4. Change configuration values if desired. 5. Save the settings. 6. Remove the override plug. 7. Power cycle the module.
You can view more details at:
http://www.canopy-wireless-solutions.com/AppicationNotes/APManualIss5.pdf
Apr 30, 2011 | Motorola CANOPY 2400AP (2400APBC)
HI. I cannot access my Motorola Canopy 5440BH with its IP address
There is a great article at Working with Windows Wireless Networks
If you need more help post back! Thumbs and testimonial are welcome!
Jan 12, 2011 | Motorola CANOPY 5.4GHZ OFDM 21MBPS...
I have conected 4links by motorolla canopy in a
try to check firewall settings whether it is enabled or not
Aug 28, 2009 | Motorola Canopy 5.7 GHz Wireless Access...
Factory Default Motorolla Canopy 900mhz. AP
all you need is a phone cord (that you dont want to use anymore) just ground the number 4 and 6 wire together and leave the rest alone. plug it in the canopy and then power it on. It should then be at the default ip. I think its 169.254.1.1 or 192.168.100.1.
Jun 16, 2008 | Motorola Canopy 5.2 GHz Wireless Access...
What have users said about what setting get the otimum picture...I have a 42 80u
Beauty is in eye of the beholder. Manufactures give options: brightness, contrast, detail & ect. So, adjust your tv to your eye, OR you can call a local tv repair shop that does calibrations. They vary in cost from $150.00 to 450.00. NOTE: the manuufacture will not do this, it is the responsibility of the store to set up, but not to this detailed. Good look and your tv.
Apr 02, 2008 | Televison & Video
Not connecting to internet
When you power down the canopy, what happens is you also do a hard reset which from your post re-establish the connection.
One of the many possible causes is that the canopy is loosing its DHCP lease on its assigned IP add. This may be a security feature/measure of your ISP limiting assigned IP add through a DHCP server for only a couple of hours to clients such as yourself. If this is the case then you have to bring this to the attention of your provider;
Another that you can try is to telnet to the canopy interface and check its settings. Its IP add is 169.254.1.1(255.255.0.0). Newer versions uses the 10.X.X.X (255.0.0.0) series, pls check which one you have.
Alternately, what can be done is to do a soft reset (not powering down/hard reset). Right click on your Networking icon in the System Tray and click on "Repair".
Other areas you can check/try are your router settings (if you are using one), settings of HTTP1.1 through proxy connections in IE, fix DNS (you can get them from your ISP). If you are using XP, there is also a registry tweak for DNS errors resulting to no connection (winxp_dnscache.zip).
Hope that this be of some help/idea. Pls post back should you need additional information.
Good luck and kind regards.
Dec 31, 2007 | Motorola CANOPY 2400AP (2400APBC)
Motorola Canopy 5.2 GHz Wireless Access Point - AES Encryption (5201AP) Logo
375 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
