Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave broken door latch
It's a GE Spacemaker model JVM1640WB004
  • GE Master
  • 9,098 Answers
The door latch head (hook) is pretty easy to replace or repair if that's the issue.
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
We have critical safety & disassembly info at our site, linked here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Posted on Sep 27, 2008
GE Countertop Microwave Oven Door is stuck closed
Remove the cover. You should be able to access the two latches and release them. Once open you will have to take the door apart and repair the latch
May 05, 2014 | GE Profile Spacemaker Over-the-Range...
I have a GE Spacemaker (JVM1631). The door latching mechanism has failed and will not stay closed causing the the microwave to not function. Do you have any troubleshooting suggestions?
Hi, normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
The door latch head (hook) is easy to replace or repair if that's the issue.
Normally you have to separate the door panels (as shown in the manual) and then you'll see the screws you need to remove.
The best place to order GE parts is Tritronics.
Jan 01, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My ge Profile microwave convection oven (JVM1790) will not turn off. I don't think it is actually heating and the turntable isn't turning. However the light is on and it sounds as though it is heating...
sounds like the broken latch is your problem.yes you can buy a latch assembly and fit .broken latch does not activate micro switch so it is like having the door open.hope this helped you let me know
Jun 22, 2010 | GE Profile Spacemaker Over-the-Range...
GE Spacemaker 1400 acts like everything works but does not heat.
Hello :
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
Check also the turntable . It could be out of it's right place .
WARNING :
1:Don't slam your microwave door because this may cause the fuse to blow and this is the reason of bad door switch problem .
2: A microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck
Apr 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I purchased a GE Spacemaker Microwave. I just
First check you owners manual for installation instructions if any. There may still be shipping materials in the unit that have not been removed. If you do not see any shipping materials then by all means call the service number. Your door latch may have been broken in the shipment orocess. It would be a valid warranty repair.
Jan 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Replacing door latch pawl
how do I replace door latches on a spacermaker XL microwave oven? thanks
Oct 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
2,837 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
