Question about Bosch Dishwashers
I have a Bosch "Classic Electronic" dishwasher that has been in use for only 18 months. If it helps - SGU53E05AU/30 is marked on top of the door.. my problem is that on the last cycle, the water won't drain so I am left with lovely clean dishes but there is water up to the drawer line present and it won't drain until the next wash. I have cleaned all the filters and ensured the pipes are not obstructed. It is odd that it only does it on the last cycle. Could it be the microchip? Any ideas?
    Sergeant:
  • 409 Answers
thank you for providing the model #, that helped me narrow down the troubleshooting.
try the following to fix your problem:
check for blockage or kink in the drainage hose if okay
check the pump to see if it's jammed or anything jammed in it if okay
check the filters for any blockage if okay
check to see if the program had ended and any error messages on the display if okay
perform the reset function
please let me know if this fixed your problem.
Posted on Sep 24, 2008
How do I run a self diagnostic on Bosch Classic Electronic SGU53E75AU/86?
Before going to the controller it might be better to verify the heater or thermostat (NTC).
If you want to know the part details refer this schematic
http://www.bosch-home.co.uk/store/spareparts/Builtunderdishwasher/SGU53E75AU/86
It is interactive and you can switch between assembly drawings and parts lists. The heater and thermostat are drawing 4.
Apr 26, 2014 | Bosch Dishwashers
Bosch she43f15uc just stopped pumping water. Any ideas? it is only 18 months old.
My Bosch dishwasher had the same problem. After checking the over flow pan I removed the inlet hose to check water flow. There was none. I checked my cut off valve...open...I had water at the kitchen facet...scratch my head...I looked closer at the Bosch supplied braided water hose. It is directional (label indicating which end to hook to supply)....closer inspection reveals maybe there is a back flow valve in that side of the braided hose. Disconnect, blow air through...air passes freely...reconnect and bingo water flow at the dishwasher. In line back flow valve...can you imagine what a repair man would have charged for that?
Apr 04, 2012 | Dishwashers
My Bosch is only a few months old and it won't drain the water.The filter is fine. It's a shea43p16uc60.
Your bosch washer should still be under warranty:
  • Limited warranty, entire appliance, parts and labor (1 year)
  • Limited warranty for non-electronic components; parts only (1st to 2nd year)
  • Limited warranty for control board (microprocessor); parts only (1st to 2nd year)
  • Limited warranty for motor or any component of the motor (1st year to 10th year)
May 19, 2011 | Bosch SHE43P16UC Builtin Dishwasher
I need an operating manual for a Bosch electronic classic dishwasher SMS50E22AU
Please click on the following links to download any manuals you require for your dishwasher:
Bosch SMS50E22AU User Manual Bosch SMS50E22AU Installation Instructions Bosch SMS50E22AU Stacking Supplement
After clicking the links you can open the files in a browser window or save them directly to your PC. You will need to have Adobe Reader (or any other PDF file viewer) installed to open the files:
Click here to download Adobe Reader
Hope this helps. If you have any difficulty downloading the manuals or need further assistance with your dishwasher, please let me know.
Regards, BElectric
Apr 27, 2011 | Dishwashers
How to remove latch from Bosch SHU3306 dishwasher dispenser?
A solution to this problem would be to sell me your dishwasher. The law firm for which I work is looking to acquire an old unrepaired Bosch SHU 33 dishwasher for some ongoing litigation. If you (or anyone else with this model Bosch) could send me some details regarding your dishwasher, you may be able simply to buy a whole new dishwasher. My email is JFraser -at- jshlawmi.com.
Thanks!
Jul 22, 2010 | Bosch SHU3306UC Built-in Dishwasher
Where do I find the pcb on a Bosch dishwasher classic xx?
Check at front door top. You may have to open the screws around the door.
May 21, 2010 | Bosch 24 in. SGS43C12 Classixx...
No water inlet on dishwasher
the water inlet is controlled by an electronic valve, which sounds like it is faulty.
Apr 30, 2009 | Bosch 18 in. SRS43E02 Slim-Line Built-in...
BOSCH DISHWASHER Flooding
Removing the water level sensor it is not a difficult operation, it is held with one bolt at the base of the floater arm.
The problem is that you cannot be sure that the floater is not working unless you find out that the floater is filled with water or stuck.
There is an electronic test to verify if water level switch activated by the floating sensor is working. Instructions here: Bosch dishwasher helps.
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
Feb 07, 2009 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Water pump noise
There is something that is stuck in the food shredder and causing this sound .
May 26, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
477 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
