Question about RCA 244889 Remote Control
RCA remote none of the buttons on the remote work, the TV is now stuck on," Unusable Signal" message. I tried turning the TV off and on and putting in new batteries, nothing works. Please help!! Thanks, CJ.
  • Anonymous Mar 19, 2014
    It is on DVD an I can't get it on to tv I get it up on screen to scroll to Freeview an it then says press ok to tune but there is no ok button on tv an I tried all the other buttons for ok but it mocks settings of an goes back to dvd
  • 57 Answers
Could it be possible that the remote needs reconfigured? If none of the buttons work, the it could possibly be that you need to re-enter the TV code back into the remote.
Posted on Sep 24, 2008
I NEED CODES FOR RCA R53NP REMOTE
Posted on Jun 20, 2009
Can not get it to put my tv on video
Posted on Mar 06, 2012
I bought an RCA smart tv and it was working fine until I picked up the RCA remote to change channels and now I get "no signal" on my TV screen. How do I fix this?
What was going on before you picked up the remote? Did the remote work OK to initially turn on the TV? Where you able to change channels prior to this issue? If yes, then maybe you accidently changed the source mode of the TV via the remote?
The source mode button chooses what signal you want to use for getting a signal transmitted to your TV (E.g., antenna, HDMI, etc.) If the source button is clicked to something that is not supported (E.g., Line1, or Line2, or Line3, or a particular source like the antenna option is not set-up properly to receive a signal, then you will receive a, "no signal" message".
I
Dec 14, 2016 | RCA Televison & Video
I need the maual for this rca tv L37wd22yx6 tv just keeps saying unusable signal and i need the maual
What is the signal source for the TV? Make sure that you are on the correct input. Use the Input button on the remote. If you do not have the original remote, you need one that matches that function. (Often a Source or Input button is not available on the low end remotes.) Check that you have the signal set to Antenna or Cable if you are using the coaxial connection and the source is TV. (Menu > Setup > Channel Setup > Signal Type)
If your source is a computer, use the VGA port not the HDMI port. Computers send a different type of video signal than video set top boxes. The L37WD22 can't interpret the PC signal on the HDMI input.
For a set top box on the HDMI port, the unusable signal message indicates a communication issue. Try pressing the Info button on the remote. If you see an additional message of Acquiring Channel, then the set top box isn't responding to the remote. Check that the device is on and set up correctly to communicate with the TV. (For example, if your set top box offers progressive scan, try turning of that feature with the control for the box.)
The L37WD22 was built by TTE for the RCA label. The manual is available on the TTE support page.
The direct link to the User's Manual in English is http://support.ttetech.com/RCATV/Assets/pdfs/L37WD22_16788070_IB_e-07.pdf .
I hope this helps.
Aug 29, 2011 | RCA Televison & Video
It is stuck on video mode and there is a message on the screen stating unusable signal. How do I return it to TV?
Hello
Highlight Exit and press MENU
Press 0 on the remote
Press CLEAR. The on-screen displays are cleared from the screen and you
return to TV viewing
Ok
Jun 25, 2011 | RCA F25441 25" TV
Unusable Signal Message
I can;t keep my DISH satillite to turn on. when I turn the tv on and hook up the cales i get unusable signal and blue screen
May 21, 2010 | RCA TruFlat 27F520T 27" TV
42 RCA TV flashing unusable signal
Ur backlight video board it dead,must replaced.
Dec 05, 2009 | RCA L42WD22 42 in. LCD Television
When we turn the TV on after hooking up to cable we receive this message on the screen - UNUSABLE SIGNAL
goto main menu , goto setup , goto autoprogram and press start ,
the cable line must be going in to
ant in on the back of the set
and make sure that the video 1 or 2 is off
on the tv
Jun 28, 2009 | RCA F32650 32" TV
RCS Scenium
What is your TV input connection? Are you using Antenna? Cable? Dish?
The Unusable Signal sounds like the TV is not getting a signal. Does your TV have a built in HD Tuner?
If you are using Antenna you might want to try setting up the connections and it should search for quality channels that you get good signal strength. If you are on channel 2 and there is no over the air channel 2 it may say "unusable signal".
Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Unusable Signal for PS2
If you want to use a PS2 with an RCA stereo monitor Colortrak plus television, folllow these steps:
1.Buy a universal remote compatible with RCA televisions if you don't have the original.
2.If your remote needs programming, program it with the manual provided.
3.Goto Menu
4.Goto Alarm
5.Goto Alarm Channel
6.Set Alarm Channel to 00
7.Exit Menu
8.Goto channel 00 on the television by using the remote.
9.You should be in AV mode, and able to play your PS2.
P.S. I don't know if you need to set Alarm Channel to 00, but that's how i did it.
May 13, 2008 | Televison & Video
My rca tv
im having the same problem on my RCA P61960 61" i just moved and it might have got bumped a bit not sure but when i try to use my component video hook up i get a blurry distorted picture for a few seconds then i get an unusable signal message if i change my input to just cable it works fine please help
May 10, 2008 | RCA P61960 61" Rear Projection Television
61" RCA Projection TV, no picture, "unusable signal" message
Read the suggestion of unplugging the TV for at least 4 hours to re-set to factory specs and that took care of it!
Apr 03, 2008 | RCA HD61LPW165 61" Projection HDTV
RCA 244889 Remote Control Logo
717 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
