Reset compaq presario to earler date - Computers & Internet
    Genius:
  • 1,124 Answers
If you need to reset your computer to earlier time, Under Win XP go to Start >>Accesories >> System Tools >> System Restore......
Posted on Sep 24, 2008
DATE -TIME RESET??
What seems to be the problem with the date and time?
If you want to change the date and time settings, then you can click on the time on the bottom right corner of your screen. There you can change the time and date settings.
Or if date and time are always changing whatever you do then you would need to change the CMOS battery of your computer.
David
Jun 10, 2013 | HP Compaq Presario V2000 Notebook
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
DEFRAG C:
CHKDSK C:
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like www.topmic.com
Dec 29, 2012 | ASUS K52n-a1 Notebook
Power-On Password on Compaq Presario C300
YOu can reset bios password with 2 method.
(1) open back cover of laptop then find motherbord .Pull cmos cell from motherbord for 15 minutes then again put it in it's position .then it not ask for password.
(2)You can clear password with jumper settings find jumper on motherbord named clear cmos it has 3 pin .1-2-3
Put jumper in 2-3 position then again put it in 1-2 position then check .
Let me know if you need more assistance.
Thanks.
Nov 09, 2009 | Compaq Presario Notebook
Clearing cmos
The BIOS battery maybe under one of the panels on the bottom of the laptop or under the keyboard.
To reset the BIOS ack to the default settings, go into the BIOS configuration and look at the various configurations, usually there is a setting to load the Default settings, then save and exit, and this would not change the Date & Time setting.
The other way to set the BIOS default setting is to remove the BIOS battery (it is probably a lithium 3volt button battery), wait 1/2 hour and replace the battery, the go into the BIOS configuration and set the Date & Time setting etc.
Jul 04, 2009 | Compaq Computers & Internet
Forgot my password for my Presario SR122NX
if u forget BIOS password so first remove power cable and moniter cable and than remove cmos battery on motherboard for 2-3 min. after that put cmos battery back in same possition and start ur pc...and set bios time and date..
If U forget windows password so pls tell me which windows u use...
than only i will give right ans of ur qus.
if work RATE me if not reply me
thanks
bye
Mar 20, 2009 | HP Compaq Presario SR1222NX (PN234AA) PC...
Missing drive
Use system restore to set computer earlier date that was working fine. If there is a missing driver by symptoms please go to support.hp.com or
http://h10061.www1.hp.com/ccsearch/search?method=mainQuery&qry=driver%5D&pname=Compaq+Presario+C700+CTO+Notebook+PC&ptype=consumer&stype=pn&spname=Compaq+Presario+C700+CTO+Notebook+PC&spid=3559331&productBigSeriesOid=3466273&pid=3559276&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-005%2Cs-006%2Cs-017%2Cz-001&lang=en&ctry=us&dlc=en&mode=lz&uqry=&pname_desc=Compaq+Presario+C700+CTO+Notebook+PC
For further assistance please post more.
Good Luck
Jun 16, 2008 | Compaq Presario 700 470024-192 Notebook
Entering COmpaq M2000 BIOS
you can simply remove the cmos battery then press the power button for atleast 20seconds then thats it if the date resets then the passwords as well ^^
Jun 11, 2008 | Compaq Presario M2000 Notebook
Display problem
try to do a system restore, for windows (xp or vista) click start>all programs> accessories>system tools>system restore> next> choose date> next....>system will automatically restart and reset your computer back to the date you have chosen. Just make sure that you choose a date when all was working ok.
Feb 16, 2008 | Compaq Presario 1200 Notebook
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
