Question about Tappan TGF657 Gas Kitchen Range
Tappan gas range burner ignition
I've got a 5-year old Tappan gas range. Two of the burners don't ignite, the other two and the oven are fine. What do I need to do to fix the problem? Will buying a new spark module fix it, or is the problem somewhere else?
  • busdriverfin Mar 10, 2009
    where is the sparks moduler located? Can you show a picture?
  • Anonymous Mar 14, 2014
    tappan gas range
  • 750 Answers
Hello paultoledoWelcome to fixya.
I'm Huuum and happy to assist you,
You said, You got a 5-year old Tappan gas range. Two of the burners don't ignite, the other two and the oven are fine.
What do you need to do to fix the problem?
Sounds like a yes from where I'm sitting, your right on target, buying a new spark module will fix it.
That sounds like the spark modules.
I think you are correct!
Let me know if you need me!
Please remember to leave a solved rating!
Huum
Posted on Sep 24, 2008
Broiler works. Oven does not
Plugged gas pipe which connects to the burner.
Jul 04, 2013 | Tappan Kitchen Ranges
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Dec 01, 2012 | Tappan TGF320 Gas Kitchen Range
Caloric range oven, older at least 20 years old, the range burners spark, but will not light, i am assuming that its electronic ignition, no pilot light?
If you don't smell gas, then it is probably electronic ignition and not a pilot light.
But if your oven and none of the range burners light, are you sure you are getting gas to the unit or from the range valve to the burners and oven? Can you light the burners with a match? If you can you can rule out the valve and incoming gas line, and concentrate on the ignitors.
Jun 07, 2011 | Kitchen Ranges
I have a tappan gas range all the burners but one works when i turn it on. You can hear the flow of gas, and the oven doesnt work. what could that possible be
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Mar 25, 2010 | Tappan 24 in. Freestanding Gas Range...
Tappan oven not gas flow or ignition
Right rear burner will not ignite without assistance (a match or lighter). What is the problem?
Feb 13, 2009 | Tappan TGF303BW Gas Range
Tappan TGFS26C, Oven igniter not even
Lets take the oven problem first. Sounds like you have a Hot Surface Ignitor problem. This is the device that glows and lights the burner. You can buy a universal ignitor at most appliance or heating and air conditioning supply houses. Note carefully how the old one is mounted. You may have to make some adjustments to mount the new ignitor, but it MUST be close to the gas burner like the old one! You don't smell gas because the gas valve will not open until the ignitor is hot. All ignitors work with the same voltage, so simply connect the new wires to the old ones.
I'm not certain if you have a standing pilot for the stove top burners or electronic ignition. Remove the top panel to check. If you have a gas pilot, relight it. If electronic ignition, clean the ignitors. If that does not solve the problem you may have to call a technician, as these systems can be complex.
Hope this helps.
Ray
Nov 20, 2008 | Tappan TGF363 Gas Kitchen Range
Oven takes up to 25 min. to preheat
I would suggest looking at how long before the bake burner ignites. If taking longer than 5 minutes before it ignites, then you are looking at a possible bad ignitor. The ignitors just don't last more than 5 yrs with regular use.
Jan 06, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan gas kitchen oven will not heat
Almost always a weak oven igniter. Remove oven floor by removing 2 screws at rear of floor. Remove flame spreader from burner, if it has one. Turn on oven and see if igniter gets red. It's the caged thing on burner tube. If it does but doesn't light gas, replace igniter. UNPLUG UNIT FIRST!!
Put dishwashing soap on threads of 2 screws holding igniter in place. This will allow it to come out easier. Do-not use oil. It will make your oven smell like a diesel truck.
Remove screws. You will have to remove drawer in front. Underneath you can fin wires from igniter. These will be cut at igniter and connected to igniter with enclosed wire nuts. The 2 wires to igniter go either way.
Nov 22, 2007 | Tappan TGF320 Gas Kitchen Range
Tappan Gas Range Oven Will Not Light
probable displaced burner assembly, faulty flame failure device or blocked burner or jet. Regards Engineer
Jul 20, 2007 | Tappan TGF320 Gas Kitchen Range
Tappan TGF657 Gas Kitchen Range Logo
422 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
