Question about Dishwashers
Maytag (MDB-1) Dishwasher Controls blinking
Dear Expert,
Every once a while, my dishwasher electroonic control lights blink intermittently. The "CLEAN", "HEAVY WASH' and "HEATED DRY" lights blink simultaneously at 1 second intervals: between these intervals, the "SANITIZE" light goes on for a split second. When this happens, none of the controls disactivate the disabled appliance. In the past, I have been lucky to hold or press buttons in such a sequence that cancels the blinking and reset the dishwasher. I was wondering if you could provide assistance as the manual guide does not make any reference whatsoever to this type of problem.
Thank you in advance for any help you can provide.
Alex
    Sergeant:
  • 409 Answers
Hi alex,
could you please provide me with the complet model # of your dishwasher?
thanks,
carmen
Posted on Sep 24, 2008
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
May 19, 2011 | Maytag Dishwasher
Maytag mdb/c-2 some lights are blinking and won´t stop. I can´t start the cycle of cleaning, well really i can´t start anything. Please any sugestion ?
press the "off" button and hold it down for several seconds. this worked for me when i encountered the same problem on my maytag jetclean this weekend. it reset my control panel and now it's working great!
Sep 11, 2010 | Maytag 24 in. MDB5600A Jetclean II...
My Maytag Quiet Series 300 light is blinking 5 times by the lock button. It won't do anything else other than blink 5 times if any other button is hit. Help!!
When Control Lock is lit, all buttons are disabled. If you press
any pad while your dishwasher is locked, the light flashes
5 times. The dishwasher door can be opened while the
controls are locked.
To turn off Lock, press and hold Heated Dry for at least
3 seconds.
Dec 30, 2009 | Dishwashers
Control panel lights blinking
I have the same dishwasher with the same problem, try pushing the delay/resume button, then the drain/off button. When the lights go off start your wash cycle.
Sep 17, 2009 | Maytag 24 in. MDB5600A Jetclean II...
I have a Maytag MDB 5600AWW dishwasher. There are
If there are no lights on the control panel then initially check if connections to the panel are fine.If they look fine then you definitely need a new control panel. No need for a new touch panel.Its always that the control panel goes faulty,not the touch panel.
you can also check for competitive rates from local dealers and few sites like--repairclinic.com and applianceparts.com
thanks.
Aug 28, 2009 | Maytag 24 in. MDB5600A Jetclean II...
No power to Maytag Dishwasher MDB-8
no breaker on motor look at door lock ***. for power
Nov 03, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Maytag Dishwasher: MDB/C-2 Suddenly Stopped Worked
I have had this dishwasher since 2003 and haven't had a problem whatsoever. This is one of the best dishwashers I have purchased out of the 4 I have had.
Jul 21, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Lights flashing can`tstop
there is a clog in your filter trap once uncloged pull plug to reset dishwasher
May 30, 2008 | Maytag 24 in. MDB3700 Built-in Dishwasher
Maytag quiet series model #:MDBH950AWB
The dishwasher lights are all blinking, it starts randomly, like one in every 50 times you press the buttons. I have unplugged it to reset several times. Nothing is working. I'm looking for a solution to blinking lights and it not starting. is there any other way to reset the controls????
Jan 13, 2008 | Maytag 24 in. MDBH950AWS Built-in...
Dishwashers Logo
722 people viewed this question
Top Dishwashers Experts
