Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
MAYTAG MZD2752GRW COMPRESSOR ELECTRICAL CONECTON
    Sergeant:
  • 409 Answers
what exactly are you looking for? are you replacing the compressor yourself?
Posted on Sep 24, 2008
Maytag referigerator running but not cold
Pull refrigerator away from the wall and then remove the lower cover that covers the compressor, unplug and feel the top of the compressor. Is it warm, hot or are you unable to keep your hand placed there? If too hot to keep hand there I want you to unplug and allow to cool and replace the=> 2262185 Start Relay
the=> 61006295 Overload
and the=> 999509 Run Capacitor
I will be back with how to test your compressor electrically, Thanks Sea Breeze
Jul 09, 2012 | Maytag Refrigerators
Wireless printers conecton
All I can see is "wireless printers conecton"
yes some printers do have wireless !
Now if there was a "question" to go with the statement ?
Dec 11, 2011 | Epson Office Equipment & Supplies
Maytag + mzd2752grw side by side on the freezer side ice builds up on the bottom
Your defrost drain is frozen. If you can empty the freezer you can thaw the drain with a hair dryer. You will have to turn the box off. should only take half hour. hope this helps
Aug 21, 2011 | Maytag Refrigerators
Maytag model # MZD2752GRW. Ice build up in bottom of freezer. Seems to be coming from vent behind bottom freezer basket.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 18, 2010 | Maytag Refrigerators
Freezer is making rumbleing noise!
You have an abnormal compressor on running. Unfortunately , it is hard to repair this compressor. People usually replace the compressor rather than get it repaired. Prolonged this situation will increase your electricity bill.
Sep 02, 2010 | Maytag Freezers
Maytag window ac blows line cord fuse soon as turned on
Check all your electrical wires and connections. If all okay, you can remove the compressor wires and ohm the compressor motor windings to ground. If you have continuity from any winding-to-ground, your compressor is shorted out and will need to be replaced.
Apr 09, 2010 | Maytag M6Q10F2A Air Conditioner
My maytag msd2456dew will not stay cool. the compressor is not running but the fans are. could it be the start relay?
Do you have power at the compressor?
There is a PTC sensor connected to the pins of the compressor.
Be careful !! and check for power there.
If in doubt, call an electrician. There is a risk of an electric shock.
You should have live and neutral at the compressor pins; one will be switched through a PTC Sensor.
Hope this helps.
Sep 29, 2009 | Maytag Refrigerators
Change filter light
you have to hold if my memory is good the two light and lock switch for 3 sec.... (the infos are written on your new filter box..)
the light doesn't go out by it self.....you have to make the reset....
Jul 04, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Water from freezer dripping into fridge freezing and accumulating in the crisper drawers.
Maytag , MZD2752GRW; Water accumulating and is freezing in bottom of the freezer, then runs out the door on to floor.
Jun 10, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Ice melted
Very possible your compressor is bad or the start capacitor is defective. Need someone to do an electrical test on compressor to eliminate the compressor.
Let me know if I can help further, Thanks Sea Breeze
Mar 19, 2009 | Maytag 25.6 Cu. Ft. Side-by-Side...
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
246 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
